Author Topic: CB750K 1975 to 1975 swing arm differences?  (Read 2116 times)
Offline vorhese
« on: November 12, 2009, 06:27:16 PM »
I'm about to buy brass bushings for the swing arm
https://www.partsnmore.com/cat_index.php?model=cb750_sohc&category=chassis
What changed from '75 to '76 to require different bushings?
I checked my serial #'s to verify I do have a 1976 CB750K
E: CB750E-2452758
F: CB750-2563351
And while I'm asking, why aren't there any wiring harnesses available for '76 models?
« Last Edit: November 12, 2009, 06:29:20 PM by vorhese »
Re: CB750K 1975 to 1975 swing arm differences?
« Reply #1 on: November 12, 2009, 07:44:07 PM »
The collar is a different diameter on the '76 and "F" and later bikes: it is 0.001" larger diameter on the outer half of each bearing area. The cupped washers between the swingarm tube and the frame changed to have seal around their insides. The internal grease seals disappeared and the two phenolic end caps (also called a "bush" by Honda) disappeared. The bushings became longer by 0.24" and the flange was added to press against the new cup washers in place of the previous phenolic "bush"es. The OEM bushings had one groove in the middle, which matched up with the groove on the baring area of the collar, to attempt to retain some grease in the area. It didn't work real well, though: the earlier version lasted FAR longer.
With those bushings that have the spiral groove inside: they will ingest water from high-pressure car wash spray, so if you use them, keep away from those areas when cleaning the bike.
When I last tried a set of those bushings, I found them to be 0.005" oversize on their OD and 0.035" oversize on the ID. It was like they were made for a Kawasaki, not a Honda. they would not fit...when you go to install them, be sure to check these dimensions first. The press fit should be only about 0.0005" to 0.0010" with this type of bronze. After you press them in, you will find they have mushroomed in the area near the inner edge of the flange, requiring that you either bore or hone them to fit the collar again.  ;)
Offline 750Caferider
  • Crazed Idiot
  • 78 CB750 SS
« Reply #2 on: November 12, 2009, 09:51:30 PM »
Here's a tip buy them from Hondaman...  He is one of the most knowledgeable experts on most all things Honda CB 750.
78 CB 750F (Yoshimi)
Just picked up 3 early to mid 70's 750's Hell Yeah!
And a basketcase 70!!!!
Offline vorhese
« Reply #3 on: November 13, 2009, 06:23:24 AM »
I'm trying to find these, is he selling some some where?
« Reply #4 on: November 13, 2009, 07:36:01 AM »
You are missing the whole point,
 which is;
 To Achieve a good fit, bushings should be installed, THEN FIT to your serviceable inner components..
 Its a bit like buying pistons... yes they can sell you something that MAY fit  without additional work, but for that to happen, you will end up with a loose fit..
Offline mystic_1
  • 1970 CB750K
« Reply #5 on: November 13, 2009, 09:45:02 AM »
He offers a full swingarm rebuild service.  Send him a Personal Message for details:
http://forums.sohc4.net/index.php?action=pm;sa=send;u=2043
mystic_1
- John Augustus Shedd
  • Crazed Idiot
  • 78 CB750 SS
« Reply #6 on: November 13, 2009, 07:08:03 PM »
+1  with mystic_1
« Reply #7 on: November 13, 2009, 09:58:19 PM »
+1  with mystic_1
Hey, Cafe:
I'm going to be out in KC area in December, will see DookieDuke. Maybe we could eyeball each other, too?
  • Crazed Idiot
  • 78 CB750 SS
« Reply #8 on: November 14, 2009, 08:58:29 PM »
Hell yeah!  I'd like nothing more!  I know a ton of great places to eat and get drinks!  I promise I won't ask a million questions about everything...  I'm actually a little giddy right now, I feel like I'm meeting a movie star!
Cheers!
Anders
« Reply #9 on: November 15, 2009, 09:32:19 AM »
Cheers!
Anders
That's embarrassing...I'm just an old #$@!....  ;D
Offline Gordon
  • 750K1, 550K2
« Reply #10 on: November 15, 2009, 09:33:53 AM »
Maybe not a movie star, but he is a TV star! ;D
  • Crazed Idiot
  • 78 CB750 SS
« Reply #11 on: November 15, 2009, 07:39:14 PM »
Sorry Hondaman...  It's just all the cool stories of working on/ racing Hondas that's got me jazzed!  Plus all the free advice that you've given to all of us here on the forum!  You have a wealth of info and wisdom that has but a few peers on the forum!  I still think ya rock!
Anders
« Reply #12 on: November 15, 2009, 08:04:27 PM »
Oh, man, I forgot about that...  :-[
