Author Topic: '69 350 Scrambler in the works...  (Read 32279 times)
Offline Hush
Re: '69 350 Scrambler in the works...
« Reply #100 on: January 03, 2010, 12:19:30 PM »
Typical girl behaviour, get a bike and wash it, guys we just wanna ride it dirty or not. ;D
One thing Mickey, were you kidding when you said you didn't know how to set twin points?
It's hard to tell irony using this media, just sing-out if you need direction on that as your Harley and Kit's 650 would be all electronic ignition and I've had a brush-up on my twin points setting since the Jaffacycle arrived.  :)
Offline MickeyX
« Reply #101 on: January 03, 2010, 01:25:48 PM »
paulages gave a pretty good description on here. but no, I've never dealt with points before so I will probably end up taking over to paul and the guys anyway the 1st time. I'd hate to mess something up.
Offline Hush
« Reply #102 on: January 04, 2010, 01:54:25 AM »
Pretty basic and once you get shown you will never forget the basics behind setting them.
Offline MickeyX
« Reply #103 on: January 04, 2010, 08:05:50 PM »
Yeah, I figure I can find an infinite amount of ways to do it wrong on my own or I can get shown the right way the first time.  ;D
I wish I had more time this week to work on it but there's just too much real world going on yet. Maybe this weekend I can get the carbs back in, change the oil, put the ignition back in, fix the wiring to the points and get it kicked over. The nice thing is, the spare CB650 came with a decent battery and it just so happens to be the same size.  8) It's a good thing we've kept it on the trickle charger.
Offline MickeyX
« Reply #104 on: January 16, 2010, 10:29:50 PM »
So the carbs are clean, kits are done and the bolts were replaced with stainless allen head ones. Kit was nice enough to put my carbs in and the air filters while I was at work last night.  8)
So, walking through the salvage place today, Kit spotted a float for my bike. Only one in the entire box like the kind I needed and she sees it.  8) I can't fit the round ones, I need the luggage style kind. Now I have one to replace the imploded one. Of course, she put the carbs and air filters back into the bike last night. I just wish she remembered which one it is in. ::) I think I can get at it while on there and replace it but I have a feeling I'll end up pulling the whole thing back off.
The tires thing is getting on my nerves. I'm supposed to have 3.00 up front and 3.50 in the rear. There aren't many kinds out there in those sizes. I'm not putting my butt on the line with a pair of cheng shins.
Other than that, we ended up buying a few things for her bike instead like a brake lever and some nice turn signals. Kit's turn signal lights are mine now.  ;D Of course, somewhere along the line, someone decided to cut the wiring, then twist them back together with a little electrical tape nearby, then cut them at a 2nd place, then twist them back together... I've got them in the apartment to take them apart and see what I can do to get one continuous wire to the plug. I need to check if they are corroded inside anyway. I also have the switch pods from her handlebars up here too. She bought "M" bars and I'm trying to figure out if I can make a hole on the side of the pods to let the wires out the side somewhere or if I'm going to have to drill her new bars and run them inside. Looking at it, I think it might actually be easier to run them inside and it would be cleaner looking too.
Off to bed. I have a lot to do while she is at work tomorrow.  :P
« Last Edit: January 16, 2010, 10:33:18 PM by MickeyX »
Offline paulages
  • 1976 cb735
    • DOOMTOWN RIDERS P.R.M.C.
« Reply #105 on: January 17, 2010, 10:28:35 AM »
you'll be alright accessing the float bowl if you haven't installed the pipes already. this makes it very difficult on the left side. also, you can rotate the carb a little so that the screws point toward you a little bit.
paul
SOHC4 member #1050
1974 CB550 (735cc)
1976 CB550 (590cc) road racer
1973 CB750K3
1972 NORTON Commando Combat
1996 KLX650 R
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
    • Playground Directory
« Reply #106 on: January 17, 2010, 07:24:42 PM »
Tires were an issue when it came time for me as well.    I ended up with a rear "DURO" 350 x 18 and a Cheng/ 300-19
They work well both for street cornering, "never let go yet" and for gravel or dirt applications.  I don't go into the forest with it.........once again, good luck with the project ;D
Offline 78whiteorbs
« Reply #107 on: January 19, 2010, 02:19:36 PM »
seaweb, you have my dream bike . Would like it in a 450 though but a 350 , I'd do !!!   One has cooler pipe ends that the other . I forget which is which , one has the boxy looking tip and the other has the double barrel. I keep seeing 175cc's around here :(   nothing bigger.
The pipes are just too dang cool! and the flipped down guages i dig too!
Mickey , how bout some full side view shots?
Offline Frankenkit
  • Industrial Strength
« Reply #108 on: January 19, 2010, 02:53:43 PM »
the 69s have the box tip and the 71 on have the double barrel, I think.
2012 CBR250R "Black Betty"
1980 CB650c- (sold) Delilah
1973 CL350- Lola?
Stuff for sale
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
« Reply #109 on: January 19, 2010, 03:40:38 PM »
Mine is a 72. I bought 4 sets of pipes on eBay before I was able to put together one good set.
Fun bikes for sure  ;)
Offline 78whiteorbs
« Reply #110 on: January 19, 2010, 04:36:50 PM »
that 72' has the round holes in the exhaust that I favor greatly over the cl450 slashes. I wonder if those pipes would fit a 450....Those bikes rarely pop up or so I am told though.
Offline MickeyX
« Reply #111 on: January 20, 2010, 11:15:14 AM »
I went through my pics and I only have the one from the left.  ???
I won't have time to work on it till the weekend. It's too hard to get at with 5 bikes in the single car garage now. We put the 650 and the HD towards the door so we can ride those regularly and back them out of the way to work on the 350s easier. Can't do it with them all in there. Kit's is closer to being done than mine since hers is in better shape overall and she ordered more parts than I did. We'll get hers running 1st I think and then go back to mine. This may take a while. We can only work 1 into the budget at a time as far as parts. It looks like hers is it. I don't mind. It takes time to end up with a nice bike and we are doubly blessed right now. I'm just going to tinker with my wiring and the things I have stuff for until I can scratch up the loot for all new cables and the tires. We'll probably get tires together to save on shipping so that's our next big splurge on the bikes.
I can't wait to ride this thing though. It feels so light compared to the other bikes. It'll be a good bike to take to work and just zoom around in town.
I want to know what people did about sidebags for these? If anything? I could hang one off the right, I guess. Maybe get a rack and put a duffle on the back?
Offline bill440cars
  • Feeling More & More,
  • Tryin' To Slow Down "Time"!
« Reply #112 on: January 20, 2010, 03:18:29 PM »
  Yeah, the rack and duffle on it, sounds like it might be the way to go Mickey. Just an opinion here. ;)
Member # 1969
Offline paulages
  • 1976 cb735
« Reply #113 on: January 21, 2010, 01:54:30 AM »
i can't tell you how many i have taken racks off of... i don't think i have any more. think they went out at the windjammer fairing "sale" we had a couple years ago.  ::) they're out there though.
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
Offline MickeyX
« Reply #114 on: February 06, 2010, 02:08:04 AM »
I wonder if this would work for my cross over fuel line? I'm thinking that I could put 2 of them in, with a short bit of line between. Then I could shut them both off and disconnect without having to empty the tank if I need to remove it. They are meant for fuel line.
I was looking for something in nylon too.
Offline bill440cars
« Reply #115 on: February 06, 2010, 07:30:07 AM »
       Sure, that should work, but wuill take some space to put that setup in there though. Somewhere, I saw some "disconnects" that would seal off, when disconnected. I can't remember where I saw them. Maybe Dennis Kirk has them, I'm not sure. Be worth a look though. that setup would be more compact too. If you, or no one else finds them online, before I get back this afternoon, I'll see what I can dig up. IF you'd like? ;)
Member # 1969
Offline MickeyX
« Reply #116 on: February 06, 2010, 02:02:55 PM »
There is one on feebay but they want almost $50 for it.  :o It's hard to tell if they just disconnect or if they also close when you disconnect. I don't mind popping the line off of the tank to take it off I just don't want to have to empty the tank everytime to do it. If you find something, let me know. Briggs and Stratton make all kinds of connectors so I'm going to check out their line tonight when I have more time.
thanks Bill!  :)
Offline bill440cars
« Reply #117 on: February 06, 2010, 05:03:32 PM »
thanks Bill!  :)
           Oops, sorry. I had forgotten about what I had told you earlier today and was reading your thread, when I realized that I was supposed to find and post info on the disconnects. So, without further delay, Check this out and see what you think> Both ends seal off, when disconnected.
           http://www.denniskirk.com/jsp/product_catalog/Product.jsp?skuId=180693&store=Main&catId=&productId=p180691&leafCatId=&mmyId=
Your Price: $27.99 Price might seem a bit much, but it's compact and would fit in there alot easier.
« Last Edit: February 06, 2010, 05:10:40 PM by bill440cars »
Member # 1969
Offline mystic_1
  • 1970 CB750K
« Reply #118 on: February 06, 2010, 05:15:27 PM »
Was just about to post that same item, Bill.  We used that on the wife's 350, worked great.
Short line from each crossover spigot, with the valve in the middle.
http://www.motionpro.com/motorcycle/partno/12-0037/
mystic_1
- John Augustus Shedd
Offline bill440cars
« Reply #119 on: February 06, 2010, 05:18:37 PM »
mystic_1
  hey, that's cool. After all, we ARE working towards the same goal. Helping out as we can, right? ;)
Member # 1969
Offline MickeyX
« Reply #120 on: February 06, 2010, 08:00:24 PM »
Heh, you guys are great. That is the same one is saw being sold on feebay by Sirius for $49 + $9.50 s/h. Only thing is, they are very careful about not mentioning what brand it is so you can't find it somewhere else.
So, now.... do I need the 1/4 or the 5/16? I'm thinking 1/4.
I'll end up buying 2 of them so Kit has one too and both for about the same price as buying one from Sirius. Thanks guys!!  ;) ;D
Offline mystic_1
  • 1970 CB750K
« Reply #121 on: February 07, 2010, 08:10:13 AM »
1/4 in should do it.
If you get a spare one, you can rig up some line an extra end on it, then use it to either drain the tank or to transfer it to your buddies tank when they run out of fuel.
mystic_1
Online CycleRanger
  • No comment about being an
« Reply #122 on: February 07, 2010, 08:34:03 AM »
mystic_1
Interesting. I use these same quick-disconnects at work for high-pressure (40~70psi) air.
Offline MickeyX
« Reply #123 on: February 07, 2010, 12:15:29 PM »
Well, I finally have time to "works" my tank for a few hours. I'm going to do the green SS tank like this. I have to figure out what to use to plug up the holes while I do this. I'm thinking if I can get hoses to fit the crossover and the petcock and then screw in bolt to plug up the hose?? Anyone have other ways to do this? I need something that can handle the toilet cleaner for two hours or more and not disintegrate. I may just take the whole tank to the hardware store for ideas from the guys there too.
I should have time to start the molasses treatment on the blue tank too. I had to wait for it to get a little warmer out. That stuff got really thick. I'm just gonna take off the petcock and crossover tubes, put it in a big rubbermade tub and let it go for a month or so. It has a little rust on the outside too. around the seams so that is why I'm dunking it instead of "works". I'm so glad it is reliably in the 50s now.
I'm curious how they come out compared to each other.
Offline TomC
« Reply #124 on: February 07, 2010, 02:38:44 PM »
Hi MickeyX
     On my CB350 twin tank I put a rubber "cork" from Handy Man in the petcock hole. There are in those boxes above the nuts and bolts. I used a section of hose connecting cross over. But two short sections with screws should work just fine.
     TomC in Ohio What are the 50's?
TomC in Ohio
76 CB750 F1 Daily Rider
76 CB550 stalled project
76 CB400F Injured Reserve
