Author Topic: What did you do to your bike today ?  (Read 3160154 times)
0 Members and 9 Guests are viewing this topic.
Offline joeyvans
  • Definitely not a
  • God's Country, Earth
« Reply #21575 on: April 16, 2016, 02:16:30 pm »
Gratuitous photo shoot!
That thing must be loud without a muffler to go with that Delkevic header/collector.
1976 CB550 K2
Non-SOHC4 - 1974 CB450 K7
Non-SOHC4 - 1996 VFR750F
"No matter how much you shake and dance... the last three drops go in your pants."
Offline oldhatt45
  • The person called in at the last minute to share the blame is the...
  • Just an Old Guy that's gone to the Dogs
« Reply #21576 on: April 16, 2016, 04:57:47 pm »
Wiped down the K6, got all the winter dust off and the winter polish.  Checked the tires, Checked the Oil, all was fine.
Turned the key on, with the kill switch off, and pushed the button.  Let it build Oil Pressure then started her up.
Let it idle a bit to check for leaks.  There were none so I put my helmet, jacket and gloves on and went for a nice little ride on a 70 F afternoon here in NJ.
A Nice Day!!!!
Charlie
« Reply #21577 on: April 16, 2016, 05:27:27 pm »
Torture test: Rhonda had her coldest ride ever today. 45 minutes in -6C, plus a headwind! Can't feel my fingers as I type this.
Bloody hell, I've been riding my bikes to work every day for the last 4 weeks and I thought I was tough riding in sub 10 deg C temps at 0630, but I just realised that compared tou you, I'm a woolly woofter! ;D
I look like the michelin man... wool sweater, winter jacket liner, then bike jacket... kevlar, jeans, and then overpants on bottom. Plus the big winter gloves.
What I REALLY need is some of those neoprene hand warmers that cover the grips. Keeps the wind off!
I'm not sure I've seen them mate, I'll have to check them out, but both of the bikes I have in Canberra are fitted with hand warmers, which are nice. Cheers, Terry. ;D
Offline firebane
« Reply #21578 on: April 16, 2016, 05:32:24 pm »
- Re-attached oil lines and secured them down
- Re-inserted (with a lot of cursing) rubber isolaters for the battery
- Discovered my harness is completely butchered and glad I have one on order
- Discovered my headlight is a 6.25" from a Suzuki bike converted to H4
- Pulled the forks and got rid of the blue and through some black paint on them.
- Pulled the caliper and found the pads are really really crooked lol
Did a few other things but that was the majority today.
Offline edwardmorris
  • Youngish
« Reply #21579 on: April 16, 2016, 05:34:37 pm »
Went out for the first ride/shakedown run of  the season.
Offline jerry h
« Reply #21580 on: April 16, 2016, 08:21:25 pm »
Beautiful bike Rafi!
Have a good shakedown run?
  • Youngish
« Reply #21581 on: April 16, 2016, 09:24:05 pm »
Thanks Jerry! It was just as I left it, smoooooth 8) I did the usual stuff, new plugs, some MMO in the cyls, primed the engine and it fired right up! As soon as that happened, I lost all interest in cleaning and just went out riding :P :P Felt bad after, I should have at least dusted and buffed up the shine ;D
Offline joeyvans
  • Definitely not a
« Reply #21582 on: April 16, 2016, 09:30:22 pm »
You should feel bad.... That's like letting your trophy wife leave the house immediately after she wakes up.
Keep posting pics of that beauty... They NEVER get old.
1976 CB550 K2
« Reply #21583 on: April 17, 2016, 07:11:53 am »
 Fiddled with a couple projects Saturday then decided to activate this K2 as the weather was great. Only have put around 50 miles on it since I got it. First ride last fall and it was puking fork oil from the left side so new fork seals this winter and also replaced the sides tand and its no longer a 'leaner'. Ran great after starting but a new issue. The front brake master goes soft quickly and needs a couple of pumps to start working,like its bleeding back up through the master ? Tried a powerbleed. Works but not to safe on the road yet but still a nice ride on a pretty spring day. Guess a rebuild on that hopefully will fix.
« Last Edit: April 17, 2016, 07:13:44 am by ekpent »
Offline OneWheelDrive
  • A journey of 1000 miles starts with your first carb overhaul.
« Reply #21584 on: April 17, 2016, 08:11:04 am »
Has a nice little internal baffle that really quiets it down.
1975 CB550 cafe
1971 CB500 stocker
2008 Ducati Hypermotard 1100S *sold*
1973 CB350F *sold*
1975 CB550K Project "Keeper" *sold*
2010 Ducati Monster S4RS *sold*
1976 CB360T *sold*
1974 CB550K *sold*
1973 CB750K *sold*
1978 CB550K *sold*
2007 Vespa LX150 *sold*
Online PeWe
« Reply #21585 on: April 17, 2016, 09:32:19 am »
Fiddled with the front brakes this weekend.
Speedo cable must be routed outside of the fender bracket to stay free from the disc.
Remove front wheel means removal of the right brake, caliper w holder.
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« Reply #21586 on: April 17, 2016, 09:57:51 am »
Gave her a bath. All pretty for 2016!
--Evan
1975 CB750K "Rhonda"
Offline 72 yellow
« Reply #21587 on: April 17, 2016, 11:55:15 am »
Went to start the CB750.  Battery low (even though was on a  float charger).  Got it started and found one of the copper exhaust gaskets was leaking badly.  Gave up for the day.  After 15 kicks got the BSA started and went for a ride.  Got the CB up on the workstand.  Will fix the leak during the week and install the new battery.  Time to quit for the day.
« Reply #21588 on: April 18, 2016, 12:13:09 am »
That's a sweet looking K2 Eric! Hey, did you try bleeding your top hose at the MC? Wrap a rag around the top banjo fitting at the MC, (to stop brake fluid blowing eveywhere) pump the lever until it feels firm(ish) and while holding the lever in, crack the bolt. Tighten the bolt, pump the lever and repeat. After fcuking around with the brakes on my FJ1200 for a coons age I tried this, and now I've got a rock hard lever. Look out ladies! ;D
« Reply #21589 on: April 18, 2016, 04:38:13 am »
  I will give it a try Terry, never had this problem before. Like I mentioned the lever will be firm but after a few minutes it will go limp but if I give it a couple pulls it starts to firm up again.  Jezzuz that sure sounds like something else doesn't it- maybe crumble up a Viagra and add a little to the cup----  :-*
Offline Frijec
« Reply #21590 on: April 18, 2016, 07:38:35 am »
I didn't do anything yet, but I bought a 4-1 exhaust.
1973 Honda CB500 Four - Brat
Offline 72 yellow
« Reply #21591 on: April 18, 2016, 10:30:08 am »
Fixed all the above problems, then proceeded to drop it off the work stand.  Trapped me between the bike and my 77 Monte Carlo.  Wife was able to help me get it back upright on the stand.  Left side switch housing smashed.  Mirror broken on the Monte.  Left elbow starting to hurt like a MoFo.  No riding for a while.  Time to go surf FleeBay for a switch.  >:(    Nice welcome to spring.
Offline jonda500
« Reply #21592 on: April 19, 2016, 02:27:29 am »
Extracted my much neglected 2nd 500 from the back of the garage and put my just painted flake sunrise orange 550F back there instead - I have to pull it's engine back out and since the 500 has its nice tank back and only needs carb tuning and a clutch pushrod installed I will turn my attention to that first.
John
A starter clutch thread:
Offline knottedknickers
« Reply #21593 on: April 19, 2016, 06:29:31 am »
Aw, man, that's a drag... Kudos to your wife, though, for helping to get you out of a pinch! Amazing what adrenaline can do--750s aren't the lightest bikes out there! :o
CB750 K6 http://forums.sohc4.net/index.php?topic=141388.0
The plural of "anecdote" is not "data" (Borgmann 2002:5).
Offline 72 yellow
« Reply #21594 on: April 19, 2016, 12:14:54 pm »
  The bruises are starting to show now.  My wife is a real helper, all 4'10" 110 lbs. of her.  My best friend for 43 years.
Online PeWe
« Reply #21595 on: April 19, 2016, 12:59:00 pm »
More grinding making alu dust ???  70mm sleeves often called tapered sleeves that need no case bore...hmmm. No news for me  though.
Did one this evening, case 4.
3 left for tomorrow. Mostly the front halves of the holes in the case that need to be wider. I use an old metal base gasket sitting tight around the sleeves as guide when mark with pen. Lift the gasket and grind. gasket on and compare...gasket off and grind some more...
Have to hurry up so I can mount the cases, cyl + piston and check how high the piston crown will go at TDC. Important for the mechanic working with the head. Need at least CR 10.5:1.
Offline BPellerine
« Reply #21596 on: April 19, 2016, 02:49:58 pm »
had to clean up the holes in my cases too pewe to fit the ha kit,mostly casting flash.bill
1978 CB 750K ard and webers
another anfob
Online PeWe
« Reply #21597 on: April 19, 2016, 10:55:14 pm »
My case is tighter, need to grind a lot to get clearance around the sleeves
Offline jonda500
« Reply #21598 on: April 20, 2016, 07:38:26 am »
Busy today! Gave my 2nd CB500 some attention:
-drained the oil
-pulled off the clutch cover and the sprocket cover, replaced the broken clutch pushrod
-replaced the pushrod seal and the gear shift shaft seal and the oil pump cap o ring
-reassembled everything and filled up with new oil
-removed the carbs, cleaned the fuel valves and set the float levels lower
-replaced the leaky float bowl o rings with shaped ones super glued in at the corners
-set the idle screws at 1 turn out (they were at 2.5 turns out)
-pulled out the needles and put the original ones back in clipped at #4
-reinstalled them on the bike, two carbs pissed out the overflow so I turned off the fuel and drained those two bowls
-then had to do one of them again
-vacuum synced the carbs
-reset the idle screws to 1.5 turns
Took her for a ride, filled up the fuel. After a bit she started to run rich as #$%* dagnammit still! I'm nearly ready to give up on these reconditioned carbs!
On the plus side there are no oil drips under her get ...touchwood.
John
Online PeWe
« Reply #21599 on: April 20, 2016, 12:21:42 pm »
Rode for awhile (72 degrees here) and got tired of hearing that 33 year old factory chain makin noise.  Now I'm sittin in the basement watching the Falcons kick a little a$$ and discovering that these dang thangs have endless (no master link) chains.  Do ya have to take the D#m swingarm off just to replace the chain?????
 How bout a good boltcutter:) ??? ??? ??? :-\
Removing the swingarm is one way.
Most will "cut" the chain by grinding the heads off 2 pins and driving out a link. Most new chains are sold with a peen type master link which requires a special tool or skill to peen over the heads of the pins to make it "endless".
Don't lose hold of the chain after cutting. YOu will hook your new one to it and pull it thru the sprocket.
Many of us just buy a chain with a traditional clip type master link. I'm not afraid.
Back in my racing days we would safety wire the clip onto the masterlink for tech inspection. Never saw one I trusted was properly installed come off.
Agree about a chain with clip. I have never had a problem with clip. Close once since the clip was lost but it held together anyway.
O-ring chain with clip. I liked DID 50HDS back in the 80's
I invested in a really strong chain at last restore. Rivet link, solid link that need powerful riveting tool. I broke one cheap tool first. Ended up in purchase of a Whale riviting and cutting kit that handle solid and hollow links. With a hammer banging the link together so it will look as the other links.
Its not that easy to rivet it together since I did it too hard and a link that was too tight. Order new link and did it again.
I have 4 extra links in my garage.
I do not need to open chain for removing rear wheel or front sprocket or pulling the entire engine.
18-48 sprockets and 100 link 530 chain. CB750K6
Rivet chain with hollow link will be next. I have to since the riveting tool costed me some. Long time to next change
I'll use a spacer next time I rivet. This will avoid rivet too hard and binding link that will look like a Z when driving. NOT good!
Here spacer and hollow link easier to rivet, even with cheaper tools. Buy 2-3 extra master links if chain must be opened.
Photo found in another forum, not mine. I think that EK chain is a OK, but 530 for CB750
http://s982.photobucket.com/user/columandester/media/ChainSpacer1_zps5c22e70d.jpg.html
« Last Edit: April 20, 2016, 12:28:25 pm by PeWe »
