Author Topic: tapered wrist pins  (Read 18092 times)
Re: tapered wrist pins
« Reply #50 on: December 07, 2009, 05:22:00 PM »
If it lives in a Gixxer, why not in a Honda.. ???
 Wrist pin buttons, lighter than steel...
« Reply #51 on: December 07, 2009, 05:39:35 PM »
Of course the GSXR's pistons have huge side reliefs, a narrower rod small end so the pin boss still is plenty wide enough even with this short pin. My 60mm forged pistons are old school, (not by choice) full round skirt and at 5.4mm shorter than the pin supplied I'm nervous to use the Gixxer pins.
« Last Edit: December 07, 2009, 05:47:03 PM by bwaller »
Offline turboguzzi
« Reply #52 on: December 07, 2009, 06:58:05 PM »
+1, go with the full length of the pins that can fit between the circlips
TG
  • Moderator
« Reply #53 on: December 07, 2009, 07:24:22 PM »
Mike has an address for you Brent, he mentioned it earlier but has gone to bed, suffering with a cold.
PM him tomorrow in case I forget.
Sam. ;)
« Reply #54 on: January 29, 2010, 07:42:21 PM »
 Got an older Wiseco 836 kit, new in box..
 Has tapered wristpins!.. not sure if they are what came with it?
still in bags but marked made in Taiwan.. :(
« Reply #55 on: January 29, 2010, 08:11:59 PM »
What do they weigh out of curiousity? It is next to impossible finding lightweight tapered pins in the 15x50mm size.
« Reply #56 on: January 29, 2010, 10:54:12 PM »
I will try to get a weight on them..
Offline CB500Four
« Reply #57 on: January 30, 2010, 02:22:07 AM »
Hello!
I have here some stock Honda wrist pins.
CB750 DOHC
OD 15mm   ID 9.10mm   length 50.38mm   weight 44g
CB900 DOHC
OD 15mm   ID 9.10mm   length 52.95mm   weight 46g
CBX1000 DOHC
OD 15mm   ID 10.10mm  length 50.37mm   weight 38g
CB750 DOHC self tapered running in my engine
OD 15mm   ID 9.10mm to 12.80mm   length 50.48mm   weight 35g
Regards,
« Last Edit: January 30, 2010, 02:36:04 AM by CB500Four »
« Reply #58 on: January 30, 2010, 04:57:21 AM »
Hey thanks CB500Four, great info. It may just be the breakthough news I was looking for.
I was about to give up on this and finally heard back from another piston manufacturer about some 40g straight wall pins, so suddenly I'm swimming in lighter weight options.
It's a good thing some parts are delayed and that I'm so bull-headed!  ::)  (can hardly wait for the Sam comment here  ;D)
« Reply #59 on: January 30, 2010, 08:32:04 PM »
Tapered bore pins, came with a Wiseco  836cc kit
56.1mm long
44.5 gr
8.54 mm ID
 stock 736cc pin from 3pce oil ring piston....40 gr
 MTC forged 970cc piston, tapere bored pin    49.63 gr
 got some piston weights, will post on light pistons.
Offline turboguzzi
« Reply #60 on: February 02, 2010, 06:48:29 AM »
Hello!
CB750 DOHC
CB900 DOHC
CBX1000 DOHC
Regards,
hei heinz, the last ones sound good, but how do you know the difference from the first 750 dohc.... :-)
got part numbers for the 35g pins?
cheers
yossef
« Reply #61 on: February 02, 2010, 07:41:55 AM »
Sounds like he modded them himself!
Offline turboguzzi
« Reply #62 on: February 02, 2010, 10:54:34 AM »
now that you say it.... "self tapered" can be read in a few ways :)
TG
Offline CB500Four
« Reply #63 on: February 02, 2010, 03:04:00 PM »
Thanks,
that was it what i would to describe.
I have lightened the pins on a lathe.
They have a thin hardened skin but if you break thru
it´s relative easy to turn it down.
Regards,
« Last Edit: February 02, 2010, 03:06:47 PM by CB500Four »
  • Moderator
« Reply #64 on: February 02, 2010, 10:49:24 PM »
I never said a word ;D ;D ;D ;D Did you contact the people at that address that Mike gave you ?
Sam. ;)
« Reply #65 on: February 03, 2010, 04:23:58 AM »
Yes thanks for the name Mike & Sam, Precision Products Performance Center and they can manufacture pins but not near the weights I was hoping for. Good folks though.
I like the CB500Four option.
Offline turboguzzi
« Reply #66 on: February 03, 2010, 03:10:46 PM »
Brent, turn some wood dowels on a lathe if you want, just get that motor running!!!!
TG
« Reply #67 on: February 03, 2010, 03:23:38 PM »
I hear ya TG, believe me.  Problem is, different parts of this bloody motor are spread all over North America.
We're get there.  :-\
  • Moderator
« Reply #68 on: February 03, 2010, 11:18:05 PM »
TG
Good idea TG, balsa wood is nice and light ;D ;D ;D
Sam. ;)
