Author Topic: What did you do to your bike today ?  (Read 3270254 times)
Offline Bankerdanny
  • Endeavor to persevere
« Reply #22025 on: June 14, 2016, 10:23:18 AM »
Depends on what you mean by tall. But in the US the bikes came with taller bars than the European SOHC4's and a lot of owners don't like them and go with what is commonly known as superbike bars, which are 2-3 inches lower than the typical OEM US spec bar, but not flat like drag bars or below the triples like clubmans and clip-ons.
I think that the rise on OEM bars is in the 4 inch range
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
  • Holy Cow! I'm a
« Reply #22027 on: June 14, 2016, 01:02:03 PM »
+1 to low rise superbike mgp bars.
Offline TomsK8resto
« Reply #22028 on: June 14, 2016, 04:02:55 PM »
Ordered a new set of handle bars for my '78 750K bike.  The set that came on it were too tall, the super bike bars on it now are too short, so I ordered a set of '69-'71 750 replica bars from 4into1.  Hopefully they will be just right!
Tom
The PO put some cafe' bars on my K4, but included the originals. I was planning to revert back to them.  Were the tall ones stock or aftermarket?  Are they replicas to OEM spec?
The taller bars which came on my '78 cb750K bike were stock on that vintage K bike.  Comfortable, but a bit higher than I liked.  I tried the superbike bars and had problems with my wrists.  They looked great, but were not comfortable for very long.  I found these replica bars at 4into1, installed them, got my cables routed to where everything works smoothly and then rode it.  I like them very much.  They are about 2" less rise than the bars that came on my bike which I think were stock for '77/'78.
Tom
'69 CB750 long gone
'76 CB750F gone
'78 CB750K in progress.....
'09 H-D Roadglide
Offline jamesv220820
« Reply #22029 on: June 14, 2016, 06:07:05 PM »
Added one of these little guys to the cb350f
Question is how hot should the oil be at, at full warmed up ?
« Last Edit: June 14, 2016, 06:09:00 PM by jamesv220820 »
There is nothing to fear but fear itself . . . and trying to restore a cb350f
Offline Schroeder
    • Schroeder Guitars
« Reply #22030 on: June 15, 2016, 06:20:13 PM »
Hows the tone of that rear fender?
Fookin gorgeous!
[/quote]
Ha! Thanks BomberMann650! I think the quilted maple accentuated the mids and gave a nice upper end clarity!! ;)
I got the valves back in after the valve lappage.  Made a ghetto spring compressor with a bar clamp and a cut up piece of copper pipe.  Worked great.  The valve looks scratched in the pic but it is just a bit of grease.
Guitar builder trying to re-build a bike...
1973 CB500k2 with 1978 CB550 motor
  • Holy Cow! I'm a
« Reply #22031 on: June 15, 2016, 07:18:55 PM »
Fookin gorgeous!
[/quote]
Always good to have everything in tune!
Offline joeyvans
  • Definitely not a
  • God's Country, Earth
« Reply #22032 on: June 16, 2016, 09:52:48 AM »
After the camshaft swap, different valve cover install and a 20 mile ride the other day.... I went back and re-checked my tappet clearances.  1 needed further adjustment, so I took care of that.  Turned on the fuel tap and #1 and #2 started spitting out fuel out of the overflows.  I rapped on the bowls a few times, but this didn't correct the problem.  This has never happened to me....  So, I drained the bowls and clear tubed them again.  They checked out good and didn't spit out of the overflows anymore.  Put the drain plugs back on and all is good.  Strange to me that the 1 & 2 floats would get stuck at the same time like that.
Anyways... all was good, so I went out for a warmup ride in advance of re-syncing the carbs as I was experiencing some gearbox chatter.  Carbs synced and went out for another 20 miles... no gearbox chatter and the thing has never run better.  Going out for another 80 miles tonight..... can't wait!
1976 CB550 K2
Non-SOHC4 - 1974 CB450 K7
Non-SOHC4 - 1996 VFR750F
"No matter how much you shake and dance... the last three drops go in your pants."
« Reply #22033 on: June 16, 2016, 09:56:48 AM »
Probably just some debris in your gas.
When bumping the carb back plate doesn't stop the flow, crack open the bowl drain screw, and allow it to flow for a second.
This usually washes out whatever is blocking the float valve.
Offline joeyvans
  • Definitely not a
« Reply #22034 on: June 16, 2016, 10:01:36 AM »
Ah.... thanks for piping in, Fly.  Will remember that for next time..... so I can skip hooking up my 'clear tube' device.
1976 CB550 K2
« Reply #22035 on: June 16, 2016, 10:11:02 AM »
Yeah...if you've checked it good once before, no need.
Offline Bankerdanny
« Reply #22036 on: June 16, 2016, 10:23:53 AM »
Paid for the used stock 550F seat I bought from eBay yesterday. It a local sale, so no shipping, I am going to pick it up Saturday. I paid $100, which I think is fair since a new one would run me at least $200+shipping. Based on the photos the seat is in good shape with one small lengthwise split in the cover that I can likely deal with short-term with black duct tape. Ultimately I will get a replacement cover.
  • Holy Cow! I'm a
« Reply #22037 on: June 16, 2016, 01:39:25 PM »
Whats really fun is when all 4 floats get stuck open because (name redacted) Fuel System cleaner also cleaned any lubricants from the float needle!
« Reply #22038 on: June 17, 2016, 03:53:03 AM »
Or if, like I once did, if you install all your fuel valves upside down because you're drunk............ ;D
Offline Jimbo
« Reply #22039 on: June 17, 2016, 12:24:23 PM »
Started creating a box for the electronics and getting the hoop welded on......Finally
"If you've never owned one you'll never understand"
CB400F
  • Holy Cow! I'm a
« Reply #22040 on: June 17, 2016, 12:28:57 PM »
This is why we need an Epic Fails thread
Offline joeyvans
  • Definitely not a
« Reply #22041 on: June 17, 2016, 12:36:39 PM »
I'm guessing there is one, but if not.... Start one up!
1976 CB550 K2
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« Reply #22042 on: June 17, 2016, 02:23:37 PM »
There's the "that feeling when" thread in the open forum! Always good for paying your blunders.
--Evan
1975 CB750K "Rhonda"
  • Holy Cow! I'm a
« Reply #22043 on: June 17, 2016, 11:20:41 PM »
Back to our voltage regulator scheduled programming!
This bugger was out of spec and causing all sorts of gremlins to come crawling out!
« Reply #22044 on: June 17, 2016, 11:55:25 PM »
you know what dude?...just leave these poor old things alone.  Seriously never had a dead battery on a sohc4 ever, and I have ridden the most junkiest ones imagineable.
« Reply #22045 on: June 18, 2016, 12:05:25 AM »
You've been lucky Sean, I've had heaps of electrical failures on CB750's, usually caused by fried stators and crappy regulator/rectifier combo's, not to mention crispy 40(+) year old wiring, dud coils, dodgy points, coil leads arcing in the wet, etc etc.
When I rebuilt Mike's bike I used all new wiring, switches, new coils and leads etc, and it actually charges the battery, and starts first prod of the button. That's got to be a "lessons learned" for anyone rebuilding a CB750, throw that crappy old wiring away and replace it all with nice new electrics, and you won't be pissed off........... ;D
  • Holy Cow! I'm a
« Reply #22046 on: June 18, 2016, 12:22:59 AM »
I wouldn't have removed the thing for adjustment.  If not for the fact I rode home by moonlight yesterday.  Lights were on, but I've seen farther in the dark with a bic lighter.
I read thru some twotired posts, opened the manual and set to work.  After testing the stator/coil, it turned out the vreg was makin trouble for me.
« Reply #22047 on: June 18, 2016, 12:34:02 AM »
I fix my bikes with hammers...no electrical problems apparently.
  • Holy Cow! I'm a
« Reply #22048 on: June 18, 2016, 12:47:12 AM »
Brute force does solve a number of problems!
« Reply #22049 on: June 18, 2016, 12:50:17 AM »
wtf
DSCN0512 by Sean Barney, on Flickr
DSCN0505 by Sean Barney, on Flickr
DSCN0572 by Sean Barney, on Flickr
DSCN0738 by Sean Barney, on Flickr
DSCN0702 by Sean Barney, on Flickr
DSCN0699 by Sean Barney, on Flickr
DSCN0860 by Sean Barney, on Flickr
DSCN0837 by Sean Barney, on Flickr
DSCN0782 by Sean Barney, on Flickr
jesus christ, fire it up and ride the damn thing
