Author Topic: What did you do to your bike today ?  (Read 3273593 times)
Offline fire113
« Reply #33200 on: November 03, 2024, 03:55:23 AM »
...please show me a picture, made with an digi cam that can catch the candybluegree color spectrum.
Here You can see 2 paint jobs that I did by myself, the candybluegreen K0 is the only picture that is looking not simple blue but still fare fare away from the original color spectrum.
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #33201 on: November 03, 2024, 06:45:47 AM »
I find that most phone cameras don't portray candy blue green properly, most of the green part isn't there.
1973 CB 750 K3
10/72 build Z1 Kawasaki
« Reply #33202 on: November 04, 2024, 09:02:06 PM »
I agree, the blue/green is difficult to see online.
 I'm swapping to Drag Specialties marker lights on my old Rat Race bike. Stockers look odd on this one and I feel the need to run turn signals, so I re-cycled some old parts and added a pair of new lights.
« Last Edit: November 04, 2024, 09:06:05 PM by Don R »
Offline spotty
« Reply #33203 on: November 22, 2024, 06:09:33 PM »
My 6" over swingarm turned up from Canadia so I've taken advantage of the hottest day so far this spring ( 37C or close too 100F in measurements of the dead ) to fit it. Got all the old stuff out , having cleaned and greased everything when I first put it together made this the easy bit.....
New one went into the frame pivot point easily enough but when I tried to get the wheel back in, no go.
FCUK
The open end of the swingarm is only 240mm whereas the K7 one I took out is about 265mm.
I'm hoping I can machine both outer spacers to get it in but I'm going to have to be careful getting the chain to line up.
Did K7's have a different spacer set up or something to allow the 630 chain to line up differently ?
I've got some spare spacers to mess around with or I might go get an aluminium rod off appropriate size and make some new ones but I might wait for the all knowing Terry to have a look before I start cutting stuff up
Also spent nearly two hours driving round looking for an open bearing shop as I thought while I have the wheel out I may as well put new double seal bearings in. Apparently no one sells bearings on a Saturday.
Looks like it might be time for some day drinking
i blame Terry
Offline spotty
« Reply #33204 on: November 22, 2024, 06:24:43 PM »
Just checked a K2 swingarm and that is also 240mm so it would seem the K7 wheel is a bit special needs.
I'm sure it can be made to fit , maybe I'll try  and find the spacers from the K2 swingarm and wheel and see if I can get it all to go together
i blame Terry
Offline spotty
« Reply #33205 on: November 22, 2024, 06:31:48 PM »
Well there we go, K7 spacers on the left, K2 on the right,  still not 20mm difference but I see the way forward
Unless anyone knows better ?
The K7 axle is also 20mm longer than the K2 ones
« Last Edit: November 22, 2024, 06:34:09 PM by spotty »
i blame Terry
Offline newday777
« Reply #33206 on: November 22, 2024, 06:40:12 PM »
I think the difference is the K7 sprocket carrier is wider,  for the 630 chain. I don't remember if the axle spacers are different from the pre K7.
Stu
My current rides
Prior bikes....
Offline grcamna2
« Reply #33207 on: November 22, 2024, 07:07:20 PM »
spotty,I looked-up both the K2 and K7 rear wheels and the 'good' is they both have the same pt.# inner spacer in the hub between the bearings.  :)
« Reply #33208 on: November 22, 2024, 09:22:01 PM »
yup, you just need k1-k6 sprocket carrier
Offline spotty
« Reply #33209 on: November 23, 2024, 12:05:46 AM »
Luckily I have one of those, probably bad luck for whoever gets my Henry Abe wheels.
I gave up due to excessive heat but tomorrow is another day
Next problem is that the rear wheel is now about an inch from the back guard, I'll try the shock extension pieces I've got but it may require longer shocks.
Thanks to everyone for their words of wisdom
Cheers Spotty
i blame Terry
« Reply #33210 on: November 23, 2024, 08:22:51 AM »
Cheers Spotty
For the record, 630 chain is the same width as 530 chain, 3/8". The pitch is different: 6/8" vs 5/8". On the K7/K8 F2/F3 engines, the sprockets are about 10mm further out than the earlier engines, with the sprocket carrier on the wheel to match. If you have a K7 engine, you will need the K7 carrier to keep the chain in alignment.
Offline spotty
« Reply #33211 on: November 23, 2024, 06:08:38 PM »
Well it's back together, the chain lines up, still using the K7 carrier, the chain side spacer from a K2 and a new alloy spacer on the brake side which will be redone later when I can get the right thickness alloy bar and a 20mm drill
The main problem now is the wheel is still too close to the guard so that means even longer shocks or weld on new shock mounts further up the swingarm, which would also enable me to use shocks with normal eyes on the bottom
i blame Terry
Offline wolf550
« Reply #33212 on: November 24, 2024, 04:49:18 PM »
got the blank made for starting a batch of finned oil cap covers.
74' CB550 (Sold)
71' CB500/550 (Sold)
Offline wolf550
« Reply #33213 on: November 24, 2024, 04:50:37 PM »
still working on the fins placement
74' CB550 (Sold)
Offline wolf550
« Reply #33214 on: November 24, 2024, 04:51:47 PM »
after this going to see about making one of these
74' CB550 (Sold)
Offline spotty
« Reply #33215 on: November 24, 2024, 05:25:47 PM »
it was indeed a good day for day drinking, went to the dog park with my labradane Clare and to my immense delight the tennis club next door finally have their bar open with a gate that opens onto the dog park. very civilised
i can see some very relaxed summer evenings ahead
i blame Terry
« Reply #33216 on: November 24, 2024, 07:16:27 PM »
 It was in the 50's F here, so I rode the gas out of the Louisville Bike and the Rat Race. Both are 72's except the Rat Race is really a K1. I'm getting good at how far they go with the petcock turned off.
Offline wolf550
« Reply #33217 on: November 25, 2024, 05:16:17 PM »
got the fins made and going to give it a try tomorrow for a sand mould
74' CB550 (Sold)
Offline wolf550
« Reply #33218 on: November 25, 2024, 05:17:08 PM »
if it works i can start rounding the fins and a polish
74' CB550 (Sold)
Offline bert96
  • past ride
« Reply #33219 on: November 25, 2024, 05:34:12 PM »
 How the cap is going to stay in place? You glue it in place?
 Bert
QA50 1969,ST-90 1974,mb5 1982,rz350 1983,shadow 1100 1985,vf1000f 1985,BMW K1 1990,shadow tourer 1100 2001,vfr 750 1994,vtr250 199?
Offline wolf550
« Reply #33220 on: November 26, 2024, 01:45:28 PM »
either a glue or adhesive material. mayber neodymium magnet drilled in the middle
74' CB550 (Sold)
Online RAFster122s
« Reply #33221 on: November 26, 2024, 01:52:36 PM »
Can't drill neo magnets, toxic materials, can buy them with beveled hole in magnet. Neo magnets generally are plated or coated. FWIW
Offline newday777
« Reply #33222 on: November 26, 2024, 02:08:14 PM »
I took it as he would drill in to the aluminum and epoxy the magnet into the cap to hold the aluminum to the steel ring of the cap.
Stu
My current rides
Prior bikes....
Offline wolf550
« Reply #33223 on: November 27, 2024, 11:55:03 AM »
yeah like that newday the thin metal cap formed onto the dipstick tightly unlike these caps im working on. I would have to find something to keep it attached to the dipstick so throwing some ideas out there maybe a bolt that the cap would screw on would be nice.
74' CB550 (Sold)
Offline Gurp
  • I'm no.......
  • Once was a...
« Reply #33224 on: November 27, 2024, 12:03:22 PM »
Wolfe those are looking great.
If you did do a hidden stud in the cap to screw on a dipstick what would be the chance of the dipstick unthreading and falling off?
Sent from my LE2127 using Tapatalk
slow Progress 74 cb550.
Poor boy chop 73 CB500 chop
Future project 77 Cb750 Amen Savior
