Author Topic: What did you do to your bike today ?  (Read 3578530 times)
0 Members and 12 Guests are viewing this topic.
Offline jvandyke
« Reply #6275 on: May 16, 2011, 05:04:30 AM »
Put it back together after repaint tins and fork seals/boots/polish, repainted badges.  Quick picture, sorry for the clutter.  Better ones to follow.  Took two kids for quick rides.
1972 CB500, 7500 miles, in family since '73
Offline Greggo
  • Somebody's
  • Helmets Save Lives. Period.
« Reply #6276 on: May 16, 2011, 10:37:25 AM »
Nice.
Offline gnarlycharlie4u
  • Far from being an
« Reply #6277 on: May 16, 2011, 10:38:49 AM »
cleaned the lower engine case (hooray simplegreen)
...and also managed to put a gouge in it :(
Offline westondc
  • Wes Mantooth
« Reply #6278 on: May 16, 2011, 01:38:15 PM »
replaced both front and rear rubber with Duro classic vintage tires... which look pretty rad. cleaned the front forks with Nevrdull. gas'd her up and hit the road!
« Last Edit: May 16, 2011, 01:39:50 PM by westondc »
B.O.X.N.I.F.E. Hospital fund https://www.everribbon.com/ribbon/view/8352
Rider no. 115 on the 2012 SOHC/4 Honda World Tour
Rider no. 274 on the 2011 SOHC/4 Honda World Tour
1972 Honda CB500k1
1971 Honda CB350k3
the project http://forums.sohc4.net/index.php?topic=64499.0
Trip/Project Blog http://easterntowestern.blogspot.com/
just be a vagabond, living out of a backpack on a little Honda, cruisin all over the damn place....
"As your attorney, I advise you to buy a motorcycle. How else can we cover a thing like this righteously?"
Offline fire113
« Reply #6279 on: May 16, 2011, 02:12:52 PM »
...started to polish the pipes
Offline Greggo
  • Somebody's
« Reply #6280 on: May 17, 2011, 01:05:27 AM »
Put on my new rear wheel with fresh bearings, and a new 34 tooth sprocket.  New tsubaki 530/98 is soaking in a bag of oil; that will go on in the morning, along with a new front sprocket, and a freshly black painted sprocket cover.
I didn't know the wheel was from a 77-78 550 when I bought it, didn't even know that mattered.  So, I bought a later brake panel, and corresponding spacer to get everything to fit.
Oh!  I did a nice cross hatching on the brake hub before I put new shoes in there too.
Markcb750
« Reply #6281 on: May 17, 2011, 01:49:31 AM »
What do you use to polish?
Mark
Offline fire113
« Reply #6282 on: May 17, 2011, 03:30:49 AM »
Mark
Hi Mark,
NEVR-DULL and/or LUSTER-Pads but be careful with the NEVR-DULL! in the polish wool are steel particles and if You are using to much pressure it will do light scratches to the chrome.
Have a good one...Georg
Markcb750
« Reply #6283 on: May 17, 2011, 04:04:06 AM »
Looks good, thanks
Mark
Offline thrutheframe
« Reply #6284 on: May 17, 2011, 05:34:21 AM »
Yesterday I rented a storage space so I dont have to keep covering my bikes with tarps and and leaving them sit in the rain.  My shop space is less than ideal for bike storage, its on the 2nd floor of a warehouse with no access to the street unless you put the bike on a truck and lift gate it down.  I was able to get the Honda inside last night but when I rode there on my Kaw my code wouldnt work.  Im sure it was some stupid mistake, I'll be getting the Kaw inside later today.
  Yesterday I also finished my clutch lever and most of my front master cylinder.  I'm going to post pics on my build thread in just a few.
http://forums.sohc4.net/index.php?topic=83981.0
'74 cb 750 K4
'75 CB 360T
'90 RC31 Hawk GT
Offline myhondas
  • Not really such a
« Reply #6285 on: May 17, 2011, 07:43:49 AM »
Looks good, thanks
Mark
Mark,
I have been using Turtle Wax Chrome Polish and have had NO problems with it. It does a great job on chrome.  Others swear by Mothers. I have not used it, but would not be hesitant to try it. For other metals, I swear by Flitz.
1974 CB 750 K4 SHOWROOM
1965 C100 CUB 50 (PIT BIKE)
1996 VF 750 CD daily rider
SOHC# 5105 11228
« Reply #6286 on: May 17, 2011, 08:40:22 AM »
Started it up and took it up and down our road several times.  Everything was fine and dandy and than suddenly I felt it lost power.  Pulled in the driveway and sure enough it would not idle.
Took it to the shop and it eventually started but the #4 - all the way to the right - is running much hotter than the rest.  Anyway took out PAMCO, cleaned the T|F|  marks and checked and adjusted timing.
Now for #4 - I think it is in the carb.
Interesting thing - with the air filter off if I hold my hand on the suction of every other cylinder  it just slows the engine a bit. but if I close the intake on the #4 it shuts down the engine.
Am I just an idiot and only the #4 is running?  Suggestions appreciated, next action when I buy new tachometer cable.
Offline fire113
« Reply #6287 on: May 17, 2011, 03:15:39 PM »
...finished the pipes and cleaned the carbs with ultrasonic.
Offline myhondas
  • Not really such a
« Reply #6288 on: May 17, 2011, 08:49:47 PM »
Changed oil & filter, adjusted chain, found #4 header was loose & leaking so got that fixed up. Proceeded to screw up the rear fender tire pressure sticker by seeing if I could attach the rally flag to the bike. Still have to hook up a power tap for the video camera so that I can record some of the rally ride on Fri & Sat. Did a rubber to rubber check of the bike to make sure all was ready for the meet-up on Fri.
SOHC# 5105 11228
« Reply #6289 on: May 17, 2011, 09:05:08 PM »
with stomach flu running rampant overnight thru our house, my 8 year old son and i took turns reinacting The Exorcist all night.
Called in sick at 5am.  slept till 8.  felt pretty good.
Finally...SUN!  and, i got the day off!!!!   :P
had a shop in town pull my front bearings for a few bucks cashmoneys.
didnt have a bearing puller and the anchor bolt method had nothing to bite on.
installed new all balls kit fresh from the freezer.  polished all bits individually as they went back on the front wheel.
cleaned up front rotor w brake cleaner. put wheel back on. bled front brake.
started up and rode until dinner  8)
it was a good day.  ;D
Offline Bankerdanny
  • Endeavor to persevere
« Reply #6290 on: May 17, 2011, 10:31:45 PM »
Solved the missfiring problem (loose wires at the 1-4 points) rode it for 40 miles to test it out and then shined up the chrome to clean up from the rain Saturday during the Chicago stage of the relay.
Offline bjatwood
  • I never claimed to be an
  • 1973 CB750-K3
    • Minbikers Proboards
« Reply #6291 on: May 18, 2011, 06:00:41 AM »
Installed new plugs last night (NGK's) Old NGK's looked like black toast. I will be pulling the carb rack after I "read" the new plugs at the 100 mile mark, Just to give me a starting point to go on.
I saw that Carb #3 is leaking a bit at the overflow, so I'm sure the float levels are wrooonnnnngggg. Thus the reason why it loads up at idle so much, freeway speeds = runs good, around town, not so much.  :P
Brian
#24193
I believe that the Finest things are the most thoughtfully made, not the most expensive!
http://minibikers.proboards.com/
Offline motocyconomad
« Reply #6292 on: May 18, 2011, 11:57:21 AM »
rode it.... I'm on it till I address that stupid Nissan Frontier wanting to stall at a stop.
Offline Greggo
  • Somebody's
« Reply #6293 on: May 18, 2011, 02:55:51 PM »
Pressed on the master link plate on my new Tsubaki, popped the clip on in the correct direction with no problem.  Had to borrow my neighbor's motion pro chain breaker kit to press the plate on..what a difference the right tools can make!  Adjusted the rear wheel/chain slack as well as I could without someone to sit on the bike.  Put my sprocket cover back on, went for a test run..#2 wasn't firing--bad plug. Limped home, changed the plug out and she fired up like a beast.
In the last week, I've changed my chain, sprockets, wheel bearings, and brake shoes...feels good.
gsnorcal
« Reply #6294 on: May 18, 2011, 07:40:41 PM »
Greggo,
We'll be able to meet up and ride SF sometime soon. I dropped my frame off at the powdercoater today. In two weeks it will be final assembly time.
Dave
Offline bjatwood
  • 1973 CB750-K3
« Reply #6295 on: May 19, 2011, 05:35:10 AM »
Adjusted chain and touched up HONDA badges and did some more detailing last night...
Brian
#24193
Offline Gerry
« Reply #6296 on: May 19, 2011, 07:27:27 AM »
i Broke mine... boo hoo  :'( got up this morning and was gonna run my son to school on it for the first time, started it, then clunk... think a valve got stuck and hit the piston... as we say in Scotland, it's gubbed!
Gerry
1977 CB550F Super Sport
Offline RatRacer
« Reply #6297 on: May 19, 2011, 05:31:58 PM »
Last week one of my rusted old mufflers finally decided to die... so I spent the first part of the afternoon installing a new pair of EMGO shorty megaphones and the rest of the afternoon was spent riding.
My old mufflers were more or less empty cans, but they sounded great.  The new Emgos are basically 17 inch long glass-packs and they brought out a throaty growl that I never new my mild-mannered 650 had!
  • 1979 CB 650 SOHC/4.  Currently undergoing surgery to replace reason with insanity!
  • 1999 Ram 2500 QCSB Cummins Diesel.  Headache Rack, Spray-on Bedliner, S.Steel Nerf Bars, Silencer Ring MIA, 4" TB Aero Exhaust, 1-Ton Suspension Upgrade, BHAF.
  • 2007 Mustang GT California Special.  Convertible Top, Bullitt Exhaust.
Offline Tripps
  • Perpetual Beginner
  • 1978 CB750K
« Reply #6298 on: May 19, 2011, 05:54:37 PM »
Installed 4 new Emgo mufflers today, changed the oil, cleaned up and freed the front caliper that was sticking, installed a new tube in the rear tire, heading off to Cleveland in the morning for the Relay, bike is running like brand new, I'm excited. Love the way it sounds, takes me back 35  years, that SOHC sound.
The greatest obstacle to discovery is not ignorance, it is the illusion of knowledge- Daniel J Boorstin
Offline wardenerd
  • '77 550F '81 650C
« Reply #6299 on: May 20, 2011, 04:08:21 AM »
My 650 fell over because of the piss poor design of the kick stand and my stupidity luckily I only broke the front turn signal and I was replacing it anyway.  Lucky me.  Rode the 550 to workand I love that little bike.
