Author Topic: High and tight pipes. Need clearance!  (Read 860 times)
Offline Turbogrimace
    • Draft Cycle Works
« on: October 23, 2009, 05:29:45 AM »
Im looking for a set of CB750 pipes that hug the frame rails and dont sit lower than the frame.  Im looking for a 4-2 (especially since most 4-1's run under the frame).  Does anyone know of any pipes that sit high?  my frame is about 4 to 4-5 inches off the ground and I dont want to lose any more clearance.  The pipes I have on there now sit about a half inch under the frame rails and sit wide, so turning is a pain.
Hell scramblers would be great hah.
Thanks!
Offline Alan F.
Re: High and tight pipes. Need clearance!
« Reply #1 on: October 23, 2009, 07:43:11 AM »
Maybe ask KingCustomCycles.com about the pipes he uses on his rigid bobbers?  His ride heights are around 5"
-Alan
« Reply #2 on: October 23, 2009, 08:00:24 AM »
Stock header pipes are the highest you will find.
 I used a turbo header pipe, and then built a rear section to lower my bike a lot.
 If you are not cutting off your stock sidestand mount, you are not low yet..
    • Draft Cycle Works
« Reply #3 on: October 23, 2009, 08:35:06 AM »
There never was a stock sidestand mount.  It's a santee swingarm frame.  I'll check out Mr. King
