Author Topic: What did you do to your bike today ?  (Read 3209533 times)
mrjack55
« Reply #7350 on: August 20, 2011, 08:32:49 PM »
Gave it a good spit and polish.  Taking it to her first show tomorrow.  Not expecting anything, but it will be a new gig for me.  I'm used to the the classic car scene, which is getting pretty damn boring around here.  It's time to hang out with the other motorcycle nerds.
Offline Rgconner
« Reply #7351 on: August 20, 2011, 10:21:49 PM »
Cleaned the ports.
Scraped off tonnes of gasket material. Prepped for new gaskets.
Checked the rings.
Cleaned one piston head. Rest tomorrow.
Discovered lots of little parts on the bike that are SUPPOSED to be metallic, but were so covered in grime they appeared painted. Mostly the rear wheel area.
Now I got dishwater hands from so much scrubbing!
I think I spent 6 to 8 hrs working on her today. More planned tomorrow.
1975 CB550K aka "Grease Monkey"
Offline Spanner 1
« Reply #7352 on: August 20, 2011, 11:14:21 PM »
Stuck a headlight bucket on the K8 750 and pulled all the wires inside it . Sat on a stool in front of the bike and put all the wires together ( I love this part, really ! ) Got all the stuff working, that is after I re-fit the rear fender and tail-light and the rear brake light switch. Basically, it's legal to ride, headlight, tail-light, brake light.....no turnsignals yet. have 1 broke spoke on the back wheel.... want to replace the spokes, frustrated no-one has spoke sets for a 17 in. K8 wheel... lots and lots of 18 in. spoke sets available  :'( :'(
Offline dhall57
« Reply #7353 on: August 21, 2011, 04:53:51 AM »
put some new Oury grips on my 750KO and so far I like them. Got 120 mains in now with a K&N filter also rerouted the fuel lines. Finally got clutch adjusted to where its not creeping anymore. The KO is coming around and starting to act and run like it is supposed to.This bike is awesome!! I really like my K6, but there is just something special about the 4/70 750 KO ;D ;D I've had this bike for 3 months now, but it's still hard to believe I lucked up on this gem and its mine clear title and all. Not bragging just very lucky. Don't give up SOHC/4er's the bikes and the deals are still out there!!
« Last Edit: August 21, 2011, 06:15:57 AM by dhall57 »
1970 CB750KO
1971 CB500KO-project bike
1973 CB350G- project bike
1974 CB750K4-project bike
1974 CB750K4
1976 CB750K6
1977 GL1000
1997 Harley Wideglide
Offline WhyNot2
  • I'm finally an
« Reply #7354 on: August 21, 2011, 07:53:06 AM »
uuuuuuuggggggghhhhhhhh...................................!!!!!!!!!!!!!!!!!!!!!!111
Nuf said!
Offline kerryb
  • Not a very
« Reply #7355 on: August 21, 2011, 10:54:09 AM »
I discovered the tach may be wrong because it won't read correctly, So...off it goes and a new dash plate allows more room for clutch cable, choke relocation and put the turn indicators where I'll see them so I don't leave the left turn on for 3 miles!
Offline fire113
« Reply #7356 on: August 21, 2011, 02:30:11 PM »
...cleaned a K0 mirror.
Offline Greggo
  • Somebody's
  • Helmets Save Lives. Period.
« Reply #7357 on: August 21, 2011, 04:21:18 PM »
Bought an unobtanium NOS rear wheel bearing retainer for the 500/550...twenty bucks!
Offline CycleRanger
  • No comment about being an
« Reply #7358 on: August 21, 2011, 04:40:20 PM »
Seems like it was the day for wires!
Installed the bars, new brake lines, blinkers, bucket & pulled the wires.
Stripped & painted the gauge bracket.
I stopped there since by then it was ~105° in the shop and I figured I'd need all my wits to hook up the wires... :o
Offline Really?
« Reply #7359 on: August 21, 2011, 05:34:02 PM »
Pulled engine side covers and then pulled engine out and sat it on the table. Easy one man job. ;).
The Wife's Bike - 750K5
The Kid's Bike - 750K3
Offline Rgconner
« Reply #7360 on: August 21, 2011, 05:56:04 PM »
Nuf said!
Well, that's yer problem right there!  :o
Offline Rgconner
« Reply #7361 on: August 21, 2011, 06:01:25 PM »
Finished giving the swingarm a quick coat of Rustoleum to protect it, someday I will get it powder coated.
While paint was drying, refitted pistons to block, the hose clamp trick worked like a treat.
Cleaned the years of grease/dirt/oil/muck off the back of the engine before reassembly
Reassembled that after a good greasing, mounted rear tire.
Now, once the damn pucks get here, I can get it all back together. Can't believe they were not in the top end kit.
mrjack55
« Reply #7362 on: August 21, 2011, 06:19:02 PM »
I braved the weather, and rode to a local show.  Hung out for a few hours, and saw some very cool bikes.
I left just in a nick of time too.  As soon as my back tire entered the garage the heavens opened and it was a total monsoon.
Offline Trav-i
  • Has finally become an
« Reply #7363 on: August 21, 2011, 06:26:06 PM »
Did a second coat of Redkote today.  It was going well until it came time to drain off the excess from in the tank.  It had already started setting up, what was coming out of the tank was long stringy globs.  Got most of the excess out, and sloshed what I couldn't around the tank till there was a nice even coating.  I just looked I have a little bit of puddling inside, but I'm hoping it will still cure ok after I let it sit for a few days.
Forum member #9962
1992 GL1500 Interstate
Offline Tews19
  • I am no
« Reply #7364 on: August 21, 2011, 06:50:25 PM »
adjusted 3 of 4 valves... May have caused a major malfunction but hopefully some mmebers on here can help me out
!!!!! I also learned how to adjust my chain.. God these bikes are fun to work on!!!!1
« Last Edit: August 21, 2011, 06:55:26 PM by Tews19 »
1970 Honda CB750 survivor.
Offline Popwood
« Reply #7365 on: August 21, 2011, 07:56:39 PM »
On my '75 550K did  a thorough wash and for the first time time wax in three years. Boy, did it make that flake sunrise shine! She's all original and in great condition with just1 10K miles. I consider myself lucky to own her. Also did a 40 mile short ride before the thunderstorms came.
On the '75 750k 5 was about to rebuild the front brake caliper. Was off, cleaned and ready to go, but put off reinstall and ordered some Dow Corning Vacuum grease, highly recommended. OK, I'll wait a week to get back on the road. The last stuff I used, the hi-temp silicone stuff in the tiny packets at autozone ruined the last break rehab. It melted, got absorbed by the brake pads, caused them to swell ever so slightly causing brake dragging. At least that's my analysis. It was hard not to just put the caliper back together and go, but patience, Grasshopper. I don't want to do this again for awhile-- I mean years.
Current Rides:
1975 cb550K
1975 cb750K
1967 Bridgestone 350GTR
Past Rides:
1988 400 Hawk
195? Schwinn Whizzer
Offline socalenduro
« Reply #7366 on: August 22, 2011, 02:10:29 PM »
put on new grips and installed my idioit light in reverse order by mistake...
waiting on my new re uphostered seat!
Offline 750K
« Reply #7367 on: August 22, 2011, 03:23:51 PM »
I rigged up a triumph flyscreen for my 77 cb750, easy mount up and wind blast is so much less. Just have to paintit black to match.
77 Cb750, 78 Kz1000
Offline Free Booter
  • My Build: CB750k5
  • Meh.
« Reply #7368 on: August 22, 2011, 05:46:00 PM »
put the engine in and mounted up the rear-sets, wheels and kickstand.
Offline Blitzburgh207
« Reply #7369 on: August 22, 2011, 06:15:50 PM »
Damn that's a sick looking build man
1978 CB750 K8
Offline IndyFour
« Reply #7370 on: August 22, 2011, 07:08:32 PM »
What bars did you use on your bike?  They appear to be drag bars....but longer than the standard ones you find everywhere.
1974 CB550K
2000 VFR800FIY
__________________
Indianapolis, Indiana
Offline japscrap
  • GWChops@yahoo.com
« Reply #7371 on: August 22, 2011, 10:50:52 PM »
I rode my bike.isnt that what they are built for?
Gwchops is in the house!
Offline johnny
« Reply #7372 on: August 23, 2011, 08:28:23 AM »
Installed Dyna coils and wires on my 350:
1976 CB550K
1974 CB350F http://forums.sohc4.net/index.php?topic=81781.0
1974 CB550K
1972 CB350 Twin
1965 Lambretta
196(?) Honda S90
1975 Ford Bronco
Offline WhyNot2
  • I'm finally an
« Reply #7373 on: August 23, 2011, 11:56:22 AM »
Got mine running sh$%tty but runs. Took it for a cruise around the hood and a cop was comin towards me. Mind you, I had been working on the bike, I was in shorts, flip-flop, and a bright azz orange bike week t-shirt. No wallet, insurance tags, registration and had a few to boot. I panicked and sped down the side street. Pumped the choke and throttle just to keep the damn thing going. Don't know how the heck I got away, but was able to get into my garage and look out the window and there he goes, right on by.
WHEWWWWwwwwwwwwwwwwwwww
Offline Tintop
« Reply #7374 on: August 23, 2011, 01:30:44 PM »
Picked up a new battery for the 400SS.  The old one was from 2007, and would take a charge but not hold it.  Probably a bad cell.  Dropped the 550 off to have the cam degree'd.  Should get it back tomorrow.
1980 CB750F (project)
77 CB550 Cafe build
550/750 Filter Thread
Sidecar Rebuild Thread
