Author Topic: perfect tool for cleaning slow jets  (Read 5050 times)
Offline paulages
  • 1976 cb735
    • DOOMTOWN RIDERS P.R.M.C.
« on: December 19, 2005, 11:42:11 AM »
after trying everything from the often-advised single wire copper strands to drill bits that never quite go small enough, i found something sturdy that will pass through even a #35 slow jet: a single tattoo needle (#12). good luck finding a tattooist who will kick down a few loose needles, but if you can find 'em, they work great.
paul
SOHC4 member #1050
1974 CB550 (735cc)
1976 CB550 (590cc) road racer
1973 CB750K3
1972 NORTON Commando Combat
1996 KLX650 R
Offline ohiocaferacer
  • www.OHIOCAFERACERS.com
    • OHIO CAFE RACERS
Re: perfect tool for cleaning slow jets
« Reply #1 on: December 19, 2005, 11:46:26 AM »
A welding tip cleaner set works great also. You can purchase them at any welding supply store.
Offline Lumbee
    • My pics...
« Reply #2 on: December 19, 2005, 12:05:35 PM »
http://www.crc2onlinecatalog.com/tools.htm
...scroll down a bit...I think this is the same welder tip cleaning tool mentioned above...
"I'm not a welder, but I play one on HondaChopper.com"
Offline mcpuffett
« Reply #3 on: December 19, 2005, 12:33:26 PM »
also the wire out of sandwich bag ties work ( uk guys will know what i mean) ;)  mick.
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #4 on: December 19, 2005, 01:33:42 PM »
These like the wire in what we call twist ties here? If so, that's what I used. They are thin enough, after stripping the paper off, and quite soft so they do no damage.
Offline paulages
  • 1976 cb735
« Reply #5 on: December 19, 2005, 01:34:49 PM »
the problem i've had with the sandwich tie wire or anything similar, is that it's too flexible. tattoo needles are stainless and rigid enough to poke through some serious crud. i never found a welding tip cleaner or jet drill kit that had parts small enough for a #35 jet, when i was looking, and i bought two different kits. i did find a carb cleaning wire set, but the small wires just bend up and become useless..
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
Offline Kevin D
  • SE Michigan
« Reply #6 on: December 19, 2005, 02:53:52 PM »
I use old guitar strings. I learned that trick here. If you dont have old ones, you can buy individuals for about a buck, .009, .010, .011, .012, whatever size you want.
71 CB750 K1
104,000 miles
Original Owner
———past———
70 SL100/125/150
70 Candy BlueGreen CB 750 K0
Offline paulages
  • 1976 cb735
« Reply #7 on: December 19, 2005, 03:55:52 PM »
yeah, that's what i used as replacements for the small wires in the set i bought unti i discovered the tattoo needle trick.
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
« Reply #8 on: December 19, 2005, 04:00:28 PM »
A ballpoint pen spring works as well, but a good trick is to hold the jet in a pair of pliers and heat it with a propane torch. It usually turns the crud to ash and is easily cleaned. Sometimes you need to soak a while first then heat. These jets are so tiny and the difference of a thou by forcing something through brass isn't good.
Offline cb650
« Reply #9 on: December 19, 2005, 04:01:47 PM »
We used to have these but know we get some plastic POS.    Must have had to many fn  lawers pokin their eyes out with the wire.
                  Terry
Objectionableone
« Reply #10 on: December 19, 2005, 04:19:21 PM »
Interesting thread to me.  I usually just follow the three C's (my term) for carb cleaning in this order:
1. Chem dip
2. Compressed Air
3. Carb Cleaner
Offline Jonesy
  • Shop Rat
« Reply #11 on: December 19, 2005, 05:48:23 PM »
Honda makes a set of jet cleaners sized by the jet number. This way, you don't have to worry about accidentally enlarging the jet. I prefer these over the welding tip cleaners, as the tip cleaners have serrated portions that can damage the calibrated orifices in the jets. The Honda Part # is 07JPZ-001010B. Any dealer should be able to get them.
Offline scott_cb650
« Reply #12 on: December 20, 2005, 07:27:39 AM »
Wires from a wire brush work well.
stiff and strong
Why worry about tomorrow for tomorrow has enough troubles of it's own.
corbinsa
« Reply #13 on: December 20, 2005, 03:34:15 PM »
A note about wires being to flexible: My mechanic showed me a good trick. Take the wire from a wire brush, put it in your drill chuck, and drill the sucker down in there, worked like a charm on my plugged jets.
Steve
« Reply #14 on: December 20, 2005, 05:04:21 PM »
It's a good trick for him 'cause it's fast.  And, he can get paid for more jobs that way.  It's a bad trick for your bike 'cause it probably changed some of the jet orifice dimensions.  The jets are made of pretty soft metal.  Chucking steel into them is bound to leave some scratches that effect the flow at some given velocity.
Good luck!
Offline Lumbee
    • My pics...
« Reply #15 on: December 20, 2005, 06:32:39 PM »
...used the wire from a brush technique tonight...I have to say it works...not sure about a the drill thing though...where do u find a chuck that small? ???
corbinsa
« Reply #16 on: December 21, 2005, 10:00:17 AM »
The chuck on my craftsman 18V goes down that small. i didn't drill it in there high speed or anything. the wire was just not stiff enough to do it with my fingers, so i put it in the drill chuck, spun it slow and it went through.
A note about my mechanic. I've known him my whole life, grew up down the street from him, was friends with his kids, and he's been wrenching old metrics for longer than i've been around. Maybe I changed the flow of the jets, but probably not enough to really matter to me. i'm just working on a cheap wintertime project.
Steve
nibenon
« Reply #17 on: July 11, 2012, 09:47:36 AM »
Dragging up an old thread here.
Bristle from brass brush did the job perfectly. Twisted it a bit by hand to poke through the crud.  :D
Offline lucky
« Reply #18 on: July 11, 2012, 11:11:42 AM »
NEVER use a welding tip cleaner.
Look at the tool closely the wire is made like a small round file.
You do not want to FILE on a jet!
The #35 jet is only .013 thousandths.
A #10 guitar string is .010 thousandths.
Even the smallest wire on a welding tip cleaner may not be small enough.
Remember you do not want to FILE the jets just push the crud out.
Offline lucky
« Reply #19 on: July 11, 2012, 11:15:16 AM »
That is what should be sold at the counter of every motorcycle store.
We do not need anymore keychains and other FLUFF.
Offline Old Scrambler
« Reply #20 on: July 11, 2012, 12:00:50 PM »
Lucky...........you are soooooooooooo right ;)
I have used the welding-tip cleaners for years but stay away from the burled wire.  If I can't easily poke a wire through the jet, I take the entire carb or rack to my local shop for a 'sonic' cleaning.
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
Offline DJ_AX
« Reply #21 on: July 11, 2012, 12:24:02 PM »
+1 .. I always have some old ones laying around.. I got a few of the sizes cut 'em down and tied/taped the ends... and added the new tool to my box. :)
And +1 on the drill thing being a bad hack! That's asking for trouble.
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #22 on: July 11, 2012, 12:56:52 PM »
Doesn't have to be Honda brand. This is the best tool I've got for cleaning carbs and not just Honda motorcycle carbs either:
http://www.amazon.com/Carb-Cleaner-Wire-Set/dp/B001DDMB2I
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
