Author Topic: Gauge project  (Read 30559 times)
Offline b82ta
Re: Gauge project
« Reply #75 on: November 25, 2009, 10:41:31 PM »
Thanks for the comments.  Here's the set. The tach redline did not read as well as I had hoped, but its easily fixed... Except that I have to take the gauge apart again.... I'll run it like it is now for a while. The gauges also look much more dirty in the first photo than they actually are...  I'm also toying with the idea of making some wood face gauges with etched numbers. Not for my bike, mostly just to see how well it works.
Offline b82ta
Re: Gauge project
« Reply #76 on: November 25, 2009, 10:43:32 PM »
aaaaaand some photos would be good....
Offline mystic_1
  • 1970 CB750K
Re: Gauge project
« Reply #77 on: November 26, 2009, 06:04:51 AM »
Nighttime readability looks to be way better than stock, maybe cause the etched numbering catches the light so well.  Hard to be sure from the pics but that's what it looks like to me.
Wood faces would be interesting for sure.
Let us know how the acrylic ones hold up, my only concerns being heat and UV resistance.
mystic_1
- John Augustus Shedd
Offline Loki
  • my bike...so far
Re: Gauge project
« Reply #78 on: November 26, 2009, 06:27:45 AM »
where did you manage to have these made?
I don't have pet peeves, i have major psychotic f@cking hatred. - George Carlin
1977 Kawasaki kz 400
1999 Suzuki gsxr 600
1975 Honda cb 750f
1977 Honda cb 550k
Offline mystic_1
  • 1970 CB750K
Re: Gauge project
« Reply #79 on: November 26, 2009, 06:35:59 AM »
He made them himself :)
mystic_1
Offline Loki
  • my bike...so far
Re: Gauge project
« Reply #80 on: November 26, 2009, 06:48:49 AM »
wow thast crazy! how did you manage that, all the perfect straight lines?
1975 Honda cb 750f
1977 Honda cb 550k
Offline mystic_1
  • 1970 CB750K
Re: Gauge project
« Reply #81 on: November 26, 2009, 07:02:36 AM »
Looks like he has access to a laser cutter at school :)
http://forums.sohc4.net/index.php?topic=60571.msg657350#msg657350
mystic_1
Offline b82ta
Re: Gauge project
« Reply #82 on: November 26, 2009, 08:00:28 AM »
I'm more worried about the vellum not holding up than I am the acrylic, but Its an experiment so we'll see.  Also if people would be interested in acrylic gauge blanks I can cut clear white and black, but maybe a field test would be good first.
The gauges are actually mostly backlit now, I think the etching helps some, but I really think if I had just cut a plain blank it would work nearly as well.  I had originally intended to paint them, but the etching wasn't quite deep enough... The next ones I make will most likely just be plain, that way I can change the vellum inserts to whatever style I want.
Offline Loki
  • my bike...so far
Re: Gauge project
« Reply #83 on: November 26, 2009, 02:21:14 PM »
id love a pair of ya for my 77 cb550, but id want it in km...not miles. is there a way maybe i could pay you to do a set for me?
1975 Honda cb 750f
1977 Honda cb 550k
Offline b82ta
Re: Gauge project
« Reply #84 on: November 30, 2009, 11:31:16 AM »
Alright finally got around to getting some photos of it on the bike. The photos make them look much less legible than they really are... I love the way they look.  I might re-do them over break with a slightly different style, but we'll see
Offline Loki
  • my bike...so far
Re: Gauge project
« Reply #85 on: November 30, 2009, 11:45:27 AM »
looks slick!
1975 Honda cb 750f
1977 Honda cb 550k
Offline Industrial Cafe
  • Like a well oiled
    • Undead Asphalt
Re: Gauge project
« Reply #86 on: November 30, 2009, 01:08:12 PM »
nice dude, very clean. now to get rid of that hideous dashboard.
  • Like a well oiled
    • Undead Asphalt
Re: Gauge project
« Reply #87 on: November 30, 2009, 01:10:29 PM »
maybe make something that tells you all that info down in your lap.
Offline Loki
  • my bike...so far
Re: Gauge project
« Reply #88 on: November 30, 2009, 01:11:23 PM »
ya i was going to put my instrument lights in to my gauges with some small leds i think it will clean it up and make it look alot better
1975 Honda cb 750f
1977 Honda cb 550k
Offline b82ta
Re: Gauge project
« Reply #89 on: November 30, 2009, 01:37:00 PM »
Yeah I'll be doing something to get rid of that crap, not sure just what yet, but it is just way too much clutter up there.... I was originally also going to put the lights in the gauges but I haven't figured out a good way to do it just yet...  I've got all winter to come up with something though.
  • Like a well oiled
    • Undead Asphalt
Re: Gauge project
« Reply #90 on: November 30, 2009, 01:46:22 PM »
my lights were in my gauges from the factory, but when I changed to K8 gauges I lost them.
don't need em really, all I want is a neutral light.
Offline b82ta
Re: Gauge project
« Reply #91 on: November 30, 2009, 01:52:40 PM »
Yeah I might just put a couple bulbs somewhere for the neutral light, and maybe an oil pressure.  I can tell when my brights are on, and no one really cares about turn signals anyway... I was toying with the idea of putting a small 'dashboard' with 2 or 4 small lights in between the bar clamps.  Also want to re mount the key and whatnot to somewhere a little more out of the way.  I just hate how much clutter there is up there...
  • Like a well oiled
    • Undead Asphalt
Re: Gauge project
« Reply #92 on: November 30, 2009, 02:03:00 PM »
I remounted my key down under the tank, up front on the left.
Offline b82ta
Re: Gauge project
« Reply #93 on: November 30, 2009, 02:18:38 PM »
That sounds like a pretty good place for it.  What did you use for a mount? Just weld something on the frame?
  • Like a well oiled
    • Undead Asphalt
Re: Gauge project
« Reply #94 on: November 30, 2009, 02:56:11 PM »
an oem ignition frame mount.
Offline celebutante
    • mitchellsigman.com
Re: Gauge project
« Reply #95 on: November 30, 2009, 07:40:30 PM »
two cents here:
My bike had the key ignition relocated to the triple clamp with one of those little boomerang brackets and I wanted to put it back to the stock location. The factory bracket in the stock location was gone. I bought a pair of pipe clamp-style brackets for mounting electrical conduit from the local True-Value along with the boomerang-shaped bracket from the relocation. Rattle-canned the brackets flat black and used the including rubber insulators pieces (seemed to hold on the frame better, but you could ditch 'em). Worked awesome, looks nice and cost two bucks.
(lemme know if you need pics)
Offline the technological J
  • deliciouso!
Re: Gauge project
« Reply #96 on: November 30, 2009, 08:24:57 PM »
didnt u have some little squares at the bottom left of ur speedo? i saw it in the plans... i been keeping up on this thread and i dont see it on the most recent posts' pic... did it have a purpose or is it just me
94 ST1100..Gone
72 750 K2 Stay tuned!
  • Like a well oiled
    • Undead Asphalt
Re: Gauge project
« Reply #97 on: November 30, 2009, 08:47:37 PM »
yeah I was wondering the same thing, I thought that would house neutral, brights, and the oil lights
Offline b82ta
Re: Gauge project
« Reply #98 on: November 30, 2009, 10:48:59 PM »
They are still there and can be seen in the right light, I just had those etched on the faces as a reference point.  At this point I just wanted to test out whether or not the rest of the face would work, the next rendition will most likely have those installed, if I can figure out how to do it....  Small leds and maybe an insert to separate the lights?
  • deliciouso!
Re: Gauge project
« Reply #99 on: November 30, 2009, 11:14:37 PM »
wow keep us posted... if u find something  let us know where... are u looking for a standard led or a micro version?
94 ST1100..Gone
