I have a 1975 CB550 that I've just bored out to 605cc, using a NOS overbore kit (bigger pistons, bored out sleeves, oversize head gasket, etc.). I also installed all new valves, guides and springs, with a machine shop performing the boring and honing of the cylinder and all valve machine work, including installing the guides.
This weekend, when I finally got it all back together and started it up (after more than 2 years disassembled!), it started spitting out massive quantities of whitish smoke -- pretty obviously well-burned oil. Since I had poured a little oil over each piston prior to assembly, I figured it would burn off after a few minutes. But it did not. In fact, it filled my neighborhood with noxious smoke.
I coasted it down the hill to a wider, less populated street and started it back up. Let it run for 20 minutes. Still churned out the same amount of smoke with no signs of letting up. And it appears to be coming from all four cylinders more or less equally.
When I got it back home, I checked the oil. Dipstick was bone dry, though I had refilled the crankcase after reassembly.
So, I ran a compression check. All four cylinders are strong, about 160 psi.
I've done a lot of work on this bike over the last 5 years, but am still really a noob, so I'm having trouble figuring out what went wrong. Here's my best guess.
When reassembling the engine, I had eight extra o-rings from my gasket set. I could not figure out where they belonged, so I studied the parts list and found eight o-rings that appear to go between the valve guides and the head. Since the guides were already installed -- I had no means of pulling them and reinstalling to check -- I just assumed that the machine shop installed their own o-rings.
Could that be the cause of this oil leak into the cylinders?
I'm guessing the oil has to be coming in from above and not past the rings, since compression is strong and the volume of burning oil is tremendous -- almost a quart in less than 30 minutes of running. I know there are oil seals around each valve stem -- I installed those myself. But if those o-rings are missing between the guides and the head, could a large volume of oil be draining down into the chambers that way? I'm pretty sure I did not miss any other o-rings or gaskets (I had a much more skilled friend checking my work during the reassemble).
Is there any way to verify the source of the oil leak without pulling the head?
Any input is greatly appreciated. It took me two years to find the money and time to complete this project. I'm at a loss here.
