Author Topic: What did you do to your bike today ?  (Read 3192735 times)
0 Members and 11 Guests are viewing this topic.
Offline Tugboat
  • Puppet
    • PseudoMoto
« Reply #18475 on: September 08, 2014, 12:21:08 pm »
Replaced a bum condenser. Bike runs great now!
« Reply #18476 on: September 08, 2014, 01:01:11 pm »
Changed front sprocket on my CB750 K6 from 17t to 18t without open the chain! Almost new chain, super duper heavy type with 100 golden 530 links X-ring, riveted master link. Removed front sprocket only that had lost one bolt, rear wheel in front position. Sprocket bolts now fastened with blue thread lock.
I do not use bike between redlights nowadays. It screamed too much...:)
Yesterday changed pilots and mains in my Vm29 carbs again....
Hondaman ignition module got it place in the toolbox under the seat. Connected and ready to go with extra grounding wires from coils bracket to frame metal to metal contact.
Waiting for a not rainy day for test. Summer yesterday, today rain.
Offline wowbagger
  • Not much of an
« Reply #18477 on: September 08, 2014, 01:15:38 pm »
Finished the engine rebuild on my CB500 K0. New primary chain, cam chain, gaskets and seals all around. Also powder coated it all. Here's a before and after shot.
Offline Tews19
  • I am no
« Reply #18478 on: September 08, 2014, 01:21:27 pm »
Looks awesome Bagger!
1970 Honda CB750 survivor.
Offline wowbagger
  • Not much of an
« Reply #18479 on: September 08, 2014, 01:24:27 pm »
Yeah, it's taken me all summer to get the engine done. Now I'm just waiting on new engine mount bolts and friction plates. I'm still lying to myself that I'll have it back on the road this season. Though, I may need to stretch the riding season into November.  ;D
Nic
« Reply #18480 on: September 08, 2014, 02:42:17 pm »
All in all, not a bad weekend. Time to get a roller together!
Bloody beautiful mate n I know how much work goes into something like that.
Thanks, all winter sanding in small chunks, then a whole day buffing it yesterday. PITA, but worth it  :-\
Here're some pics of a similar process I did to my brake and gear change levers, stock these parts have cast marks all over them, I spend a couple of days smoothing them all out and polished ready for chrome. Job made harder being that I was working with steel.
« Last Edit: September 08, 2014, 02:44:28 pm by Nic »
Offline edwardmorris
  • Youngish
« Reply #18481 on: September 08, 2014, 02:53:24 pm »
They look great! Fortunately for the chromed pieces, the plating shop took care of smoothing them down :)
Nic
« Reply #18482 on: September 08, 2014, 02:58:18 pm »
True but if you do the smoothing/polishing yourself you reduce the price of the chrome by 2/3. I had a lot of chrome done to nuts, bolts and washers and did all the polishing on them myself, all six sides and the top, I spent 3 months restoring bolts. nut and washers, never again ::)
  • Youngish
« Reply #18483 on: September 08, 2014, 05:03:39 pm »
You and me work alike bud, swing by my build thread sometime. I did a bulk deal with the chromer as well, but I only cleaned the parts as best as I could, no smoothing them out or anything. Everything, down to the smallest chrome washers got replated! As for all the zinc stuff, I plated all that myself and chromated it too! A whole year has past and I can feel that its getting close to be complete, fingers crossed.
« Reply #18484 on: September 08, 2014, 05:58:26 pm »
I think you will be happy with the 18 tooth along with a 48 on the back.
« Reply #18485 on: September 08, 2014, 06:03:47 pm »
I think 18/48 was OEM anyway so you just went back to stock. The 17 was OEM on an earlier K and on the Fs I think.
Offline Jo3f1sh
  • Still don't have a jacket, even though I'm a
« Reply #18486 on: September 08, 2014, 06:19:18 pm »
Got carried away with my Dremel on my rear fender. 4 cutting disks later...
Also threw on a seat strap and chrome strip.
1974 Honda CB350 Four
Build thread: http://forums.sohc4.net/index.php?topic=138848.0
« Reply #18487 on: September 08, 2014, 06:50:02 pm »
^ I'd definitely throw a leg over that--Nice---
« Reply #18488 on: September 08, 2014, 10:48:22 pm »
Ya...me too. Looks nice.   8)
Round.out those rear fender corners so they match the front.  Symmetrical.
  • Youngish
« Reply #18489 on: September 08, 2014, 11:08:42 pm »
Taking a break from polishing, finished up chromating the carb bits. Yellow or Blue?
Offline Zaipai
    • My Home page
« Reply #18490 on: September 10, 2014, 12:20:30 pm »
As much as the Yellow looks good, I think I would go with Blue, however its all a matter of personal choice right? However if you were going for a stock look the Yellow would likely be a better choice.
.: Scott :.
Its my Avatar..
75 CB550F  |
  • Youngish
« Reply #18491 on: September 10, 2014, 12:37:31 pm »
Yea, I wanted a more stock look but I think I'll go with the blue for now. Most of the hardware was done blue and only the most exposed to the env pieces were done heavy yellow (kickstand bolts and spring, centerstand shaft and c-clamp etc.)
Offline maduncle
  • Don't confuse me with a
« Reply #18492 on: September 10, 2014, 08:32:31 pm »
Put my front end together today.
Thanks to Terry who turned down my Suzuki GT750 axle ends on his lathe, it all fits together nicely.
CB750K2 (only slightly modified)
  • Youngish
« Reply #18493 on: September 10, 2014, 10:22:14 pm »
Removed the bearing form the clutch lifter plate (just fell out) and the counter shaft end cover (this one took the heat gun to fall out).
Offline AbbyRider
« Reply #18494 on: September 12, 2014, 06:49:59 pm »
Sealed my tank with Caswell epoxy. Now when I get my carbs back from Harisuluv I won't be putting any more rusty crap into them.
'98 VTR1000 Superhawk
'78 CB750F
'77 CB750F (in the works)
'81 KZ650 sitting in pieces in my basement
« Reply #18495 on: September 13, 2014, 04:50:16 am »
Sold my Kawasaki last night  :o
No - not any of the good ones. Went on a house call for antiques a couple of weeks ago, bought a few things and the guy asked me to haul this out of his yard for him. Been sitting outside for some time.
  Ran an add and got a call. People drove from a fair distance. Very good looking lady with a mini van and trailer pulls in my lot- Hmm nice.  Out jumps an enthusiastic 16 year old young man and little brother and looks it over. Mom says he has a bunch of lawn mowers etc. and loves to tinker with gas engines. He works up the courage to offer 40 bucks and I say sold  :D
   Glad he got it and nice to see some of the younger generation wanting to tinker and get their hand dirty on engines and machines instead of living behind a computer screen. !!
Offline Tews19
  • I am no
« Reply #18496 on: September 13, 2014, 06:46:01 am »
That's cool! I bet his parents were like wtf! How long before the kid runs his leg over while riding the 3 wheeler?
« Reply #18497 on: September 13, 2014, 07:09:18 am »
If he ever gets it running again.
« Reply #18498 on: September 13, 2014, 07:42:47 am »
You had me concerned there for a second, Eric.   BTW, do you have an H1? That is next on my list.
« Reply #18499 on: September 13, 2014, 08:18:51 am »
Nice story, Eric.
