Author Topic: What did you do to your bike today ?  (Read 3959022 times)
grcamna2 and 15 Guests are viewing this topic.
« Reply #23200 on: December 28, 2016, 03:20:20 AM »
Thanks Terry!  Mike's cafe looks great too.  Hope I can scrounge up a Giuliari seat for one of my bikes someday.
Offline markreimer
« Reply #23201 on: December 28, 2016, 04:32:56 PM »
Lapped my 350f valves but all of them are still leaking, so I made an appointment with my machine shop for new seats cut, and my cylinders honed. It's gonna be a happy bike come spring
Offline Medyo Bastos
  • Gusto mo titi ko?
    • project
« Reply #23202 on: December 28, 2016, 04:34:52 PM »
i tripped over 2 of them on my way out  :o 8 bikes take up too much space, at least that is what my wife keeps telling me
Offline Beergineer
« Reply #23203 on: December 28, 2016, 04:44:33 PM »
Today I trued my wheels, which was as easy as people say. Also ran some parts through the ultrasonic cleaner so I can get this build on the road...
« Reply #23204 on: December 28, 2016, 05:01:33 PM »
Plugging away on putting this disassembled K6 bike back together. The engine came to me with all the covers off and its dirty inside. Gutted out the clutch area for cleaning. Dropped the oil pan and pulled the pump. Good news was no metal, plastic, rubber, illegal aliens or other surprises in the pan just some black sludge on the bottom and the screen on the pump was very clean. One thing of note was the cover everybody likes to break on the clutch has a bearing in it and this one was on the verge of a seize when it was pulled. A good cleaning and oil brought it back to fine shape but would not want to have run it as it was, something for you to think about or check if your doing an engine that has sat for a long time  ;) Similar bearing on the shifter side also.
  Next step will be to pull the cam,rockers, towers etc to give the top end a good careful cleaning and put in some fresh pucks and o-rings where needed. Here is a pic of the top end to show a dirty before, would have been nice if the PO had kept the cover on  ::)  Peering down the cam chain tunnel the rubber roller looks good so that's a plus.
  Luckily the temp was warm today at 39 degrees  :D  so was able to wash/degrease all the external covers and some other bits in my old gas I save from draining tanks. Be glad to get all this cleaning done and put this thing back together and get it in the frame for the next adventure.
Offline Laids
« Reply #23205 on: December 30, 2016, 08:17:11 PM »
Checked the bikes in the shed today, snow on the ground. Brought out a beer and hung around for a while, ahh, waiting for spring here in the great white north.
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
« Reply #23206 on: December 30, 2016, 10:15:17 PM »
I have temporarily revoked my mechanic license.  There is no excuse for cross threading shock eyelets.   :-[
« Reply #23207 on: December 30, 2016, 10:54:37 PM »
nice #$%*ing shed!
« Reply #23208 on: December 30, 2016, 11:54:19 PM »
Well I think I fixed the short on Mike's CB750K2 Cafe Racer today, but fell into a fit of depression when I realised that the oil leak will probably require me lifting the head, so I took my Sportster for a ride to cheer me up. I've been messing with the jetting on the Mikuni flat slide race carb I installed a few months ago, from new it felt lean so I bored the main jet from 160 to 205 (only because I only had one jet drill bigger than 160) and it actually ran pretty well, but I'd since bought some new jet drills, so I bored a 165 out to 180, and adjusted the idle mixture.
I also checked the fuel tap's flow, as in the past it's felt like it was running lean at high RPM, to the point where it'd tap out at 5K RPM, (approx 90 MPH) and I was actually thinking about buying a Pingel petcock, but after filling a 5 litre drum in only a couple of minutes I decided that there was nothing wrong with the OEM tap.
Anyhoo, I took it for a ride, and a few miles down the road, it conked out. Fcuk. I rolled to the side of the road, and checked the fuel level, even though I knew it was half full. I turned the fuel tap lever to "Reserve", turned the key, hit the button, and it fired right up. Hmmnn, weird. I rode another 3 or 4 miles, and it did it again! Fcuk!
Same same, checked the fuel level, played with the fuel tap, hit the button and away I went. Four or 5 miles down the road, I could feel it dying again, so I reached down and loosened the fuel tank cap, and away it went! Blocked fuel cap breather! I rode back home with the cap loose (no issue, it didn't miss a beat) and when I got home I replaced the cap with a new "Drag Specialties" lockable cap I'd bought a few weeks ago, and took off again. No issues for the rest of my ride, so I was glad that it wasn't something more serious. Woohoo! ;D
Offline fire113
« Reply #23209 on: December 31, 2016, 04:29:46 PM »
...sorted some parts...
BTW-> HAPPY NEW YEAR  ;D
« Reply #23210 on: January 01, 2017, 04:05:30 AM »
 ^ That bottle of 'special lube' looks like the hot ticket ! ^
« Last Edit: January 01, 2017, 07:48:34 AM by ekpent »
« Reply #23211 on: January 01, 2017, 05:49:02 AM »
Found in time that I have forgotten to mount the inner collar holding the lower wheel in the std cam chain tensioner. I found cheap NOS parts where this was one of the items. Remembered that I did not mount it. My previous tensioner did not use it (metal wheels with needle bearings).
I'm happy to find out before mounting the pistons with cyl, head, starting it and later find metal flakes in oil....
Offline maduncle
  • Don't confuse me with a
« Reply #23212 on: January 01, 2017, 01:33:42 PM »
Oh man, I reckon we have all had that one happen before - same deal with my CB500 a couple of years back.
Glad you found the fuel starvation problem Terry and I am sure you will have that oil leak in Mikes CB750 fixed in no time - just think of the garage space you will have once Mikes bike is with Mike!
Since my CB750 looks like a hover bike with the front forks out and waiting for fork seals I took the V-Strom for a country ride. The hills roads are covered in wash outs from the rain we had last week, seems everyones gravel drive is on the road now. I did nearly lose it in one of these wash outs but just managed to control the bike through the slippery corner without low siding it!
« Last Edit: January 01, 2017, 01:35:49 PM by maduncle »
CB750K2 (only slightly modified)
« Reply #23213 on: January 01, 2017, 01:47:42 PM »
I've just finished a bottle of Havana Club rum Eric, it's a magnificent drop, I think you should race over to Cuba and set yourself up as the official importer as Bobby was telling me that you can't buy it in the US yet? Now there's an idea mate, get the contract for importing rum and cigars into the US, and you'll make so much dough you'll be able to send me a nice GT750K as a "finders fee"! ;D
« Reply #23214 on: January 01, 2017, 01:53:07 PM »
Yeah I had a similar "pants filling" experience last Friday Cliff, for some reason (maybe as the result of the storm) there was sand all over Plenty Road in Bundoora, and I did a big skid when the rear brake on my Sporty locked up! Luckily the front brake has about as much power as your K2's, (wouldn't lock up on ice) or else I would have dropped it for sure! Hopefully that's been sorted by now, I'm feeling like going for a ride today. (once it stops drizzling) Cheers, Terry. ;D
Offline scunny
  • don't call me expert
« Reply #23215 on: January 01, 2017, 04:51:04 PM »
I've got a very tiny fork seal leak, seals done 2 maybe 3 years ago. made my very own cheap as chips cafe racer fork seal reconditioning tool, seems to have done the job. xcellent. Have done the XL250S as well. one size fits all.  ;D
« Last Edit: January 01, 2017, 04:53:01 PM by scunny »
present-CB 650 retro
            VTR1000F3
           XL250S riverbed rocket
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
           pedal(pub bike) leaks oil
« Reply #23216 on: January 01, 2017, 05:33:26 PM »
Ha ha, well done Scunny, I've got a couple of "motion Pro" items, and they're fcuking useless! ;D
Offline maduncle
« Reply #23217 on: January 01, 2017, 07:53:40 PM »
Speaking of fork seals, I managed to get that "tight as buggery" bottom bolt undone on the one fork leg giving me attitude, so now both forks are completely apart and awaiting new seals.
These top tubes are mint, best I have ever seen.
I think I will put fork dust seals on the lowers this time instead of fitting gators that flop around and let water in the top.
« Reply #23218 on: January 01, 2017, 08:13:03 PM »
Well done Cliff, and yep, gaiters can protect your fork tubes, but they're also very good at holding water. (I hate them, except on original bikes) Cheers, Terry. ;D
« Reply #23219 on: January 02, 2017, 07:14:09 AM »
Went for my annual New Years Day ride yesterday, the weather was great down here in Texas!
Hadnt ridden the Z1 in a while, so he got the nod this year....
« Reply #23220 on: January 02, 2017, 09:58:45 AM »
Just briefly watched a TV segment (but not all) about Havana Club. There are 2 versions: the original recipe sold to Bacardi years ago and produced in Puerto Rico and the newer Havana version. Trade wars. Made me want to find the Cuban version once I land in Costa Rica tomorrow. I'll have 3 months of roaming to locate some. I'll report back on the findings when I return in April.
Offline joeyvans
  • Definitely not a
  • God's Country, Earth
« Reply #23221 on: January 02, 2017, 10:01:58 AM »
Luckyyyyyyyyyyy!!!!
Stev-o.... do you prefer Roadriders for all your vintage bikes? I like them on my 550, but need to decide on rubber for my 450.
1976 CB550 K2
Non-SOHC4 - 1974 CB450 K7
Non-SOHC4 - 1996 VFR750F
"No matter how much you shake and dance... the last three drops go in your pants."
« Reply #23222 on: January 02, 2017, 01:30:23 PM »
Luckyyyyyyyyyyy!!!!
Hey Joey....no, do not have Avons all all my bikes, Also have Bridgestone, Dunlop and IRC, I like to try different rubbers!  Continental also makes excellent tires, I will be buying those next.
« Reply #23223 on: January 02, 2017, 01:37:32 PM »
Why not take a side trip across the Carribean to Havana Jerry? I think I'd like to go there just to drink Havana Club and smoke ceegars! Cheers, Terry. ;D
Offline Tews19
  • I am no
« Reply #23224 on: January 02, 2017, 02:00:22 PM »
Looks great Stev-o! I always wondered how the exhaust sounds on that??? Possible video?
1970 Honda CB750 survivor.
