Author Topic: What did you do to your bike today ?  (Read 3564629 times)
Offline Bankerdanny
  • Endeavor to persevere
« Reply #26500 on: April 17, 2018, 10:17:00 AM »
be care not to klip the thin vires..vho goes through the plastic....use a solder iron..and hold heat on..and press the top part off..at the same time..but try to test for ohm after re solder the  solderpoints..somtime its just a Cold soldering..and some oxyd..and a re heat vill give live..
I'm gonna have to work on that one a little bit Stringbean to decipher your code   ;D ;D
...he he..... make you think....
 ;D
« Reply #26501 on: April 17, 2018, 11:16:51 AM »
...did the tach and speedo for the K2
They look really good!
New faces, right?
New needle or did you paint it?
Any good tool to crimp the rings together without any visible marks?
I have a set of K2 gauges, new faces, rings, o-rings waiting to be done.
« Last Edit: April 17, 2018, 09:48:27 PM by PeWe »
« Reply #26502 on: April 17, 2018, 12:07:05 PM »
be care not to klip the thin vires..vho goes through the plastic....use a solder iron..and hold heat on..and press the top part off..at the same time..but try to test for ohm after re solder the points..somtime its just a Cold soldering..and some oxyd..and a re heat vill give live..
pas på ikke at klip de tynde vires .. hvem går gennem plastik .... brug et loddestang .. og hold varmen på..og tryk på den øverste del af .. på samme tid .. men prøv at teste for ohm efter re loddemåler point.som tiden er det bare en kold lodning .. og nogle oxyd .. og en re heat vill give live ..
Translated back to Danish, does that help, Eric?!
Offline strynboen
    • http://forums.sohc4.net/index.php?PHPSESSID=3fu1vo3kge1tt0pjq7iefscd95&/topic,60973.0.html
« Reply #26503 on: April 17, 2018, 12:29:06 PM »
pas på ikke at klip de tynde vires .. hvem går gennem plastik .... brug et loddestang .. og hold varmen på..og tryk på den øverste del af .. på samme tid .. men prøv at teste for ohm efter re loddemåler point.som tiden er det bare en kold lodning .. og nogle oxyd .. og en re heat vill give live ..try to run it through s german translater..and see if itr klears somthing up...
..hnmmm not qvite the same as i vas vriting in the first place...but the pointe is burning through..i think..try to run it through a german translater..think it vill klear it up..
« Last Edit: April 17, 2018, 12:31:59 PM by strynboen »
i hate all this v-w.... vords
« Reply #26504 on: April 17, 2018, 12:44:07 PM »
Any problem with Hindi?
Clear as sausage broth as we say were I come from.. ;)
पतली तारों को काटने के लिए सावधान रहें .. जो प्लास्टिक के माध्यम से चला जाता है .... एक मिलाप रॉड का उपयोग करें .. और गर्मी को पकड़ो .. और ऊपरी भाग दबाएं .. उसी समय .. लेकिन ओम के लिए परीक्षण करने की कोशिश करें फिर से मिलाप अंक। समय के रूप में यह सिर्फ एक ठंडा टांका लगाना है .. और कुछ ऑक्साइड .. और एक फिर से गर्मी जीना चाहता है .. इसे एस जर्मन अनुवादों के माध्यम से चलाने की कोशिश करो .. और देखें कि क्या इरर क्लेयर ऊपर आ गया है ...
« Reply #26505 on: April 17, 2018, 02:05:13 PM »
  Thanks for the Hindi PeWe. Now I fully understand,Thanks !
« Reply #26506 on: April 17, 2018, 02:34:50 PM »
Ha!   Didnt know you knew Hindi, Eric!
Offline Bankerdanny
« Reply #26507 on: April 17, 2018, 08:31:09 PM »
Confirmed that the starter solenoid is fine, it's just the button assembly that needs repair. I connected the Yellow/red wire from the solenoid to the battery positive and the engine turned right over. I connected an aux tank to the carbs and with some carb cleaner was able to get it to pop and almost start, but couldn't quite get there. I ended up running the battery down a bit, so when I left I hooked it up to a tender to get topped off before I get back tomorrow night.
I also drained the oil and added a couple quarts of fresh. I have a new filter, but didn't replace it at this time since the header is in the way of easy removal.
I attached the top half of the airbox and got the bleeder screw on the front caliper to loosen without breaking.
The sheet metal screw in the rear caliper turns out to be screwed into a broken bleeder, so a project for this weekend will be to pull the caliper and drill out the bleeder and replace it.
« Last Edit: April 17, 2018, 08:32:44 PM by Bankerdanny »
Offline Bankerdanny
« Reply #26508 on: April 17, 2018, 08:34:13 PM »
Mine will turn over when you short across the solenoid. My switch does have the housing,  that's what's left of it in the 2nd picture.
Those 2 pictures look like my bike.............
I see now, I have the harness wrapped to the wrong frame part.
My carb tops hit the wires when opened to full throttle.
Can you post a pix of how the throttle cables are routed?
Thanks
Here you go
« Reply #26509 on: April 18, 2018, 12:50:22 AM »
Beautiful work Georg, well done mate! I was gonna send my gauges to Marcel to restore for me, but now I think I'll give it a go myself! How did you remove/replace those pesky rings mate? ;D
« Reply #26510 on: April 18, 2018, 01:13:31 AM »
sat the 400 for sale.....9000 Danish kroner...made a selfie in the mirror...look a bit kapatain haddock
9000 kroner?whats that equal to?two empty beer bottles and a piece of string?
Offline kghost
« Reply #26511 on: April 18, 2018, 01:26:11 AM »
Denmark, Norway, Sweden, Greenland, and the Czech Republic all use Kroner or Crown...so I guess it depends...in Norway it 1 to .17 AUD...9000=1530 AUD
Stranger in a strange land
« Reply #26512 on: April 18, 2018, 01:28:42 AM »
good price for a four hundred,ill keep my beer bottles then!
« Reply #26513 on: April 18, 2018, 02:54:35 AM »
I drain my economy with help of:  Yen (Yamiya), Pounds (DSS, eBay and some shops),  Euro (eBay Europe + car, oil and bike shops) and US dollars (eBay and all bike related guys).
Vacations mostly Euro. I have no SEK in my wallet at all, always card or transfers via telephone or internet bank.
Offline kghost
« Reply #26514 on: April 18, 2018, 03:27:10 AM »
Happens to us all....
Offline Yamahawk
  • IGOR!Come here IGOR! ...Yesss
  • 1971 Honda CB750 Four K1
    • Kingdom Run Biker Church and Outreach
« Reply #26515 on: April 18, 2018, 03:57:42 AM »
Thanks
Here you go
Danny, better fix that push/return cable, it's coming out of the linkage mount. Happened to me several times. :D
Charlie
1971 CB750K1 (newest bike), 1996 Royal Enfield 500 Bullet (therapy bike), 1981 Yamaha XV920RH, 2006 Kawasaki Concours (retirement bike), 1975 Yamaha RD350 (race bike), 1989 Honda VTR250 Interceptor (race bike), 1986 Kawasaki EX250 Ninja (race bike in progress), 1985 Honda Elite CH250, 1973 Yamaha GT1 80cc, 1974 Yamaha DT360 project bike.
The Only Thing Necessary for Evil to Triumph, is for Good Men to do Nothing.
Edmund Burke
All Things work together for good, for those who love God and are the Called according to His purpose.
Romans 8:28
Though He slay me, Yet will I trust Him...
Job 13:15
will you trust Him...?
Offline WhyNot2
  • I'm finally an
« Reply #26516 on: April 18, 2018, 04:20:58 AM »
Thanks
Here you go
Thank man...........is that the factory routing or did you reroute them yourself?
Not sure I can get the top cable to go under the coil like that.
I'll give it a shot tonight when I get home, after these God forsaken hours they keep us here at work.
Mine just feel so stiff, doesn't snap back on it's own.
Offline Bankerdanny
« Reply #26517 on: April 18, 2018, 04:36:11 AM »
That's how they were routed when I got it. I don't know if that is how they came from the factory.
Offline Yamahawk
« Reply #26518 on: April 18, 2018, 04:54:58 AM »
Not sure if that is the way it came from the factory either, Danny. But, one thing I did notice is the angle of the push/return cable is contributing to it being pushed out of the mounting flange on the linkage. It would be better to route it for a straighter approach (higher angle) to the linkage. Do you see what I am referring to in your picture? Perhaps running it above the coil or in the same plane as the other cable, would fix that leverage problem...
Charlie
Edmund Burke
Romans 8:28
Job 13:15
Offline BRG-BIRD
« Reply #26519 on: April 18, 2018, 04:56:23 AM »
Slowly reassembling the 550 as parts come in, just put in the airbox and air filter holder in last night.
“You are either on something or onto something.” The Comman Man
« Reply #26520 on: April 18, 2018, 04:59:21 AM »
Both throttle cables go under the coils and if you look at the front round rubber tank mount on that side in the pic there is a plate/bracket under it next to the frame that the cables route through also.
« Last Edit: April 18, 2018, 05:23:37 AM by ekpent »
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« Reply #26521 on: April 18, 2018, 06:36:32 AM »
This is a capture from the shop manual. The return cable goes over the coils, apparently.
--Evan
1975 CB750K "Rhonda"
Offline Yamahawk
« Reply #26522 on: April 18, 2018, 06:49:38 AM »
+1 for going over the coil with the return cable.
Charlie
Edmund Burke
Romans 8:28
Job 13:15
« Reply #26523 on: April 18, 2018, 06:51:18 AM »
 Thanks for posting that Evan and correcting me. Seemed to fit well but I assumed again  :D  Looks like I have a little redo to do  ;)  Now what the heck is going to that bracket ?
« Last Edit: April 18, 2018, 07:00:20 AM by ekpent »
Offline evanphi
  • Apparently I'm an
« Reply #26524 on: April 18, 2018, 07:05:43 AM »
Thanks for posting that Evan and correcting me. I assumed again  :D  Looks like I have a little redo to do  ;)  Now what the heck is going to that bracket ?
I have a re-do to do too! (say that five times fast!)
I have no idea what those lines are the go through the brackets. Maybe the coil connections?
Here's the whole pages:
--Evan
