Author Topic: What did you do to your bike today ?  (Read 3287192 times)
Offline newday777
« Reply #33125 on: August 23, 2024, 01:45:01 PM »
That is Amazing John
Stu
My current rides
Prior bikes....
Offline BenelliSEI
  • 1969 cb750
« Reply #33126 on: August 23, 2024, 02:30:30 PM »
Thanks Bill. I’m very pleased. Kudos to my buddy Terry, he’s really good at this sort of thing.
« Reply #33127 on: August 23, 2024, 04:13:19 PM »
Built a new seat (using the original seat pan) for the S/C!
Looks fantastic John, much better than my aftermarket seat. When I win the lottery I’m going to buy a Yamiya replica for mine, it’s doubtful I’ll ever find an original like yours. ;D
Offline grcamna2
« Reply #33128 on: August 23, 2024, 04:43:14 PM »
John, that does look very good.
How firm is the red foam to compress when installing the cover ?
Offline BenelliSEI
  • 1969 cb750
« Reply #33129 on: August 23, 2024, 05:37:22 PM »
Bill….. it was almost impossible! The Yamiya cover has absolutely no stretch at all. It took two of us to compress the foam enough to get the cover to pull down to the stitched seam, all the way around. The cover is a perfect replica and a perfect fit. Once in place it looks great. On the website Yamiya mentions this and suggest “professional installation” is required. Fortunately my friend is just that and had all the correct tools for the job. Even the strap is exactly the correct length. No trimming or waste, we had to use the entire length for a perfect fit. Not a job for the inexperienced.
Offline BenelliSEI
  • 1969 cb750
« Reply #33130 on: August 23, 2024, 05:40:23 PM »
Terry….. it was a bonus day. The ignition switch from Steven V. arrived as well. I have not tested yet, but it looks absolutely perfect! Thanks for the help on that detail!
« Reply #33131 on: August 23, 2024, 05:55:27 PM »
No worries John, I’m glad it all worked out for you, your sandcast is going to be perfect! ;D
Offline newday777
« Reply #33132 on: August 24, 2024, 08:51:03 AM »
Yesterday I rode the K5 into town to get a couple things at the hardware store, then a stop at the grocery store for some oatmeal. On the way home I had to downshift for a couple of turkeys that decided they wanted to cross the road, the 1.5 year old 4into1.com, less than 2,000 miles short clutch cable popped out of the lead feral at the lever, no clutch.....OK speed shifting comes in handy to get home. I had a NOS stock clutch cable that with so rerouting works with the Euro bars until the replacement (not from 4into1.com!)
Stu
My current rides
Prior bikes....
Offline Rookster
« Reply #33133 on: August 24, 2024, 12:55:53 PM »
John,
That seat looks fantastic.  Great work.
Scott
Offline BenelliSEI
  • 1969 cb750
« Reply #33134 on: August 24, 2024, 01:36:34 PM »
John,
Scott
Scott…. Appreciate your comment. Thanks! Looks good on the bike too (spare K1 tank fitted).
« Last Edit: August 24, 2024, 01:39:19 PM by BenelliSEI »
Offline fire113
« Reply #33135 on: August 25, 2024, 03:40:40 PM »
...rode the K2...
« Reply #33136 on: August 31, 2024, 10:49:28 PM »
Spotty and I had a good day tinkering on my K0 yesterday. I was hoping we'd get it finished, but of course everything takes longer than you hope. We replaced the sump pan with the stripped threads with another one I found in my garage, replaced the aftermarket crappy Chinese rear shocks with genuine Honda "Black tops" that are either K0 or K1, but look more authentic.
We dropped the needles a notch on the carbs as I raised them when I first bought the carbs from a well known "Expert" who didn't install the gaskets under the carb tops before I realised that he'd fcuked up and that was why it was running lean, and installed new ones, but didn't drop the needles, thinking that a slightly richer condition wouldn't hurt with the free-er flowing K&N filter and Delkevic 4 into 1, but it did run a bit rich regardless.
We reinstalled the oil tank, chain and chain guard, carbs and airbox, brake, gear and kick starter pedals, clutch cable and cover, and filled it with fresh oil, and by that we'd had enough, so next time I go over we'll install the coils, the new Yamiya pipes, fill the tank with fresh fuel, and call it good. Hopefully it'll run as well as it did with the Delkevic pipe, and as it's the first day of Spring today, the weather should be getting nicer for some rides leading up to Christmas. ;D
K0 Saturday 31 August 2024 by Terry Prendergast, on Flickr
« Last Edit: August 31, 2024, 10:51:25 PM by Terry in Australia »
Offline newday777
« Reply #33137 on: September 01, 2024, 02:57:08 AM »
That's some great progress Terry and Spotty.
Stu
My current rides
Prior bikes....
Offline BenelliSEI
  • 1969 cb750
« Reply #33138 on: September 01, 2024, 07:31:50 AM »
Terry and Spotty….. Amazing what you accomplish in one day!! That bike looks so right. Stunning.
P.S. I like Scotty’s shop. I would be very comfortable there.
Offline fire113
« Reply #33139 on: September 01, 2024, 11:08:11 AM »
...@ project 1 I did the front fender and the brake caliper with arm and brake lines.
Put the seat locks back togeter after sandblasting and fresh 2K paint job.
Found out that I miss the 8x25 blots  :P
@ projekt 2 put the seat lock too.
Looking good Terry, what vin do You have there ?
Have a good one...Georg
« Reply #33140 on: September 01, 2024, 03:06:01 PM »
Thanks guys, I'm really looking forward to riding it again soon. Still can't work out why it started running on 2 cylinders last year, when we brought it over to Spotty's place it started on the 3rd kick and ran on all four. I guess we'll see how it runs when it's back together again. Georg, the VIN is 102XXX (because I can't remember off hand the rest of it) but an expert here in Oz told me that it's a 1/70 build. ;D
Offline Magpie
« Reply #33141 on: September 05, 2024, 09:36:59 AM »
Yesterday, I went through the carbs on my K3 then tried to balance them. The gauges were at 10 for all 4 then #4 had a slight stumble and the reading dropped for a bit then came back to 10. Must be time for new manifolds. It has good throttle response. Road test today.
« Reply #33142 on: September 05, 2024, 07:02:43 PM »
Best on the road test/ride…glad everything is looking good, pretty bike…
Offline BenelliSEI
  • 1969 cb750
« Reply #33143 on: September 10, 2024, 09:40:52 AM »
Cliff…. looks very nice indeed!
Offline BenelliSEI
  • 1969 cb750
« Reply #33144 on: September 10, 2024, 09:42:07 AM »
Finished it and rode it!
Offline grcamna2
« Reply #33145 on: September 10, 2024, 12:53:59 PM »
John !  :)  The sandcast is looking good  8)
How did it ride ?
Offline M 750K6
« Reply #33146 on: September 10, 2024, 03:00:42 PM »
Superb. Love the sun fade on some of the original paint. Characterful and beautiful.
Offline BenelliSEI
  • 1969 cb750
« Reply #33147 on: September 10, 2024, 03:36:41 PM »
How did it ride ?
Better than I could have imagined. Like a new bike!
Offline BenelliSEI
  • 1969 cb750
« Reply #33148 on: September 10, 2024, 03:37:56 PM »
When I started this project “Frank” begged me to leave it alone. He was right.
« Reply #33149 on: September 13, 2024, 02:57:41 AM »
yeah theres something about original faded paint that appeals?only factory once,i got Kghost to supply and fit another sport demon rear for me other day,Tim dont rush the strip out or refit and it may seem like only fitting a tyre but great attention to detail,he has a pair of early 550s in his shop right now and one of those weirdo 650s,boy the top end on those is ugly,wish my 550 had the same power though!
