Author Topic: What did you do to your bike today ?  (Read 3193076 times)
0 Members and 18 Guests are viewing this topic.
« Reply #18350 on: August 18, 2014, 10:12:53 pm »
Met up with a few members today and this thing called pimpzilla.
SUPER NICE group of 750's there Guys !!  See your bike Nick and Sean's, what other members are there ?  Safe rides
Hey Eric, Dennis (old scrambler) , Jerry (Jerry H), Johnie (Johnie), Trevor (Hoodellyhoo).
Bet Johnie had a hard time wondering which one to pull out for the ride  ;D
No exaggeration Johnie needs to change his SN to either Showtime or Showroom.  His Red one is museum quality!
So was Dennis the lead dog?    Who has the hot 750?!
Tews' k1 was spanking my f3...Old Scrambler seems to know every good road in Wisconsin.
Offline edwardmorris
  • Youngish
« Reply #18351 on: August 18, 2014, 10:42:18 pm »
Struggling getting the rear wheel laced up right, HAALPP!!
http://forums.sohc4.net/index.php?topic=126735.msg1590927#msg1590927
« Reply #18352 on: August 19, 2014, 02:01:40 am »
requested pic of the rod in question. The bolt is bent, the other all scratched up. Also found the nuts later.
Oh, OK mate, so the rod didn't let go completely? Well your "Big End Bearing" is obviously trashed, looks like it wasn't getting any oil, so have a look at that journal on the crank and see if it's toast, if it's still OK (possible) have a look at the oil holes and see if they're blocked.
I've got a crank that I removed from the K2 engine that someone had rebuilt, (poorly) they'd installed new bearings but hadn't checked that all the oil holes in the crank were clear, and the oil holes on #3 were blocked, resulting in that bearing burning and falling apart.
Did you do any other damage with the nuts bouncing around inside? Looks like you were lucky! Cheers, Terry. ;D
  • Youngish
« Reply #18353 on: August 19, 2014, 09:25:58 pm »
Crisis averted, wheel laced! Ugh, now the damned thing won't true easily.
« Reply #18354 on: August 19, 2014, 10:04:36 pm »
nothing but ride it. I did however get my brothers K1 750 running.
Offline Radam
  • taco racer
« Reply #18355 on: August 21, 2014, 11:20:36 am »
I bought it! I'm back in the club! 1972 frame with 73 engine cb500 registered as a 73. Hasn't been registered since 97. Guy I got it from said he bought it from a mate a couple years ago with plans to do it up, but never did anything. Started when parked, of course. I haven't had a chance to do anything yet. Carbs and engine have both been painted, so I'm not sure if it has had any engine work in the past. I need to hook up all the cables and put fluids in it to see if it runs. Also needs a battery and kick start lever. Other than that I think it's all there. Came with two four into one set ups and (I think) original 4-4 that is a little rough.
And I have a real garage!
Offline Schnell
« Reply #18356 on: August 21, 2014, 11:26:29 am »
Welcome back to the club. :)
primary: 1974 Honda CB750
project: 1971 Honda CL350
project: 1974 Honda CB450
previous:
1975 Honda CB750
1973 BMW R90/6
1981 Suzuki GS650
1973 Honda CD175
« Reply #18357 on: August 22, 2014, 02:07:00 pm »
 Busy. Met a friend and fellow forum member this morning at the local mega dealer to check out his new 2014 CB1100 he ordered that is still in the crate. He wrote the check and will take delivery Monday. Very Nice
 Buttoned up the carb clean on the V65 and reinstalled air filter stack.Lots of horror stories on these but not too bad especially with new rubber manifolds, no longer scared to dig in. Ran it a little on the bottle,bout ready for a first ride.
  Recently picked up a Kaw KZ750.Waiting on sprockets,chain has arrived, so pulled carbs to find a gas leak.Pulled carbs and attached fuel bottle to find culprit. Of course the PO or somebody had done the typical sh#t job of too big of gas line with two many crap as% clamps, leaked like a sieve. Easy fix and was going to replace anyways and a good time to clean the jets/bowls which were in good shape. Changed the oil and pulled front and rear brake pads,look worn and original so ordered new. Hopefully button it up next week, take it for a ride and move on to another couple in the works.
« Reply #18358 on: August 22, 2014, 04:24:40 pm »
Welcome back Adam, what are you doing with yourself in "Un Zud" mate? That's a nice little 500/4 mate, well done! Cheers, Terry. ;D
Offline krusty
« Reply #18359 on: August 22, 2014, 05:36:47 pm »
Bead blasted four Colleda brake MCs prior to painting them.
Honda
1976 CB750F1
1978 CB750F2
1972 CB350F
1961 C100 Cub
1962 C100 Cub
1959 C76
1963 C92
1964 C95
Suzuki
1963 M15D 50cc
1961 250TA Colleda
Yamaha
1977 DT175E x 2
1978 DT125E
1979 DT125F
1976 DT250E
1978 DT250G
1984 FJ1100
1990 FJ1200
Offline rickman750
« Reply #18360 on: August 22, 2014, 11:18:04 pm »
Still waiting for parts from David Silver Spares.
Hooked up the Venhill hydraulic brake light switch on the Steaming Pile.
Found some really dodgy hack work on the front 'guard. Drilled out the rivets and started fabricating a proper hoop to hold the guard in the right place.
« Reply #18361 on: August 22, 2014, 11:47:53 pm »
Changed the oil last night and discovered that  I cracked the oil pan in the process and that my cb750 dry sump oiling system is actually quite wet...and $25 worth of 20w50 is really only a fleeting glimpse of value when it is in a puddle on the garage floor....please, someone take this f3 away from me, I hate it, what a piece of mechanical garbage
  • Youngish
« Reply #18362 on: August 22, 2014, 11:56:07 pm »
Finished polishing the front hub
« Reply #18363 on: August 23, 2014, 02:21:51 am »
Well it was a wonderful pre-spring day today, and I was on a motorcycling mission. I actually got out of bed around 8am, and after a breakfast of eggs and fried tomatoes (from my own garden) on buttered toast, washed down with a cup of joe, I sauntered out to the ol' Tardis to do some work on the mighty 'Wang.
My last episode (re-installing the wheels with the new Stinko whitewalls) resulted in my rear brake caliper crapping out and dumping Dot 4 all over my driveway, so I invested 20 bucks (plus 60 for shipping) on an ebay replacement. It had arrived by the time I got back from working at a Navy base this week, so I got the tools out and after 4 or 5 hours, it was all ready to go. My "Mity Vac" made short work of the brake bleeding, and I was ready to ride.
I'd really only intended to do a short "shakedown" ride, but I ended up doing a quick 150 miler, riding from my place to Yea (pronounced "Yay", not "Yeah") via Broadford. I stopped in at the "Red Plate Cafe", a great place for any biker to stop for a coffee and a snack. The place is run by a biker and his son, and they were keen to give me the 2 dollar tour.
He's got some great bikes in and around his cafe, from vintage BSA slopers to Kawasaki H2 race bikes, Yamaha SR500 Cafe Racer, a Speedway bike, and a nice Yamaha TT500, not to mention the BSA 650 twin and TT500 hybrid motocross bike out the front.
All in all, a great ride, great coffee and "ANZAC" biscuits, (Cookies) and I'll be going back again next ride. Cheers, Terry. ;D
Remember this guy? He co-starred in "Ghost Rider", and his name's Bob.
Offline Radam
  • taco racer
« Reply #18364 on: August 23, 2014, 02:38:40 am »
[quote author=Terry in Australia link=topic=61168.msg1592289#msg1592289 date=1408749880
[/quote]
Thanks, Terry. I'm doing a sports turf apprenticeship for work. I've been doing a bit of hunting with my longbow, and shooting tournaments a little too. I'm currently ranked #3 in NZ with my longbow. I'm also playing in a basketball league here and go fishing as often as possible. Where the hell am I going to find time to fix up this bike?! We're loving it here, and don't plan to leave any time soon. Have you done anything with those parts I cleaned up for ya?
« Reply #18365 on: August 23, 2014, 03:00:46 am »
G'Day Adam, good for you mate, great to see you enjoying your time in "Middle Earth"! I sold the K6 frame to a movie set dresser, and got Jeff to true the wheels and installed new Pirelli Sport Demons, and put them on a bike I'm building for a guy called Mike.
I built his engine last Christmas, and it looks so nice I couldn't bear putting it back in his horrible rolling chassis, so I've taken his roller as a part trade for the bike I'm building for him. Here's a pic. Cheers, Terry. ;D
« Reply #18366 on: August 23, 2014, 03:42:33 am »
You and the F3 still not getting along well ? Time to get ole' Goldie back on the road !!
« Reply #18367 on: August 23, 2014, 12:03:49 pm »
ya think?
« Reply #18368 on: August 23, 2014, 12:41:30 pm »
Took the Smokin' RD350 out for a spin to the cliffs....
« Reply #18369 on: August 23, 2014, 01:46:46 pm »
Yikes! You're braver than I am!   :o
  • Youngish
« Reply #18370 on: August 23, 2014, 09:10:37 pm »
Laced and trued up the front wheel  :) Now, conti vs avons decision   :-\
« Last Edit: August 23, 2014, 09:21:26 pm by edwardmorris »
Offline maduncle
  • Don't confuse me with a
« Reply #18371 on: August 23, 2014, 09:25:37 pm »
Just got back home from a two day ride through some great twisties in the far south east of Victoria.
The 'Melbourne Cafe Racer' group run an annual 'Brass Monkey Ride' - involving lots of riding, with this years destination being the Shady Creek Hall where we lit a big fire, had a rockabilly band playing, ate baked spuds and drank copious amounts of beer, red wine, scotch and Frangellico.
Time to rest.
CB750K2 (only slightly modified)
« Reply #18372 on: August 24, 2014, 05:51:27 am »
Meanwhile as Steve casually puts the camera away and leaves the lake  :o  https://www.youtube.com/watch?v=EWkoT1qPXwQ
  • Youngish
« Reply #18373 on: August 27, 2014, 07:22:58 pm »
Sanded down rear brake stay plate. Phew!
« Reply #18374 on: August 28, 2014, 03:21:14 am »
Had a real satori over electrical schematics.  See the few schemas that everybody uses pritn pretty #$%*ty.  Like green for ground looks identical to black on paper, brown and red are also quite the same.
If I were better person, I would redo it and publish it here  :)
