original project thread:
http://forums.sohc4.net/index.php?topic=52010.msg559634#msg559634the bike as of now:
![](http://i18.photobucket.com/albums/b115/johnspeck/luckenbach%20oct%2009/IMG_1789.jpg)
![](http://i18.photobucket.com/albums/b115/johnspeck/luckenbach%20oct%2009/IMG_1790.jpg)
quick recap of work done so far:
engine top-end rebuild
>honed cylinders/new rings/gaskets
>valve job
>new cam-chain tensioner assembly
stainless fasteners on engine
rick's stator/rectifier-regulator
hondaman ignition/NOS points plate assembly
mikuni vm30's/k&n filters
shorty reverse megaphone mufflers (with re-wrapped baffling)
tapered steering bearings
hagon shocks
avon roadriders
new chain
15 wt. fork oil
euro handlebars
new bump-style seat foam/cover on stock pan
fender undersides cleaned/painted
lucas-type tail light
the engine is in great shape, around 5k miles before the top-end refresh. really good compression, and i've got the carbs jetted pretty close to right.
with the addition of the new seat shape, i've been seeing the lines of the bike slightly different. i was initially thinking of ducati monster bars, or cb400f bars (lower than my euro bar rise, but not a drag bar profile).
just to see what it would look like, i took my bars off yesterday, and flipped them upside down. i actually like this look and feel, compared to a brand-new set of clubmans i have sitting in the garage. the upside-down euro bars don't put your hands as far forward, clear the tank, and give it a bit of a boardtracker vibe. i'm pretty critical aesthetically, and they don't look as goofy as stock high-rise bars flipped upside down, at least not as bad as i'd imagined.
here are some pics of the bars test-mounted:
(please ignore the messy garage floor, i've been busy)
![](http://i18.photobucket.com/albums/b115/johnspeck/yamaha%20and%20other%20motorcycle%20stuff/IMG_1820.jpg)
(the flash lets you see the bars better)
![](http://i18.photobucket.com/albums/b115/johnspeck/yamaha%20and%20other%20motorcycle%20stuff/IMG_1822.jpg)
![](http://i18.photobucket.com/albums/b115/johnspeck/yamaha%20and%20other%20motorcycle%20stuff/IMG_1823.jpg)
what do you think? i can adjust them to approximate clubmans, or to reach up and back a little more (like i have them in the pics).
this ties into the next step. one of my fave bikes of all-time is the cb400f. i love the styling and the way the bike rides. i especially like the positioning of the footpegs. they sit right around the swingarm pivot point. they're a little further back compared to the stock position on my pegs, same relative height, but not as far back as rearsets (using the passenger peg locations).
i work for a small steel fab shop (with a gearhead boss), so i can easily cut and weld in extensions to the stock pegs that would look almost factory and locate them at the swingarm. i've thought the process through and bounced ideas off my boss. by extending the stock peg brackets back around 3 inches, i utilize all the stock linkage. all i have to do is shorten the gearshift lever and weld on a new tip, and the brake lever can be heated and bent back and up a bit, then cut and weld the end back on. it's subtle enough that the brake should still have good leverage, as it's pretty easy to lock up.
the next step is the front end. i like the stripped down look, so i'll be removing the fork covers, rebuilding the front end with straight-rate springs and possibly emulators if i can fit them. i'll fab headlight mounts and put some gaitors over the springs (although the exposed springs look pretty cool). i'm actually thinking about a combination headlight mount/tach mount bracket. i made a small bracket to center the tach, but i think i can clean up the levers and controls eventually, so i could incorporate a few switches into the bracket as well and look really trick in the process.
i'll finish up test-mounting the bars today. i don't want to drill the bars again for the other side, so i'm modding the housings to run the wiring outside. a travesty if they were mint, but they weren't, and i'll be rewiring the bike to reduce/relocate most of the bar controls.
i don't have turn signals, i can locate a horn switch on the left bar standalone and just mount an MX style lever. the run/kill switch can be located on the tach bracket i'm designing, as well as a three-way light switch (off/on/hi). i could mount a starter button standalone on the right side to match the horn button, or make it stealthy.
i'm relocating a smaller horn. also thinking of mounting the ignition up there between the bars somewhere.
whew! a lot of stuff, but i'm feeling pretty inspired by all the cool bikes at a show this past weekend, and i've got the tools and capabilities to get it done for relatively low $$$ (free steel stock, free help from the boss for any welding stuff i can't handle, use of the shop), plus i have a lot more tools since i started the work on this bike when i got it this spring. i'll be carefully cleaning up any welds, painting and making it look as 'factory' as possible.
more pics as i progress...
