Author Topic: What did you do to your bike today ?  (Read 3668111 times)
Offline mjstone
  • I'm definitly not a
« Reply #6375 on: May 27, 2011, 04:29:36 PM »
It's sunny here in Chicago today, but it was 47 degrees when I headed out to walk to the train at 8:30. Where's that damn global warming they promised me if I kept driving my gas sucking V8?
It was 46 degrees at 5:00 this morning and overcast with light rain.  So I rode my bike to work as always.  Get with the program Bankerdanny, ride!
MJ
1972 CB500Four (Honda)
1973 CB500Four (Oliver)
Offline Grnrngr
« Reply #6376 on: May 27, 2011, 06:37:05 PM »
Rode it to work, wasn't raining when I left, roads were OK, had several torrential downpours while I was inside lookin out, wasn't raining when I left but the roads were drenched, got almost as wet as if it were.....
Columbia river is at flood stage and I don't think it's been warm enough for the snow to melt. All we need is a nice warm heat wave to wash the whole mess to the sea....
'72 CB750-K2 "PopCycle"
'73 CB750-K2 "Barney"
'77 CB750A
'83 Virago 500 (red)
'83 Virago 500 (black)
Offline Hasenkopf
  • Really, I'm not an
  • This space for hire.
« Reply #6377 on: May 27, 2011, 07:03:03 PM »
Well, I  finally got my subaru oil temp gage installed on my k8.  its sooo cute !!
I like berries.
Offline bmxjrod
    • JRoD's PhotoShop
« Reply #6378 on: May 27, 2011, 07:19:51 PM »
New fork seals today, new tach cable ( first time tach has worked since purchase), and I figured out the wiring mess the PO left me in the headlight bucket! Everything works as it should.... I think.
CB750 K6
Offline Bankerdanny
  • Endeavor to persevere
« Reply #6379 on: May 27, 2011, 10:09:48 PM »
New fork seals and brought the bike home from my sister's for good. This was the last of the mechanical work. Some minor cosmetic cleanup is all that is left.
Offline Johnie
« Reply #6380 on: May 28, 2011, 06:33:39 AM »
Got all the newly painted candy gold tins back on the bike and took it out for the first ride of the season.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline dhall57
« Reply #6381 on: May 28, 2011, 02:26:30 PM »
awesome K1 Johnie ;) ;)
1970 CB750KO
1971 CB500KO-project bike
1973 CB350G- project bike
1974 CB750K4-project bike
1974 CB750K4
1976 CB750K6
1977 GL1000
1997 Harley Wideglide
Offline Tree
  • CB750K5
« Reply #6382 on: May 28, 2011, 02:41:08 PM »
Packed my MAC 4-1 muffler baffle with fiberglass.  It's the two opposing tubes style of baffle that's not normally packed.  I've always wondered if I had enough back pressure because I heard the original muffler systems were more restrictive.  Tech support at MAC said to secure some metal window screen over the two holes with wire, then wrap with fiberglass, and then aluminum foil around the whole thing before sliding it back into the muffler.
Seems to have worked great.  It's whisper quiet and runs as well or better than before.
Offline kuba85
« Reply #6383 on: May 28, 2011, 02:58:48 PM »
Found some time between cutting the grass and cleaning the garage to get my ' :)74 750 cleaned up and out for a fun enjoyable ride.  Boy I miss that ride http://forums.sohc4.net/Smileys/default/smiley.gif
Offline dhall57
« Reply #6384 on: May 28, 2011, 03:08:11 PM »
I've had my KO for 3 weeks now and finally getting the carbs and pipes off so I get a closer look at everything. The right side pipes upper and lower are in pretty good shape no rust through holes only some surface rust. I wish I could say the same about the left pipes. Both upper and lower has holes, what do you think guys too far gone to try any type of  repair? I believe it's going to take a little longer than I originally thought to get her in road ready condition. But that's half the fun of it right :) :) Things it has to have before hitting the road:
Frt brakes
Rear brakes
fork seals
fork boots
caliper rebuild
m/c rebuild
tires
« Last Edit: May 28, 2011, 05:56:25 PM by dhall57 »
1970 CB750KO
1974 CB750K4
1976 CB750K6
1977 GL1000
Offline Really?
« Reply #6385 on: May 28, 2011, 04:04:55 PM »
Replaced the two left mixture screws and re-synced the carbs on Brownie. Easiest sync so far.
Changed headset/mic from old helmet to the new helmet. Momma and I can talk and listen to the radio again. WooHoo!
The Wife's Bike - 750K5
The Kid's Bike - 750K3
Offline Greggo
  • Somebody's
  • Helmets Save Lives. Period.
« Reply #6386 on: May 28, 2011, 04:25:28 PM »
Replaced my CRUSTY front signal stems, old on the left, new on the right.  These were by far the ugliest item on my bike, and I feel much better now that they're replaced.
Mounted my painted stator cover.  It was scraped up from a PO crash, so this is a significant improvement
Finished
Offline bmxjrod
    • JRoD's PhotoShop
« Reply #6387 on: May 28, 2011, 05:42:17 PM »
Rode 40 great miles, then the poor girl started bogging down and sputtering, almost didnt make it back. On the good side, every backfire gave me a boost!
CB750 K6
Offline Frankenkit
  • Industrial Strength
« Reply #6388 on: May 28, 2011, 06:58:28 PM »
We went for an old bike ride.  I was on the 650  MickeyX was on my 350.  We went to the Beaverton honda shop then just took the opportunity to scoot around town a bit more.  It felt SO good. :D
2012 CBR250R "Black Betty"
1980 CB650c- (sold) Delilah
1973 CL350- Lola?
Stuff for sale
Offline thrutheframe
« Reply #6389 on: May 28, 2011, 07:26:55 PM »
Started on the clutch on my CB 360 but of course I was side tracked by what appear to be an oil leak from under the sprocket cover.  Didn't really find a leak probably because I had already drained the oil.  I wasn't too upset because it gave me a chance to adjust my chain tension and get the back wheel spinning better.  It would stop spinning after barely one rotation.  She spins nice and free now.  I cleaned up the slack adjusters and axle nut real nice with a brass brush while I was there.  I managed to get every one of the 6mm phillips head screws out with out incident, they were all torqued down pretty tight. I have all of the clutch parts and the oil filter screen out.  Hopefully tomorrow I can get the thing buttoned up and ready for a test ride.
'74 cb 750 K4
'75 CB 360T
'90 RC31 Hawk GT
Offline Hush
« Reply #6390 on: May 28, 2011, 08:45:16 PM »
Nothing, wheeled her out of the shed so I could waste my whole friggen day chasing a problem on my sons bike!!!!! >:( rant over...sorry. :-[
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
    • Playground Directory
« Reply #6391 on: May 28, 2011, 10:09:34 PM »
Clamped an exhaust back on a job bike and then rode one of mine to the end of the road ;D
Offline jkidd01
« Reply #6392 on: May 29, 2011, 02:42:32 AM »
I took the front brakes, calipers, tire, and fender from my 82 650 Nighthawks old front end, and put them all on my 81 650 C.
1982 CB650SC Nighthawk
1981 CB650C
Offline Tintop
« Reply #6393 on: May 29, 2011, 04:37:24 AM »
Finally got a hole in the rain, and took the 400SS for its 1st tour of the season.  They do tend to travel farther when the fuel is truned on properly. ::)  Souinds a little noisey, will have to check valves, and cam chain adjustments.
1980 CB750F (project)
77 CB550 Cafe build
550/750 Filter Thread
Sidecar Rebuild Thread
amark1
« Reply #6394 on: May 29, 2011, 06:26:44 AM »
Went riding for four hours yesterday and plan another 4 to 6 today
Offline wardenerd
  • '77 550F '81 650C
« Reply #6395 on: May 29, 2011, 10:03:36 AM »
fixed my saddlebag strap and put my Honda seat stencil on the 550.  Looks good from 5 ft so I'm happy
« Reply #6396 on: May 29, 2011, 10:36:50 AM »
I went to Smalls Pro hardware a scored a few temporary clutch and sprocket cover bolts so I wont have to struggle with putting the old ones in later today and so I wont be stuck with a stripped screw head when the bolts that I just ordered from Z1 arrive.  I love new fasteners.
'74 cb 750 K4
'75 CB 360T
'90 RC31 Hawk GT
Offline mjstone
« Reply #6397 on: May 29, 2011, 12:28:36 PM »
Just got done replacing my headlight.   The screw holding the trim ring on was rusted in place.  Ended up having to drill it out.  Got a stainless steal screw in there now.  Went to the auto parts store to get the headlight.  Only had two choices in 7" headlights, both halogen Sylvania's. Bought the cheaper one.  Mounted it up right there at the store.  No listing of power consumption on the box.
MJ
Offline Tree
  • CB750K5
« Reply #6398 on: May 29, 2011, 02:07:05 PM »
MJ
Sounds like the same choices I had for headlights recently.  They looked up the power for me and said it was 35W low beam and 65W high beam (if I remember correctly).
Offline Bankerdanny
« Reply #6399 on: May 29, 2011, 02:21:13 PM »
Watched mother nature give it a big time all day bath. Now that it's home for good, time to get a cover.
