Author Topic: What did you do to your bike today ?  (Read 3282307 times)
0 Members and 7 Guests are viewing this topic.
Offline boatsdickson
  • 1978 836 K8
« Reply #12950 on: January 14, 2013, 06:17:04 AM »
I threw a tarp and moving blanket over the k8 for the rain, ice, & snow. Grrrrr......I cant wait till I get my shop moved from the city to my country house.
"No. We're all our own prisons, we are each all our own wardens and we do our own time. I can't judge anyone else. What other people do is not really my affair unless they approach me with it. Prison's in your mind. Can't you see I'm free"?  Testimonial of Charles Manson
Offline CycleRanger
  • No comment about being an
« Reply #12951 on: January 14, 2013, 06:49:01 AM »
Fired up the K5 yesterday after letting it sit for more than a month. Of course it started right up and soon the shop was filled with fumes.
Mmmm, fumes. ;D
I added a bit of magic Seafoam to the gas and ran it for a bit more then shut it down.
While I was letting the 750 idle I looked at the 80% finished CJ360 and tried to will it to completion.
No luck, maybe next weekend I find the inspiration to continue on it.
Offline Harsh
  • 74 CB750 and two 72 CB350's
« Reply #12952 on: January 14, 2013, 06:59:55 AM »
I installed the engine.
« Reply #12953 on: January 14, 2013, 07:14:15 AM »
Mocked up the swing arm and handlebars.  Now on with desigining rear master cylinder bracket and lever.
« Reply #12954 on: January 14, 2013, 11:54:22 AM »
Just ordered all new bolts for my two front 750 K1 calipers and dual disc front hub @ Bolt Depot $13 + $11 shipping.
Nice to get all from one place.
here's the parts list for others  (for 2 calipers)  hopefully it will be of use to someone sourcing hardware
quantity, BoltDepot's part #'s, specs, use....
6, #10687 - Metric flange nuts serrated, Zinc plated class 8.8 steel, 8mm x 1.25mm Front Hub Rotor mount flange nuts
10, #4527 - Metric flat washers, Zinc plated steel, 6mm (calpier arm shim/b-pad adjuster washers )
4, #4529 - Metric flat washers, Zinc plated steel, 8mm (calpier arm shim washers)
2, #6223 - Metric hex bolts, Zinc plated class 8.8 steel, 8mm x 1.25mm x 35mm lower caliper arm mount bolt
6, #6235 - Metric hex bolts, Zinc plated class 8.8 steel, 8mm x 1.25mm x 110mm Front Hub Rotor mount bolts
4, #6064 - Metric tap bolts, Zinc plated class 8.8 steel, 6mm x 1.0mm x 30mm    upper caliper arm mount bolt
2, #5143 - Metric machine screws, Phillips flat head, Stainless steel 18-8, 6mm x 1.0mm x 50mm   B pad adjuster bolt
2, #13572 - Metric hex jam nuts, Stainless steel 18-8, 6mm x 1.0mm    B-pad adjuster nut
4, #15754 - Metric socket cap, Class 12.9 steel black oil finish, 10mm x 1.25mm x 50mm CB750 K1, Caliper Hex bolt - i'll cut these down to 45mm
« Last Edit: January 14, 2013, 12:26:55 PM by flybox1 »
FROZEN SIDE COVER !!!
« Reply #12955 on: January 15, 2013, 09:55:23 PM »
My side cover froze up... >:(>:(
Offline chris mcshifty
« Reply #12956 on: January 15, 2013, 10:11:13 PM »
Looked at mine to decide what's next for a bike that hasn't ran in 5 years and needs the motor gone though
Offline nccb
  • 1974 CB750 Four
« Reply #12957 on: January 16, 2013, 02:57:04 PM »
put stuff on, took it off again, put it back on, realized i lost parts in the process and basically achieved absolutely fu**ing nothing :-\
Offline Greggo
  • Somebody's
  • Helmets Save Lives. Period.
« Reply #12958 on: January 17, 2013, 10:45:51 AM »
Frank, that bike looks UNHAPPY ;D ;D
« Reply #12959 on: January 17, 2013, 12:18:13 PM »
Took circlip out of master cylinder I am gonna rebuild.
Offline Tews19
  • I am no
« Reply #12960 on: January 17, 2013, 12:59:03 PM »
Where did you get the tool? I need one
1970 Honda CB750 survivor.
« Reply #12961 on: January 17, 2013, 01:05:40 PM »
I sprayed it with gun blaster cleaner day before to losen up the cirlip.
To get it out I had a small screwdriver  - small enough to fit the circlip hole - ground to sharp point. After several attempts I was able to lift the end of the clip up. Broke the first one of, got it out via the second one. Important to push the piston down to align the groove with the clip. Perseverance is the best tool here:)
Offline captain hopeless
« Reply #12962 on: January 17, 2013, 01:24:06 PM »
I morgan carbtune'd my 350. My number 1 cyl was at the top of scale, while number 4 cyl was not registering, and it ran like a tractor! Much better now.
I also cleaned it, adjusted the chain, and contemplated painting the engine...
When I removed my master cyl circlip, I bought a cheap pair of long nose pliers, and ground and bent the tips such that they would grab the circlip better. Came out eventually.
Offline fire113
« Reply #12963 on: January 17, 2013, 01:36:01 PM »
...got a lot of pats today  ;D
Did the carbs and now I am thinking what will be the best way to get the dent out of the gas tank.
Offline Greggo
  • Somebody's
« Reply #12964 on: January 17, 2013, 03:41:11 PM »
http://youtu.be/eEmCdd_DY7Q
Offline fire113
« Reply #12965 on: January 17, 2013, 04:14:30 PM »
THX Greggo,
...I tried to get a dent out by the first cb750 gas tank I did but I had a strange feeling, thought the material is too thick and will be going to break by pressing the dent out.
Not sure if I can reach that part in the gas tank with the tools but I will give it a try.
have a good one...Georg
« Reply #12966 on: January 17, 2013, 06:01:52 PM »
Got my new $6 feebly  3.3v - 30v red LED voltmeter w 8" leads.
Not waterproof, but I plan to seal it with some silicon, and mount it hidden below my gauges.
My son tested on a 9v battery...
Comes in blue, green, yellow and red...
« Last Edit: January 17, 2013, 06:18:05 PM by flybox1 »
Offline cbtex
« Reply #12967 on: January 17, 2013, 06:28:05 PM »
Some new stuff like coils, wires, plugs and ignition.
« Reply #12968 on: January 18, 2013, 01:17:30 AM »
THX Greggo,
G'Day Georg, to do it properly, you need to buy the proper tools, but they do work. Here's a vid of a guy repairing a CB500 tank, my only concern is that it looks like he didn't quite get the worst dent out? Check it out just after he gives it the "thumbs up" at the 2.50 minute mark. Cheers, Terry. ;D
74 Honda CB 500
Offline fire113
« Reply #12969 on: January 18, 2013, 03:44:15 AM »
Hi Terry,
...I saw the vid Yesterday and all other from the dent dynamics.
Next week I will have 100% health back  :) and I can go on with the bikes.
Did You saw this one ? --> 69 honda
Offline Greggo
  • Somebody's
« Reply #12970 on: January 18, 2013, 03:51:08 AM »
The Dent Dynamics guy has taken numerous dents for me, from both bike tanks, and car doors too.
Offline fire113
« Reply #12971 on: January 18, 2013, 04:18:24 AM »
Hi Greggo,
...do You have some pictures from the gas tanks ? before and after ?
Offline Greggo
  • Somebody's
« Reply #12972 on: January 18, 2013, 06:31:21 AM »
Hi Greggo,
I don't have a good 'before' pic, but here is a NOS CB550 tank that had a bad dent in it from being dropped inside the box..it was pretty bad, and he couldn't save a chunk of the paint from chipping off, but the metal was almost perfectly smooth..very difficult to smooth out a bad crease.
Offline Greggo
  • Somebody's
« Reply #12973 on: January 18, 2013, 06:35:37 AM »
Okay, I found a good 'before' pic of the 550 tank, and then another of a 750 tank that had a BAD crease from the forks slamming it..he almost couldn't fix the 750 tank, but ended up getting it done
Offline fire113
« Reply #12974 on: January 18, 2013, 07:52:49 AM »
...THX for the pictures  :)
Here is one of the gas tanks that I have, will use it to practice.
But I thing it will not work on the HUGE dent in the red one, in the middle of the dent
the gas tank has his welding line! I thing it is not possible but I will see.
Have a good one...Georg
