Author Topic: Is there a quicker throttle for the 550?  (Read 7771 times)
Offline westondc
  • Wes Mantooth
Re: Is there a quicker throttle for the 550?
« Reply #25 on: November 05, 2009, 08:17:30 AM »
my bike came with touring style grips on it. they're wider than stock and the throttle grip has a large lip on it that the palm of my hand can rest on for leverage. it works great. i can push on the lip area with my thumb for full throttle without repositioning my hand. also helps with overcomming return from the throttle spring. this type of grip might help you and with little modification. cant seem to find a good example of this style grip on the internet.
B.O.X.N.I.F.E. Hospital fund https://www.everribbon.com/ribbon/view/8352
Rider no. 115 on the 2012 SOHC/4 Honda World Tour
Rider no. 274 on the 2011 SOHC/4 Honda World Tour
1972 Honda CB500k1
1971 Honda CB350k3
the project http://forums.sohc4.net/index.php?topic=64499.0
Trip/Project Blog http://easterntowestern.blogspot.com/
just be a vagabond, living out of a backpack on a little Honda, cruisin all over the damn place....
"As your attorney, I advise you to buy a motorcycle. How else can we cover a thing like this righteously?"
Offline JS550
  • the artist formerly known as
  • IAFF local 1307
« Reply #26 on: November 05, 2009, 08:25:15 AM »
This is what I did on my project bike:
I had my Dad make up a little cam to slide over the throttle tube to quicken up the ratio of the twist a little bit.
I had to do just a little bit of clearance-ing out of the housing for the cam to fit.
I was going to measure the amount of the twist before I put it in, but I forgot. It does twist a lot less now, though. It has about the same amount of twist as my Ducati does.
did you have to glue the spacer on or is it just resting there? i'm going to try that on my k4, not so much for the fatser throttle but anything i can do to reduce the distance i have to turn the throttle to WFO is a good thing
I am so going to do this today! Great idea. I did the wire in the cam groove, but it didnt seem to do much.
thanks,jim
If you're worried about how many calories are in beer, is losing weight really your biggest problem?
« Reply #27 on: November 05, 2009, 08:32:49 AM »
SNIP
crap!  :'(
 ;D
Nice thing about the Commando Rapido is it hooks into the original switch gear, It sounds like Hondaman was installing it or something similar by sliding the switchgear in a little, drilling a new locating hole, then install the throttle. it looks like stock.
Offline turboguzzi
« Reply #28 on: November 05, 2009, 10:16:02 AM »
Oh yeah, Takuro, does it have changeable pulleys?
 take that!
