Author Topic: What did you do to your bike today ?  (Read 3208763 times)
Offline mjstone
  • I'm definitly not a
« Reply #7750 on: September 29, 2011, 05:02:17 PM »
I finally got to pull the engine out! Hopefully I'll get to open it up soon.
I even talked the wife into letting me work on it in the house!
Some of us have wives that are definitely keepers. ;)  Mine let me bring the whole bike in the house last January.  She was the one that suggested it! ;D
MJ
1972 CB500Four (Honda)
1973 CB500Four (Oliver)
Offline mjstone
« Reply #7751 on: September 29, 2011, 05:05:22 PM »
On the CB500 I'm restoring, I installed the sprocket cover, RH side cover, clutch cable & lever, front pegs, rear brake lever. 90% done!!!
Is this the one that got the brake shield that I sent you?
MJ
Offline Elpresidente
« Reply #7752 on: September 29, 2011, 05:36:01 PM »
Ordered new condensers/points, clutch cable and some other assorted o-rings and gaskets...  She gave up the ghost today, needs some tlc.
'73 CB500
'12 Triumph Thruxton
Offline CycleRanger
  • No comment about being an
« Reply #7753 on: September 29, 2011, 07:53:50 PM »
The wood floors aren't real. I'm going to build a mount to hold it. My fun room just entered a new level of fun. Now it's time for me to go ride around bikes blues and bbq and yell over all the "life saving" noises. I have to keep an eye on my tach on the beemer so I know it's still running.
Aww man, wish I was down there on Dixon street!  I've got some friends performing on the main stage.
Offline yellowbirdrs
« Reply #7754 on: September 29, 2011, 09:43:36 PM »
Mount the tires and rims, start to warp the header, choose the seat upholstery and some photoshop to add some color to the side
« Last Edit: September 29, 2011, 09:47:30 PM by yellowbirdrs »
X/A
Summer 2011
Offline ABikeNamedTrouble
« Reply #7755 on: September 29, 2011, 09:58:24 PM »
Today I
- repaired an oil leak out the bottom of my alternator cover
- attempted to repair an oil leak from my pressure sensor (we'll see tomorrow if it actually worked)
- established that I'm going to need my dremel, and a little more motivation, to get my oil pump off so I can replace the leaky O-rings
- synced my carbs
- Adam
1980 CB650c Custom
Keihin PD mechanical carbs
Stock air box and 4-4 exhaust
http://forums.sohc4.net/index.php?topic=97504.0
Offline Radam
  • taco racer
« Reply #7756 on: September 30, 2011, 07:04:48 AM »
What band do you know that's playing? I may go check them out. I may go test ride some expensive bikes that I'll never be able to afford in a little bit.
KingCustomCycles.com
« Reply #7757 on: September 30, 2011, 07:45:50 AM »
Rode my 69 K0 home at 80 mph to beat a thunderstorm.  First time the old girl has been out on the open highway since the valve job.  Breathtaking.
Offline Really?
« Reply #7758 on: September 30, 2011, 08:00:38 AM »
Ordered some number plate and side cover decals.  Three of them are #1 and two say 50.
The Wife's Bike - 750K5
The Kid's Bike - 750K3
Offline Tugboat
  • Puppet
    • PseudoMoto
« Reply #7759 on: September 30, 2011, 08:02:14 AM »
@MJStone - indeed it is! Now I'm waiting on carb kits.... :(
Offline Really?
Offline tango911
« Reply #7761 on: September 30, 2011, 08:22:15 AM »
Indeed!
CURRENT STABLE:
1969 Honda Dream 305 (black)
1974 Mach III kawi 500 smoker
K2 (project)
K2 Original fixer up
K0 original fixer up
2006 CRF250R
Offline Mercuno
« Reply #7762 on: September 30, 2011, 02:51:23 PM »
Love that show...Finished my swiss cheese.
Offline RustyStuff
  • If it aint broke, Fix it till it Is.
« Reply #7763 on: September 30, 2011, 03:28:42 PM »
If all goes well it will be running for the first time in 20 years by the end of today.
'80 CB650
Offline fire113
« Reply #7764 on: September 30, 2011, 03:44:12 PM »
...rebuild the master cylinder on my, now I can go on with the front break.
« Reply #7765 on: September 30, 2011, 03:51:08 PM »
Looking good!
Parked the bike, got my bow, opening day tomorrow  :)
Offline hoodellyhoo
  • CB350F
« Reply #7766 on: September 30, 2011, 03:54:35 PM »
So I didn't really do anything to the bike but I bought a facemask and glove liners to stay warm for my early morning ride to the slimey crud run.
Offline steam-powered man
  • Not the eggman, Not the walrus, I am the
  • Where are you going? I was going to make Espresso
« Reply #7767 on: September 30, 2011, 04:23:47 PM »
forks are fully disassembled and cleaned (had to drill out one allen).
-- ordered fork seals and motul fork oil
-- started sanding/polishing fork lowers
-- my DID aluminum/shouldered rim came in (oem on 76 cb750A), i found it on ebay.  rim as described (will polish up easily) but spokes need more work than i anticipated.  fooey!   >:(
searching for a dr350se
Offline dhall57
« Reply #7768 on: September 30, 2011, 04:55:29 PM »
Rode the KO to work on Thursday and the K6 today.
1970 CB750KO
1971 CB500KO-project bike
1973 CB350G- project bike
1974 CB750K4-project bike
1974 CB750K4
1976 CB750K6
1977 GL1000
1997 Harley Wideglide
Offline Steven.Burns
  • Beer and Bikes
« Reply #7769 on: September 30, 2011, 06:10:17 PM »
I finally decided to order my long needed Barnett clutch kit and a new stator cover off of ebay. One step closer to riding motorcycle   :D
1978 CB750F3 -Scrambler/ tracker or something of the sort  http://forums.sohc4.net/index.php?topic=97025.msg1083788#msg1083788
Offline Greggo
  • Somebody's
  • Helmets Save Lives. Period.
« Reply #7770 on: September 30, 2011, 06:39:18 PM »
Put together a scary $1k parts list to get the new bike where I want it...
Offline CycleRanger
« Reply #7771 on: September 30, 2011, 07:44:03 PM »
Replaced all the spade connectors and the molex plug on the pigtail from the alternator.
The old connectors were fatally corroded.
Small wonder the battery wouldn't charge.
Then I installed a solid-state voltage regulator. I used a VR124 (for the '76 Porsche...)
I might clean up the mounting later, I just stuck it in there Q&D.
It works great! Thanks to everyone in the "cheap regulator" thread!
Tomorrow.....I ride!  :)
« Last Edit: September 30, 2011, 10:11:42 PM by CycleRanger »
Offline RustyStuff
« Reply #7772 on: September 30, 2011, 10:05:59 PM »
Ran It for the first time in 20 years. Greased the swingarm.
'80 CB650
Offline fire113
« Reply #7773 on: October 01, 2011, 06:00:23 AM »
...mounted the front break and steel break lines, finished the K0 to 99,5%
Took off the carbs & air filter from the next K0.
Offline illrational
« Reply #7774 on: October 01, 2011, 10:25:01 AM »
Is that all? I dont even want to add up what ive spent since i bought this bike and im not even close to riding it but i have to make sure i have a godo foundation before i even think of modding anything...oh im sorry didnt address the question....
i got my dial gauge in mail with no instructions and ordered a cylinder bore gauge....trying to find specs on my 77 cb550k concerning run out spects for my crank and camshaft
« Last Edit: October 01, 2011, 10:26:50 AM by illrational »
