ok, i'll try to answer a bit of this... i need to get the bike back on the stand and do some analysis, which will take me a couple days to find the time for.
Don't confuse primary resistance with secondary resistance. They are isolated from each other.
yes, this makes sense. i just wasn't thinking it through.
I really don't know much about how the dyna 2000 operates. So, I can't guess the duration the coil current exists per revolution. This is the dwell spec., (which is 195 degrees of crank rotation for the points system) and determines how much total draw the coils/ignition has on the battery.
All the current draws headlight coils etc. will lower the battery voltage during start operations. But, since I have no way of knowing what the dwell is for the dyna 2000, I can't estimate the Vdrop, or what effect, if any it has on the ignition.
I'm kind of surprised that the Dyna 2000 system doesn't specify a larger gap at the spark plugs. If it is a coil discharge based system (Kettering), you won't realize any benefit of higher voltage potential without a larger spark gap.
I have none of the dyna 2000 specs other than what was provided with the kit, but your comments provoke me to want to call them for more specs and a chat about these points. I'll look back through the literature, but I don't believe they specified a larger gap, though it does make sense. I estimated mine above, and are probably actually just under .030".
[/quote]
As for the secondary, you really should have some resistance in either the spark lead, the plug cap or the spark plug itself.
again, I just installed the kit the way it came, wires included. The dyna kits come with 2 wires, the plug ends made up already, and when you cut them in half, you make up the coil ends. The 2000 kits come with suppression core wires.
Does the dyna power pulse the coils for the spark event, or does in discharge the coils for the spark event? The stock points system and the Dyna S both discharge the coils for spark.
If it works like other systems, then the coil discharge collapse will still build until the spark leaps the gap, (whatever voltage it needs) the secondary resistance will slow the coil discharge current, and delay the drain time, creating a longer spark event duration. This should allow a longer time to ignite a mixture and the atmosphere near the leaping spark should get hotter during cold start, making it more likely to ignite an less than ideal mixture.
As far as I know, it is a discharge system. I feel like if it was a pulse-fire system, dyna would advertise this loudly. I could be wrong though.
What wattage headlight are you using?
Can you remove a headlight fuse easily for starting?
What is your battery rating/type?
the headlight is a stock honda lamp, 30/50 i believe. I'll have to check to be sure. I did try starting with it disconnected today with no better results.
Any schematics or theory of operation available for the dyna 2000?
I'll attempt to contact them tomorrow for more information, and look for the literature that came with it.
The 750 PD carbs have a spring loaded door in the choke plates to relieve some of the vacuum when the plates are fully closed. They also have a hole in them where the accell pump squirters shoot through. Are the choke plates on your carbs solid?
my carbs are not PD carbs. I'll look at the stamping tomorrow, but it doesn't really matter... they're K1-6/ F1 CB750 carbs. jetting does not match up with a particular year within that range.
If you don't have run issues when the engine is warm, I still don't think you should mess with the inlet restriction, just to make it start easier.
I agree, and this was my initial thought. like i said, the dyno was happy with my carb settings warm. I can't help but suspect weak ignition. when it does fire, it just catches and is suddenly strong.
What position do you hold throttle for start up? The more closed the slides are, the deeper the vacuum seen at the pilot circuit outlet. Of course that also leaves the throttle valve at minimum opening for fuel delivery. But, if you have a low vacuum condition when the slides are open, the jets aren't going to flow fuel regardless. If you have little inlet restriction, holding the throttle open will reduce the throat vacuum and fuel flow accordingly.
you know, even warm the throttle position is a little tricky on startup. usually if i let someone else ride it, they'll fumble with the start, and i'll hop on and fire it up first kick. i usually pull the throttle cable taut, and then just lightly open it as i'm kicking it through.
sometimes it just feels like i can't kick it through enough with one stroke of the kickstarter. I love how on my BSA, if the kickstarter is at the top of a compression stroke it feels like you're really spinning the engine fast. the 550 feels like the 1st gear kickstart ratio just isn't tall enough. at least on mine anyway...
