Author Topic: What did you do to your bike today ?  (Read 3209363 times)
0 Members and 20 Guests are viewing this topic.
Offline Tintop
« Reply #7425 on: August 28, 2011, 05:15:02 PM »
Finally hooked up with Tintop....real nice guy....very informative......with a reeeeaaal nice 400F.
Definitely deserves his 15 minutes.
Nice ride through the twisties..
Thanks
Steve
We'll have to do another ride Swoop.  Found a bunch of nice stuff to string together, on the way back.  If my adapter parts shows up before the weekend, I'll give you a call.  Also give me an excuse to see some of those other projects of yours. :)
1980 CB750F (project)
77 CB550 Cafe build
550/750 Filter Thread
Sidecar Rebuild Thread
Offline Bankerdanny
  • Endeavor to persevere
« Reply #7426 on: August 28, 2011, 05:40:02 PM »
Delivered it to the new owner.
Dang, she is gone? How is the goldwing doing?
Yep, she should be in her new home in South Carolina by now.
Well, I did quite a lot this weekend, pulled the fairing and bags (temporarily), installed new timing belts, a new thermostat and coolant hoses, set the valves and points, however not all good. I broke one of the float pin towers while trying to remove a pin on carb #1. I went ahead and rebuilt the carb pair that was intact, but didn't do 1 or 4 since I figured I would be buying a full set (you rarely see one carb for sale) and would just rebuild the 1-4 pair together.
I found out from a Wing forum member today that Randakk's makes a tower repair kit where you get a machined aluminum tower and everything you need to install it. Apparently the method is so proprietary that he won't even tell you how the new tower in installed until you buy the kit.
Still, he is the old 'Wing guru, so I am willing to trust him. Plus, $38 beats the hell out of $100+ for a used set of carbs.
« Last Edit: August 28, 2011, 05:42:29 PM by Bankerdanny »
Offline OldSchool_IsCool
  • Really feeling like an
« Reply #7427 on: August 28, 2011, 07:42:21 PM »
Split the cases today, here is the primary chain wear. Definitely hitting the oil gallery from the pump to the oil filter. Now I get to wait on parts.
CB550 Split Case Primary Chain Wear
Aren't you supposed to make it cough when you do that?
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
Offline Really?
« Reply #7428 on: August 28, 2011, 09:08:35 PM »
Sanded plastic.
The Wife's Bike - 750K5
The Kid's Bike - 750K3
Offline mrbreeze
  • Not your average
« Reply #7429 on: August 28, 2011, 09:39:45 PM »
If you do a search here you will find a member that welds the tower back on. He has some sort of a micro set up to weld aluminum. I have forgotten who it was (few years back).
MEMBER # 257
Offline Bankerdanny
« Reply #7430 on: August 28, 2011, 09:42:39 PM »
I read about that on another site after a Google search. His site crashed a few weeks back and isn't back up yet.
« Reply #7431 on: August 29, 2011, 04:47:23 AM »
Pulled carbs again, that thing does not start now.  Could it be the safety inspection sticker?
Offline Tugboat
  • Puppet
    • PseudoMoto
« Reply #7432 on: August 29, 2011, 07:25:48 AM »
Took my carbs apart & cleaned 'em.
Prognosis: clogged slow jets.
Now I know.
Offline JustinLonghorn
« Reply #7433 on: August 29, 2011, 07:43:52 AM »
Cut the 25+ year old tires off of my Alumunum hoops. Trusty saw-zall and an angle grinder for the bead. Much easier than beating up the hoops with a set of spoons.
"So you had better do as you are told
You better listen to the radio"
My Super Sport Build
Offline WarwickE36
« Reply #7434 on: August 29, 2011, 07:44:58 AM »
Quote from: WarwickE36 on August 28, 2011, 06:26:52 pm
It definitely cried rape a few times... but its costing me a mini fortune to rebuild so I felt I'd get my moneys worth of fondling in.
" Why does anyone get offended by what someone does to their own bike? I dont get it. "
You made me think about it after I cheered knowing someone else would like to know what these control freaks are up to.
 Every time any owner strips whatever precious Honda part the horrified purists parts go up in value. That's not the part that bothers them.
 What bothers them is they sat up late at night, their breast full of wonder and estrogen, unable to sleep, dreaming about their lovely darling and all her glory... and next thing you know someone else doesn't share their emotional deluge and their reaction is they must spread their mind museum as far as they possibly can, taking over as much of the real world as possible.
Drink fast, drive slow, but ride it like you stole it
1974 Cb550 with style
2004 SV650s
Offline IndyFour
« Reply #7435 on: August 29, 2011, 01:19:59 PM »
Tank back from painter.  Applied a coat of epoxy around the top of the gas tank filler neck to to seal the lip and keep the paint from lifting again.  Painter did a beautiful job and don't want it to get eff'd up again.
1974 CB550K
2000 VFR800FIY
__________________
Indianapolis, Indiana
« Reply #7436 on: August 29, 2011, 01:22:17 PM »
So nice!
Offline IndyFour
« Reply #7437 on: August 29, 2011, 01:49:52 PM »
So nice!
Thanks.  Love this Orange....just glows in the sunlight.
Took her for a ride for the first time since May.  Can't tell if she's hesitating a bit or just feels slow after riding around all summer on the other bike.  Probably a bit of both.  Did a quick carb cleaning about a month ago, but didn't bother to pull the emulsion tubes....so of course they probably need it.  Guess it's time for the carbs to come out again.   ::)
1974 CB550K
2000 VFR800FIY
__________________
« Reply #7438 on: August 29, 2011, 02:08:29 PM »
One word... SeaFoam!   ;)
Offline Tintop
« Reply #7439 on: August 29, 2011, 04:18:35 PM »
JimR who is doing work on Sam750A's drag bike does micro welding.
« Last Edit: August 29, 2011, 04:21:55 PM by Tintop »
77 CB550 Cafe build
Offline mrbreeze
  • Not your average
« Reply #7440 on: August 29, 2011, 04:39:51 PM »
Good word Ron!!! The stuff is amazing although I think it has taken a big jump in price lately. Used to get it for around $6-7 and just paid $10 for a new and improved different shaped can. Still cheaper than pulling the carbs and all.
MEMBER # 257
« Reply #7441 on: August 29, 2011, 05:48:01 PM »
I like it a lot!
Offline Gman
« Reply #7442 on: August 29, 2011, 06:19:53 PM »
Indy4 - Gorgeous scoot!
I just rode mine to work - beautiful day.  Only had it about a month, so still getting used to it... the idle at warm up has been rough with an interesting rhythm and then idles high once warm (2k).  On a whim, as it was just warming up, I felt the headers.  #2,3,4 = hot.  #1 = cool.  Hmmm.  After a very cursory search here, seems I might need to do a bit of carb cleaning.  Nothing like jumping in w/both feet! ;)
'76 CB550K
Stock airbox, MotoGPWerks 4-1, HondaMan ignition, Lesters
Offline Tews19
  • I am no
« Reply #7443 on: August 29, 2011, 07:16:32 PM »
Ordered Hondaman's fuse box for the 550K....
1970 Honda CB750 survivor.
Offline Raef
« Reply #7444 on: August 29, 2011, 07:20:08 PM »
polished the side cover and chain guard
Offline scooter1
  • 1973 cb750
« Reply #7445 on: August 29, 2011, 07:44:55 PM »
Ordered up new rear brake shoes.....and rode it to work and back!!!
« Reply #7446 on: August 29, 2011, 09:37:58 PM »
Nice side covers Raef.....
« Reply #7447 on: August 29, 2011, 10:05:24 PM »
Got the plates for the K2 today, even though the bike isn't built i had to get these before someone else did.... ;D
« Reply #7448 on: August 30, 2011, 12:17:51 AM »
RSC72 = really scarey seventy two?
« Reply #7449 on: August 30, 2011, 12:26:31 AM »
Maybe.... ;D
