Author Topic: What did you do to your bike today ?  (Read 3268778 times)
0 Members and 7 Guests are viewing this topic.
Offline Really?
« Reply #12775 on: December 15, 2012, 04:44:23 PM »
I have 110's in momma's. stock is 105.  Well, if they are the same carb number as when new.
The Wife's Bike - 750K5
The Kid's Bike - 750K3
« Reply #12776 on: December 15, 2012, 05:01:09 PM »
Cleaned the carbs on the Planet Blue K5. It was #2 Terry, not #3. Also did some cosmetic restoration, personally I don't care for rattle canned black engine covers...
Had some spares laying around and swapped em out....
Then started her up and took a test ride down to the local park. Beautiful day.....
Oops, sorry Steve, I didn't realise that your bike's got the fuel tap (pet rooster?) on the left side, hence #2 carb blocked, and not #3. It certainly looks much better with the chrome covers mate, well done! Cheers, Terry. ;D
Offline Greggo
  • Somebody's
  • Helmets Save Lives. Period.
« Reply #12777 on: December 15, 2012, 05:24:36 PM »
Cracked into a set of '69 K0 750 carbs that will be going on the 500/4 8)
« Reply #12778 on: December 15, 2012, 06:12:23 PM »
How are you gonna make 'em fit mate? Cheers, Terry. ;D
Offline JamesM
« Reply #12779 on: December 15, 2012, 07:10:52 PM »
Sold my '73 500 the other day :( , new owner picking it up the 28th. Picked up a '78 750 with a '74 motor in it today off a member on here. Going to be stripping it completely apart and doing a ton of stuff to it over winter.
« Last Edit: December 16, 2012, 08:46:41 AM by JamesM »
Current Stable:
1972 CB750
1973 Shovel
1978 CB750
1977 KZ750T
1996 Shadow VLX
Offline Greggo
  • Somebody's
« Reply #12780 on: December 16, 2012, 07:23:13 AM »
Terry, they mount right up to the existing spigots.  I will have to ding the underside of the 500's smaller tank to make room for the 2 & 3 carbs' tops.
Offline Greggo
  • Somebody's
« Reply #12781 on: December 16, 2012, 08:58:18 AM »
Here's a spare set of intake runners from a 550 up against the 750 carbs...PERFECT!  I will buy new rubbers for both ends ;)
« Reply #12782 on: December 16, 2012, 12:39:32 PM »
No worries mate, be careful with the K0 carb mounting bracket, it's fragile and will snap if you try to force the carbs on or off. Cheers, Terry. ;D
Offline MoMo
  • Ride like you're invisible
« Reply #12783 on: December 16, 2012, 12:46:46 PM »
Right, and you'll wind up with this...Larry
« Reply #12784 on: December 16, 2012, 01:08:14 PM »
Did the Amish man TIG weld that Larry, or was it gas welded? Cheers, Terry. ;D
Offline bjatwood
  • I never claimed to be an
  • 1973 CB750-K3
    • Minbikers Proboards
« Reply #12785 on: December 16, 2012, 01:14:24 PM »
Adjusted valves and did some Valve cover polishing. Can't wait for spring to come!!!
Next project is the clock face freshing up Ron's  Red Zone overlay..... ;)
Brian
#24193
I believe that the Finest things are the most thoughtfully made, not the most expensive!
http://minibikers.proboards.com/
Offline Greggo
  • Somebody's
« Reply #12786 on: December 16, 2012, 01:21:58 PM »
I remembered that picture, and that was the motivation to go straight for the heat, not force to remove the practically glued on float bowls.  Broke the tip off my favorite Kershaw knife being stupid...Grrr  >:(
« Reply #12787 on: December 16, 2012, 02:16:18 PM »
Geez I had a Kershaw knife many years ago, I wonder what I've done with it? I just checked Ebay and (shock horror) it looks like Kershaw knives are now made in China? That sucks.  >:(
http://www.ebay.com.au/itm/USA-Kershaw-Grant-County-Folding-Pocket-Knife-Camping-Fishing-XMAS-Tool-Gifts-/251200039393?pt=AU_KnivesSwords&hash=item3a7cb069e1
Offline Trounce
« Reply #12788 on: December 16, 2012, 08:02:14 PM »
Motor is in ....starting to look like a bike again.
"You don't know till you try and fail....and then try again!
Offline Dimitri13
  • 1974 CB550K
« Reply #12789 on: December 16, 2012, 11:23:20 PM »
Cleaned up the triple tree and figured out how to work the steering lock. Turns out the replacement key I had doesn't have a groove at the top, so I had to use the OEM key it was traced from.
Online CycleRanger
  • No comment about being an
« Reply #12790 on: December 16, 2012, 11:31:01 PM »
CR - did You recently put 130's in yours?
No, 120's but I took them out a couple of weeks ago and put in 115's. Much better.
« Reply #12791 on: December 17, 2012, 06:57:16 AM »
Got it, thx for the info.  PS. I'm off next week, let's ride.
Offline DJ_AX
« Reply #12792 on: December 17, 2012, 10:33:08 AM »
... still ridin' in Michigan...
oh snap... I hope I didn't curse it.
Offline mjstone
  • I'm definitly not a
« Reply #12793 on: December 17, 2012, 04:58:59 PM »
Keep it up DJ!  With your windshield you should be able to ride year round like I do.
MJ
1972 CB500Four (Honda)
1973 CB500Four (Oliver)
Offline Dimitri13
  • 1974 CB550K
« Reply #12794 on: December 17, 2012, 05:39:48 PM »
Picked up boxes for my top end and swingarm. Stupid me putting it off forever and now I'm paying the price with the wait time.
« Reply #12795 on: December 18, 2012, 03:01:17 AM »
Well while I'm waiting for my new 34mm Mikuni carbs for my CX500 to arrive, I decided to get off my butt today and do something mechanical. I like the look of the stock mufflers but I believe that they're pretty restrictive, so my initial thoughts were to drill out the rivets and "gut them". I drilled them out and quite liked the symmetrical holes, so I fired it up and Woohoo! It's got a note!
Of course, my assumption was that drilling them out would allow them to come out, but in fact, I couldn't even lever the caps off with a long handled screwdriver, but what the heck, it sounds so good I don't care. I gave 'em a squirt with some satin black paint, and they look almost "factory".
I bought some new rear shocks from an Ebay seller in Brisbane, he was fantastic, he set them up for my CX500 with the correct bushes, so there was no mucking about, I had them on in around an hour. (the hardest part was removing the mufflers so I could access the mounting hardware.
All in all, a nice easy day. I did a little bit of work, and went for a ride to the pub. The bike sounds like a "proper" V twin now, not too loud, but probably a little louder than legal. Cheers, Terry.  happy0062
Offline Scotty J
« Reply #12796 on: December 18, 2012, 11:26:10 AM »
Today...  Installed Cycle Exchange lightened & balanced Alternator rotor.  I had to pick up a Milwaukee electric impact wrench to break the bolt loose on the old one.  I don't think that bolt had been turned since my CB's birth in '72!
No reports on performance improvements as it's been pissing down rain & sleet for the past few days.
1972 Honda CB750 Four
2010 BMW R1200 GSA
Offline Greggo
  • Somebody's
« Reply #12797 on: December 18, 2012, 02:14:00 PM »
Looks nice!
« Reply #12798 on: December 18, 2012, 02:16:18 PM »
Looks nice!
yes, very. They redefine "chamfer".
Offline Dimitri13
  • 1974 CB550K
« Reply #12799 on: December 18, 2012, 04:49:16 PM »
Reserved.
