Author Topic: How much does your CB750 weigh?  (Read 14323 times)
Offline McQueen 750
  • Yeah, I'm finally a
  • Time to ride
« on: October 27, 2009, 12:38:31 PM »
Post the weight and year, and any cool mods you did to get the weight down  ;)
Tip: Put a bathroom scale under the front tire and weigh it. Repeat on back tire and combine weights.
-1975 CB750F (Follow the thread: http://forums.sohc4.net/index.php?topic=88829.msg997640 )
-1978 CB750K8(Parts bike)
"Trust me you'll regret it, but you'll regret it more if you don't at least try it."
Re: How much does your CB750 weigh?
« Reply #1 on: October 27, 2009, 01:26:59 PM »
396lbs, you can see the mods in my avatar. ;)
Sam. ;)
Offline Industrial Cafe
  • Like a well oiled
    • Undead Asphalt
« Reply #2 on: October 27, 2009, 01:43:17 PM »
  210rr
+215ft
  425lbs
I don't know if that's lighter of heavier than stock :D
Offline McQueen 750
  • Time to ride
« Reply #3 on: October 27, 2009, 01:53:43 PM »
Yeah it should be. Stock should be around 475lbs? Good job
Offline BurtonWarpup
« Reply #4 on: October 27, 2009, 01:56:27 PM »
Actually, what I do is check my own weight, then lift my 750 off the ground (remember to bend at the knees) and check our combined weights, and finally I subtract my own.  ;D
Mike
1.5x 1974 CB750K4
2003 Triumph Speedmaster
http://flickr.com/photos/mikepark/
"Now, with a hundred miles on the clock, the rider has nearly forgotten what it means to sit anywhere but on this machine." -Melissa Holbrook Pierson
  • Like a well oiled
    • Undead Asphalt
« Reply #5 on: October 27, 2009, 03:06:01 PM »
I guess I should say what was done.
 I cut off everything that was unnecessary
my seat only weighs 1.5 lbs
aluminum akront wheels
everything that could be drilled has had the piss drilled out of it
air box gone
pass pegs gone
frame ends gone
... I don't know what else.
 it's funny how much weight you can lose off a part when you drill holes in it.
 they all feel like I'm holding a feather.
hey stig sam, why is yours so much lighter?
Offline new2novas
« Reply #6 on: October 27, 2009, 03:10:42 PM »
how much does the motor/trans weigh.....
and IC that is some serious drill time buddy LMAO good job
75 cb750F
Offline the technological J
  • deliciouso!
« Reply #7 on: October 27, 2009, 03:14:12 PM »
crazy thing if u take any motorcycle object and add money it will decrease in weight or get shinier(shinyer? shinneyer?)
94 ST1100..Gone
72 750 K2 Stay tuned!
  • Like a well oiled
    • Undead Asphalt
« Reply #8 on: October 27, 2009, 03:50:21 PM »
"shinier" and that's not money, it's holes. ;D
HOLE
MONEY
see?
« Reply #9 on: October 27, 2009, 03:52:08 PM »
My references put stock weight at 515lbs, likely wet.
The bike in my avatar was weighed on a grain scale at an elevator, pretty accurate as its for commercial purposes at 430lbs.
no fenders, turn signals, stripped harness, aluminum rims, no switchgear, (QA50 buttons and flimsy toggle) fiberglass tank and seat, no sidecovers, no elect start, lightened rotor. but I did add the disc.
« Last Edit: October 27, 2009, 04:20:29 PM by MCRider »
« Reply #10 on: October 27, 2009, 03:52:50 PM »
air box gone
pass pegs gone
frame ends gone
IC, Aluminum oil and gas tank, narrower rear rim, lightened crank, no lighting system, no generator and that gearbox cover that you drilled 87 holes in has been removed alltogether, also no kick start shaft and cranker.
All surplus brackets off the frame and top TTT.
I could have made it lighter but Chris wanted twin discs and fairing. ::) ::) ::)
Sam. ;)
  • deliciouso!
« Reply #11 on: October 27, 2009, 04:13:14 PM »
i was talking about sams bike if i remember right he said in another thread what it was worth and there was alot of money added and its lighter
94 ST1100..Gone
« Reply #12 on: October 27, 2009, 04:21:29 PM »
and faster :D :D :D :D :D :D
  • Like a well oiled
    • Undead Asphalt
« Reply #13 on: October 27, 2009, 04:30:57 PM »
             I really just added that for the funny.
I think the motor is 180-200lbs, but don't quote me on that
  • deliciouso!
« Reply #14 on: October 27, 2009, 04:44:16 PM »
in this condition does it compete with a newer sport bike or is it still a dinosaur?
94 ST1100..Gone
« Reply #15 on: October 27, 2009, 04:51:09 PM »
Using a CBR600 as baseline, most midsize sportbikes are sub 400lbs in street trim with LOTS more dependable horsepower.
http://en.wikipedia.org/wiki/Honda_CBR600RR
Easy to make them sub 350lbs with even more horsepower. It took a while, but since 1995 or so, its a pipe dream to think we can make a 70s era bike competitive with even a fully street legal avg modern sportbike.
Still we love our CBs.
  • Like a well oiled
    • Undead Asphalt
« Reply #16 on: October 27, 2009, 05:00:06 PM »
my quote at the bottom says it all for me.
« Reply #17 on: October 27, 2009, 05:05:19 PM »
Gab and Mcr, I never got to ride the bike after the motor was reworked so it's hard to say.
I dont think it would match an up to date 600 off the mark but it wouldn't be a long way behind on top speed.
Chris was a big guy, about 100lb heavier than me and I think his best time over the 1/8 mile was an 8.2 secs. I managed a 7.8 on a CBR600F3 after just 4 passes at Piedmont NC last year. Looking at it that way, I'd say with a lighter rider, it would be a match for the 600s of the early 90s.
Sam. ;)
Online mec
« Reply #18 on: October 28, 2009, 01:20:32 AM »
Sam. ;)
and oil pump removed also?  ??? ???
the oil pump is driven by the gear on the kick starter shaft.
mec
Honda Monkey
Takeuchi TB 070
Massey Ferguson
  • Like a well oiled
    • Undead Asphalt
« Reply #19 on: October 28, 2009, 06:06:06 AM »
I've seen people remove the kicker and shaft, they cap off the hole.
 I've always wondered what they do...
« Reply #20 on: October 28, 2009, 06:26:59 AM »
As MEC says, the oilpump drive gear spins on the kickstarter shaft. So some allowance must be made. You can cut the end off the shaft flush with the cover, but something must remain as there is an oil seal there. A plug would work but still what about the gear?
Interested to hear what Sam says.
  • Like a well oiled
    • Undead Asphalt
« Reply #21 on: October 28, 2009, 02:58:16 PM »
I'm glad you said (ISDE rider) cause I was thinking this guy.
« Reply #22 on: October 28, 2009, 03:15:30 PM »
Sam. ;)
mec
Yes, it was only the end of the shaft and the kick leaver.
Sam. ;)
