Author Topic: What did you do to your bike today ?  (Read 3210019 times)
Offline mrbreeze
  • Not your average
« Reply #7025 on: July 27, 2011, 10:50:52 AM »
Just ordered petcock seals for my new tank so I can get rid of the fumes so I don't burn down the house!!!!!!
MEMBER # 257
Offline Greggo
  • Somebody's
  • Helmets Save Lives. Period.
« Reply #7026 on: July 27, 2011, 11:04:11 AM »
valve adjustment.
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #7027 on: July 27, 2011, 11:54:12 AM »
Took a cup of coffee out to the garage this morning and stared at it longingly.
Yanno, sometimes that makes for some great company!
Well, it never talks back to me.  ;)
Offline WhyNot2
  • I'm finally an
« Reply #7028 on: July 27, 2011, 12:22:26 PM »
rebuilt one fork.
What about the other one?
Offline fire113
« Reply #7029 on: July 27, 2011, 12:24:04 PM »
...prepared the K1 for longer trip.
Offline CJams
« Reply #7030 on: July 27, 2011, 12:39:09 PM »
Bought some Tarozzi rearsets for the 72 500.  Shoud go well with the full churchgate fairing set-up.  Can't wait.
1971 CB500 Cafe (in the works)
1972 Candy Gold CB500
1973 Candy Bucchus Olive CB500
Offline DJ_AX
« Reply #7031 on: July 27, 2011, 01:09:29 PM »
re-glued the re-crack in my sidecover. Maybe I'll use a little less baking soda next time.
And of course ... rode it to work ..
what's that?  50% chance of what? ...
well..
A much better chance of a nice ride :)
Offline IndyFour
« Reply #7032 on: July 27, 2011, 05:52:45 PM »
I decided to remove and clean the carbs on my 550 today.  I've never had them off since purchasing the bike a few years ago....it has always run reasonably well with the exception of pretty lack-luster fuel mileage.  They were worse than I expected.....can you tell which of the 4 have not been cleaned yet in this pic?  :o
The slow jets may have been clogged just a bit, but overall everything seemed clear and the floats moved freely even with the gunk.
Oddly, the float height appears to have been set WAY off last time these were opened up.  They are supposed to be 22mm and they look to be about half that (way too high).  Never had any fuel from the overflows, though.   ???  Hopefully setting the floats correctly will help correct my mileage issues and richness.
1974 CB550K
2000 VFR800FIY
__________________
Indianapolis, Indiana
Offline bjatwood
  • I never claimed to be an
  • 1973 CB750-K3
    • Minbikers Proboards
« Reply #7033 on: July 27, 2011, 07:31:52 PM »
Were your plugs black and sooty with the float level off that much?
Brian
#24193
I believe that the Finest things are the most thoughtfully made, not the most expensive!
http://minibikers.proboards.com/
Offline Tews19
  • I am no
« Reply #7034 on: July 27, 2011, 07:40:49 PM »
Finallt got my CB550k back from the shop. Carbs completely rebuilt, had to adjust the points. The Shop in Bayview, was very detailed and the owner took his time to explain everything that was completed. First time I drove her while running well.... Well, sorta... She doesn't want to stay running when coming to a stop.... At times, she will idle around 1k-1250 and stay running but other then that she will die... Sounds like she wants to stop running... But when she is driving, man, I understand all the postings of the enjoyment these bikes bring their owners.... Anyways, took off the horrible fairing and saddle bags. MOunted the rear and front turn signals, played around 4 hours to get the wiring correct and still no turn signals... SIGH... I will have to hit up Ace Hardware to pick up some rubber gaskets and modify the bucket Removed the handle bar extension also.... Now I am going to search the threads for the proper wiring diagram to get these lights functioning...
« Last Edit: July 27, 2011, 08:35:03 PM by Tews19 »
1970 Honda CB750 survivor.
Offline Roach Carver
« Reply #7035 on: July 27, 2011, 07:43:54 PM »
rebuilt another fork.
Bobdoliest
« Reply #7036 on: July 27, 2011, 07:59:02 PM »
Continued ripping apart my 1980 CB650...endless cleaning..examinations...
BTW I am new here..
Offline IndyFour
« Reply #7037 on: July 27, 2011, 08:12:57 PM »
You know what....I must have been high on carb cleaner.   ;)  I went out to finish things up and as it turns out the float were not off as much as I thought.  Actually, they were very close and I just had to do minor adjustments.  The plugs typically are slightly sooty.  I've never synchronized the carbs on this bike so that's next.
1974 CB550K
2000 VFR800FIY
__________________
Offline IndyFour
« Reply #7038 on: July 27, 2011, 08:13:32 PM »
BTW I am new here..
Welcome!
1974 CB550K
2000 VFR800FIY
__________________
Online Don R
« Reply #7039 on: July 27, 2011, 08:33:13 PM »
Watched the odometer go past 11,111.1 miles. 76 F. It had 7,8xx when I got it. So after 35 years, 1/4 of the total miles were put on this year.
Offline Spanner 1
« Reply #7040 on: July 27, 2011, 08:59:19 PM »
78K 750 Put Together ( I'm not callin' it a re-build  ;) )..... Put on the wire loom , solenoid, rectifier, diode, changed-out the ign. switch for one that has a key !, wired the r/h control, rigged a main fuse, connected the starter AND couldn't resist cranking it over.... woohoo.... no fuel/air set-up yet ( like tank and such to feed fuel to carbs... minor detail !! )...... drank a (few ) beers, posted here...
Oh... and my friggin' oil tank has a pinhole in the bottom of it ( feck it ), so posted in the 'wanted section'...........
« Last Edit: July 27, 2011, 09:17:29 PM by Spanner 1 »
Offline WhyNot2
  • I'm finally an
« Reply #7041 on: July 28, 2011, 04:34:05 AM »
I like that seat.........can you tell me where you got it?
Jack
Offline thrutheframe
« Reply #7042 on: July 28, 2011, 08:54:49 AM »
Rode my CB360 to the license exam station and took my riding skills test.  30 years after I started riding.  Getting my first ever speeding ticket on a bike was the thing that did it.  Watched a bunch of guys take the test.  I hate to say it but the big twin HD's had the best advantage because they could idle thru the whole test.  A guy about 70 on a little scooter high sided his bike doing the quick brake test, that's an instant fail.  The guy wasn't hurt, and we all felt bad that he crashed his ride.
'74 cb 750 K4
'75 CB 360T
'90 RC31 Hawk GT
Offline fire113
« Reply #7043 on: July 28, 2011, 11:18:47 AM »
Jack
Hi Jack,
...the seat is self made.
Did the electric at my K0, no fuse smashed but I had big problems to get my starter running. Seems that the NEW wiring harness has a wrong cable color  :o  what ever the starter is working now  ;D
Offline WarwickE36
« Reply #7044 on: July 28, 2011, 12:41:29 PM »
Today/Yesterday I wrapped my headers....
And took off my rockerbox, replaced the cam pucks, and installed a new valve cover gasket.
found 2 cam pucks to be leaking.  I am hoping this stops my oil leaks along the fins. Crossing my fingers but not holding my breath.
Now I just need to replace the shifter seal, and primary drive seal... How easy is this??
" Why does anyone get offended by what someone does to their own bike? I dont get it. "
You made me think about it after I cheered knowing someone else would like to know what these control freaks are up to.
 Every time any owner strips whatever precious Honda part the horrified purists parts go up in value. That's not the part that bothers them.
 What bothers them is they sat up late at night, their breast full of wonder and estrogen, unable to sleep, dreaming about their lovely darling and all her glory... and next thing you know someone else doesn't share their emotional deluge and their reaction is they must spread their mind museum as far as they possibly can, taking over as much of the real world as possible.
Drink fast, drive slow, but ride it like you stole it
1974 Cb550 with style
2004 SV650s
Offline Tews19
  • I am no
« Reply #7045 on: July 28, 2011, 12:54:30 PM »
I really like your seat.. Did you make it or purchase? If you purchased it where and how much if you do not mind?
Offline WarwickE36
« Reply #7046 on: July 28, 2011, 01:47:30 PM »
I made it :-D  had it upholstered by my buddy's dad.  Here's the build thread.
http://forums.sohc4.net/index.php?topic=91256.msg1026307#msg1026307
Cost me under $100 for the whole job, parts + labor.  Without the buddy's discount prob right at $150.
2004 SV650s
Offline CJams
« Reply #7047 on: July 28, 2011, 04:38:12 PM »
Rode the 72 500 to work since it's nice and sunny out.  The 72 just doesn't have the torque the 73 has.  It gets slugish at about 4500rpms and doesn't want to pull hard.  Still makes it from a to b though.
Offline Jim F
  • go baby go
« Reply #7048 on: July 28, 2011, 04:56:29 PM »
Its finally Done
2002 RC51 1000 (SP2)
1983 GS1100EC Suzuki
1992 KTM500 2 stroke
1975 CB750/836 Honda
1978 GS750/840 Suzuki
Offline DJ_AX
« Reply #7049 on: July 28, 2011, 04:59:22 PM »
