Author Topic: Extra part do not know where from.  (Read 1713 times)
jus750
« on: October 26, 2009, 05:24:10 AM »
Hi im new to this and have a couple of 78 cb750f2 . I am doing a bottom and top rebuild and found a pin on the floor and dont know where its from. any help would be appreciated.
 its 4mm by 6.8mm.
I have looked through the parts catalougue. Its to short to from the gear selector  and i dont think it came from the oil pump is there anywhere else it could be from. i have searched everywhere and am a bit reluctent to put motor fully back together untill i know where its from. Do you have to pull the pump apart to get to the pin. all i did was remove the pump removed the screen and cleaned it.
Re: Extra part do not know where from.
« Reply #1 on: October 26, 2009, 08:27:21 AM »
Never seen one fall out, but make sure the one locating advance plate in the ignition is in place.
jus750
« Reply #2 on: October 26, 2009, 12:29:56 PM »
I will check that when i get home this arvo. This particular motor had frozen pistons and took a little effort to free some parts could of dilodged something. sorry for the no picks. the part looks the same as the rollers on the gear shift drum spindle only shorter.
Offline moham
  • .fnord.
« Reply #3 on: October 26, 2009, 01:58:28 PM »
Locating dowel for clutch cover or some such?
78 750K-The Ocho
74 550-The Cherry Picker
70 750K0 motor-Dick in a Box
Offline mystic_1
  • 1970 CB750K
« Reply #4 on: October 26, 2009, 02:47:06 PM »
4mmx6.8mm sounds like maybe one of the pins that locate the pil pump body onto the oil pump valve body.  Did you separate those while you had the oil pump off?
6.8 is very short indeed.  Very few places on the motor use pins that small.
mystic_1
- John Augustus Shedd
jus750
« Reply #5 on: October 27, 2009, 12:35:44 AM »
left my manuals at work. will be spending a few hours in shed tonight. it seams like clutch cover or oil pump.
thanks everyone. anyone else got any ideas
jus750
« Reply #6 on: October 27, 2009, 01:49:19 AM »
found it. it was a locate for the ignition points i think its the advancer. Manuals are at work so don't know the correct terminology. thanks everyone. the build continues
jus750
« Reply #7 on: October 27, 2009, 03:45:20 AM »
thankyou that was the one your a legend, if it had to fall out it had to be me.
Offline KRONUS0100
  • MAD MATT THE MANIAC
« Reply #8 on: October 27, 2009, 08:53:48 AM »
hey since no one else said it.......you did it right!  extra left over parts are always good...they keep your brain sharp.
MATT
« Reply #9 on: October 27, 2009, 08:09:54 PM »
WHOOOo HOOOOooo......
 I win, I win, I WIN...OOOHHH YEAH!!............ ;D
 Winning aint everything, but losin sure sucks... ;).... ;D
