Author Topic: TACH CABLE ISSUE  (Read 582 times)
Offline fletcha221
  • CENDSE BIKEWORKS
  • Cendse Bikeworks
    • OUR SHOP
TACH CABLE ISSUE
« on: October 29, 2009, 07:46:12 AM »
Guys,
One huge Snafu on the cb350f cafe build came when I could not get the tach cable out of the rockerbox. I ended up just cutting the cable at the input housing, allowing it to simply sit there and spin. I was going to drill the Phillips screw out, but I was concerned with messing up the threads in the rockerbox. I have had no intention of putting a tach on the bike at the time, but I'm thinking it might be a good Idea if I plan on winding this little guy out. If I leave it as is, can it lead to any damage down the line? If I remove it and decide to not replace the cable, will it leak oil? Any ideas?
"Consistency is the last refuge of the unimaginative" -Oscar Wilde
1973 CB350f
1975 CB550k
1975 CB750 K5
Offline CBGhia
Re: TACH CABLE ISSUE
« Reply #1 on: October 29, 2009, 08:53:17 AM »
You can leave it for now and it should be fine.  might be able to get that screw out with an impact driver or a small pair of vise grips.
