Author Topic: What did you do to your bike today ?  (Read 3249780 times)
0 Members and 7 Guests are viewing this topic.
Offline fastbroshi
  • Puppet
« Reply #10150 on: May 01, 2012, 06:30:20 PM »
Replaced the stocker clutch with an EBC version.  Weird, I measured the originals and they were almost brand new.  I think I glazed them over on the trip to Barbers last year.   Gotta go get some oil to top it up, I only had a half quart on hand?
Just call me Timmaaaaay!!!
Offline hoodellyhoo
  • CB350F
« Reply #10151 on: May 01, 2012, 06:58:30 PM »
took the grab bar off the 350. I've been taking a basic welding course at school and I want to see if I can finally fix my broken blinker mount.
« Reply #10152 on: May 01, 2012, 09:23:15 PM »
I'm gonna be boring - no pix tonight.
I installed the Dyna 2000 main unit and pick ups. Went to the Honda dealer to listen to them #$%* about my Honda brand parts ordered vs their generic stuff and put them through another hassle by checking off MY list and asking them to cross reference superceded part numbers so I'd know what they are giving me vs what I paid for online. What the hell do they get paid for?! I reminded them it's a good thing I mostly order online and save them that little detail.
Got home and finished up 4 or 5 things that I needed those parts for then started on my rear brake system. That damned rear sprocket is another 2 weeks out so I've decided to mock it with my existing sprocket to make some progress. Next up - build the rear caliper and install then put on the fargin rear wheel, chain, chain guard and CR31's plus the Kerker then it's FLUIDS TIME! I'm thinking those 2 more weeks I'll wait for the rear sprocket should give me just the right amount of time to polish off all the little BS and turn it into a bike again ;D
« Last Edit: May 01, 2012, 09:27:27 PM by Jerry Rxman Griffin »
Offline the technological J
  • deliciouso!
« Reply #10153 on: May 01, 2012, 09:56:14 PM »
where is everyone getting these wiring harnesses?
94 ST1100..Gone
72 750 K2 Stay tuned!
Offline Hablo
« Reply #10154 on: May 02, 2012, 11:59:36 PM »
Removed the upper triple tree, dash, chain guard, and tail light/license plate bracket to have powder coated.
'73 CB350F
Offline Emokid
  • Easy you say ? Now where's the fun in that ?
« Reply #10155 on: May 03, 2012, 08:40:02 AM »
Rebuilt my coils today :)
The wires where rock hard , and the cable for number 4 was broken where it went into the coil body.
I cut them all of and took a grinder to expose the wires where they go along the coil body surface .
Got five feet of 7mm spark plug wire from the store .
Soldered them onto the wire left in the coils .
Covered the cables in a sort of mesh hose ( really dont know what its called in english ) , some heat shrink on the ends , screw the caps back on and hey presto , looks way better than new :)
All thats left is to fill the parts i removed
With epoxy ,for insulation and to sement everything firmly .
Edit :
Did the epoxy , used a couple of pieces of tape to make a mold , it follows the shape of the coils .
Then used a syringe to fill the cavities with epoxy , two holes , one to fill ,one to let air out , worked like a charm
« Last Edit: May 03, 2012, 11:08:01 AM by Emokid »
-76 550f ,transforming into the 798 "Nazgul" cafe
http://forums.sohc4.net/index.php?topic=97563.0
Offline Really?
« Reply #10156 on: May 03, 2012, 09:32:09 AM »
Got a 77/78K tank for "Beans".  I am liking the size of that tank.
The Wife's Bike - 750K5
The Kid's Bike - 750K3
« Reply #10157 on: May 03, 2012, 12:37:02 PM »
New/NOS F harnesses are NOT available. Sheer luck and much more persistence. I have seen 2 in 5+ years on EBay. I won mine luckily for only $150. Just got a response to a thread here that a company has started making K harness for $90 and is beginning F harnesses. CB750Supply maybe??
MAYBE NOT!!   http://forums.sohc4.net/index.php?topic=104650.0;topicseen
« Last Edit: May 03, 2012, 12:39:46 PM by Jerry Rxman Griffin »
Offline grcamna2
« Reply #10158 on: May 03, 2012, 12:40:48 PM »
Edit :
Excellent work Emokid !
« Reply #10159 on: May 04, 2012, 01:30:35 AM »
that is good work,great attention to detail.
Offline Dimitri13
  • 1974 CB550K
« Reply #10160 on: May 04, 2012, 01:41:33 AM »
Finished my seat mount. Came out like crap. Used the stock hinges and lock. Won't be using those when I do a permanent mount.
While on the test ride, the same exhaust flange backed itself out and I lost one of the two brand new collars. Any reason why this could be happening? Bad studs? Should I use loctite? My #$%*ty plate bracket failed and wedged the plate between the tire and tore it up a bit. Oh, and I forgot to put the cam cover side cover bolt back in, and it pissed oil all over my pants and shoe. Made a HUGE mess (you can see it missing in the above photo).
« Reply #10161 on: May 04, 2012, 04:26:31 AM »
Rode to work wearing my new jacket - Xelement vintage brown. Quite happy with my new gear.
Fog in places, very enjoyable 20+ miles in VA. My commute is actually 1.5 miles but I tend to make loops to get there when I ride :)
Offline Rhummy
« Reply #10162 on: May 04, 2012, 04:51:18 AM »
Yesterdays work:
Points were off, seems 2-3 was too close not really letting them fire and caused the plugs to be fouled.
Redid timing.
Took carbs off, bench synched, fixed gas leak, float adjustment needed.
Dicked around with the carb settings.
All in all, not a bad day
1977 CB550f
« Reply #10163 on: May 04, 2012, 05:47:48 AM »
dimitri13,you can locktite the stud into the head,or even use any hard setting compound,you shouldnt need to though,are you sure those collars were in correctly and seated?is that a temp exhaust or do you have plans for something a bit more restrictive and quiet,im not being funny here,i just dont understand those non existent exhausts?
Offline Dimitri13
  • 1974 CB550K
« Reply #10164 on: May 04, 2012, 11:07:17 AM »
it's not the studs that came out, it was both nuts that backed off the studs.
Yeah, they were in there correct. Lots of thread came through the nut, same as all the other flanges. The flanges are all original oem stuff, and the collars I use there were new oem stuff. Before I lost them the first time, they were original oems, just like the other three. I didn't have this problem until I took my headers off to do some head work.
I had a muffler on there, but it fell off. My next paycheck I'll be getting another.
Offline grcamna2
« Reply #10165 on: May 04, 2012, 01:57:01 PM »
Dimitri13,
     Vibration can be intense and it would really help to keep those parts from coming off of there if you replace the muffler and put a good solid rear mount on your exhaust system back there.
72500john
« Reply #10166 on: May 04, 2012, 02:29:59 PM »
dimitri13,
try some stainless lock washers under the nuts.
« Reply #10167 on: May 04, 2012, 02:38:49 PM »
Cut lock washers dont work, try some of those star shaped ones.
My ride home was rainy and now the sun is out. Thats how it goes when you dont know nobody up there :(
Offline Statenheimer
« Reply #10168 on: May 04, 2012, 03:20:24 PM »
Today these arrived on my doorstep.  Scored them taking a chance on a vague eBay ad that only had a grainy pic of the shocks, and made no mention of S&W...
Got them for $50 shipped!   8)
'75 550F - Resto/mod - Riding - But never really finished...
'76 550K - Cafe build - On hold
'78 550K - Parts - Good engine for another day
'73 500 - Parts - Engine seized
'90 CB-1 - No longer seized! but still title-less
« Reply #10169 on: May 04, 2012, 03:22:10 PM »
Good score on the shocks mate..... ;)
« Reply #10170 on: May 04, 2012, 04:30:49 PM »
Thanks Retro.  I'd imagine they have been sitting on a shelf for a while...
Dusty, but brand new   ;D
Offline Dimitri13
  • 1974 CB550K
« Reply #10171 on: May 04, 2012, 06:11:20 PM »
Dimitri13,
Yeah. I had some autozone muffler tip that just screwed into place. It was fine for about a week then fell off on the highway. I'll be switching back to my mac can soon enough. As for the collars, do ya'll think one will seal the exhaust until I get a replacement?
Offline Greggo
  • Somebody's
  • Helmets Save Lives. Period.
« Reply #10172 on: May 04, 2012, 06:12:01 PM »
Lucky SOB!  What a great deal on those.
Offline Dimitri13
  • 1974 CB550K
« Reply #10173 on: May 04, 2012, 10:57:46 PM »
Replaced the stacks with stock airbox. Will save stacks for aftermarket carbs. Quick question on the jetting tips though:
2 jet sizes for 4 into 1 exhaust
2 jet sizes for no muffler (open header)
Do you add these two together if you've got 4-1 headers with no muffler (2+2-1=3)? Or just count the open header (2-1=1)?
Offline fastbroshi
  • Puppet
« Reply #10174 on: May 05, 2012, 03:45:53 AM »
Dimitri, do you wear a full face helmet?  If not you better get one soon.   ;D   Sorry, I have to laugh at your logic here.  Someone posted a how-to a while back that was broken down like that.   Is that what you're referring to here?  Sorry, but it's not that easy.
