Thankyou for the reply's.
It is for a 750 K3. Is it different from other 750 SOHC's? I am trying to turn the bike over (without fuel) and I am blowing fuses (even 30 amp). I must have a major short somewhere, not surprising seeing as I made the wiring loom
The ignition switch is connected re to red and black to black. Is the black wiring seperate to the 'green ground'?
When connected up to the the regulator I get connection between black and green. but when I test the green/white or black conectors on the regulator connectors on the combined reg / rec I get a quick temporary connection (1/4 second) and then nothing.
Is this correct?
Thank you for your advice in advance.
