Author Topic: What did you do to your bike today ?  (Read 3263629 times)
0 Members and 11 Guests are viewing this topic.
« Reply #8675 on: December 26, 2011, 12:45:44 PM »
more cleaning and checking,this might explain the broken rings,the smallest piston at 60.93 wont drop through any of the bores from the bottom,itll drop in from the top till that point,it appears it hasnt been properly hone finished and i doubt the ring gaps were even checked let alone piston clearance,i can see the high spot mark in the bores,it would have been hard squeezing that barrel down but this hero persisted,i think ill be able to rescue the pistons and barrel with a decent measure and hone through,this looks to be 750/61mm pistons in a 550 barrel.
What sort of hone are you using Dave? I've got an Ammco adjustable hone here, they're fantastic tool, you can get a very straight cut out of them, and I've known guys to use them to take a cylinder out one oversize, (long and tiresome process, but doable) if you've got access to something similar, it'll make your job easier. Cheers, Terry. ;D
 http://www.ebay.com.au/itm/AMMCO-Motorcycle-Cylinder-Hone-Kit-/270539314914?pt=Motorcycles_Parts_Accessories&hash=item3efd6656e2
thanks teryy,i have a mate with an engine reconditioning shop,he has flex hones etc,when he re opens ill measure the bores up properly.
Offline Tews19
  • I am no
« Reply #8676 on: December 26, 2011, 01:04:46 PM »
I tried to think of some way to calculate the best way to improve my handling on my 75' CB400F; does anyone know the rake and trail dimensions of my frame ??
Take a look at this and has some external links as well.
http://www.denoonsp.com/user/image/v3-issue1.pdf
Stock tires rake is 26.5mm trail is 85mm...Page 5 of link gives good details
« Last Edit: December 26, 2011, 01:07:29 PM by Tews19 »
1970 Honda CB750 survivor.
Offline Roach Carver
« Reply #8677 on: December 26, 2011, 02:19:53 PM »
Took the head off a spare motor and drilled tge remnants of a spark plug out and rethreded hole. Need the gaskets now.
Offline rbmgf7
  • 2>4
« Reply #8678 on: December 26, 2011, 03:01:17 PM »
Washed the engine cases in a bathtub full of diluted Simple Green. Hoping to have them ready for blasting tomorrow then paint.
While I was cleaning the chamber and in./ex. ports in the head with a rotary tool and emery disc, I thought it would be worthy to remove the aluminum spigots so I could get in deeper (that's what she said).
After getting the tools and applying a ton of heat, I finally broke it loose. Holy sh*t those things are on there. In the end, it wasn't worth it. Only managed to strip it out so I had to debur it and stick it back in with JB Weld.
« Reply #8679 on: December 26, 2011, 04:28:24 PM »
This was covered in another recent thread. Do not remove the intake spigots. There is no need to and usually results in pulling the threads out.
Oh, you noticed...  :(
Offline 78 k550
« Reply #8680 on: December 26, 2011, 04:35:54 PM »
got my rear master cylinder (76 750F) on the table now and going to rebuild it.
Can you say frozen solid. Going to be some work.
Paul
« Last Edit: December 26, 2011, 04:52:58 PM by 78 k550 »
Paul
Littleton, CO
76/77 CB 750F,
76 GL1000 LTD
84 GL1200 Standard
Offline Randy
  • Nothing like a banging four under my legs..
    • Mission Detail
« Reply #8681 on: December 26, 2011, 04:41:29 PM »
Valve adjustment an carb vacuum adjustment, check plugs...Installed a better looking tail light assembly
1973 CB500k, 1972 CB750 (New Arrival), 1978 Vespa P200 (New Arrival)
« Reply #8682 on: December 26, 2011, 04:45:36 PM »
I recently saw some nice anodized replacement spigots in different colors for the 750, what would be the best way to remove the old ones without doing damage.?
Offline IndyFour
« Reply #8683 on: December 26, 2011, 04:46:32 PM »
Ordered new front OEM copy front blinkers and shorty stems (early style that double as headlight bucket bolts) so that I can fit them back on with the new clubman bars.  Just couldn't bear the thought of sticking a set of those tiny modern ones on this bike.
Today I replaced the horn with a little Stiebel replacement horn (clearance at Meijer for $10).  I replaced the original with a compact air horn a couple years back and then it died this past summer.....so put the original back on....but it quit as well.  Hopefully this one will last.   ::)
BTW - I used on of my Christmas gifts for the first time....
I asked for the plain round shaped seat....this one's a little over the top and is labeled a "harley style".....but I won't complain.  It's WAY more comfy than sitting on an inverted bucket like I used to!  I feel like I should be wearing chaps and fringe when I sit on it, though.... ;D
1974 CB550K
2000 VFR800FIY
__________________
Indianapolis, Indiana
« Reply #8684 on: December 26, 2011, 04:52:38 PM »
nice seat, indy!
« Reply #8685 on: December 26, 2011, 05:01:50 PM »
nice seat, indy!
Indeed. I now have a use for an old computer chair and round topped bar stool..... ;D
Offline myhondas
  • Not really such a
« Reply #8686 on: December 26, 2011, 05:11:11 PM »
What did I do to my bike?????? I freaking rode it on both Christmas Day and today also.  Now that may not sound like much, but how often does one in a snowy climate get to do that. 40F-45F and sunshine. Had to get out and enjoy it since they are talking colder and snow tomorrow and the rest of  the year.
1974 CB 750 K4 SHOWROOM
1965 C100 CUB 50 (PIT BIKE)
1996 VF 750 CD daily rider
SOHC# 5105 11228
Offline rbmgf7
  • 2>4
« Reply #8687 on: December 26, 2011, 06:17:23 PM »
After having experienced what it takes to remove just one, I highly discourage it. It's locked in there with some type of thread locker on top of being a fine pitch thread. Unless you're repairing a broken one, I'd just leave it. Only reason I wanted to remove it was to get that last bit of carbon in the port but I think I can live with it.
Others have done it with success. Just requires a LOT of heat. If you have acetylene, zapping it with that would probably do better than a propane torch.
Must use a 6 point 36mm socket. I found one at O'Reilly's Auto for $20. You can find a 12 point at Sears but I know the 12 will mar the spigot.
Offline Grnrngr
« Reply #8688 on: December 26, 2011, 07:07:15 PM »
Been crazy like that around here too...record lack of rainfall for this time of year, nice clear skies, at least what I can see out the window at work, but still...dark when I get there, dark when I leave..frost on the tank and seat in the morning..
'72 CB750-K2 "PopCycle"
'73 CB750-K2 "Barney"
'77 CB750A
'83 Virago 500 (red)
'83 Virago 500 (black)
Offline Dimitri13
  • 1974 CB550K
« Reply #8689 on: December 26, 2011, 09:43:31 PM »
Resynced the carbs. Now it doesn't sound like it's skipping, and has better low end throttle response and performance.
Also installed a 125db horn from NAPA.
Offline petercb750
« Reply #8690 on: December 26, 2011, 11:18:16 PM »
After no rides for 3 weeks, took it out and gave it a damn good thrashing.
I feel better now. ;D 8)
1972 750/4 K2 (his), 1976 400/4 (hers)
1982 CB1100RC (ours)
« Reply #8691 on: December 27, 2011, 02:10:54 AM »
Nothing on my bike today, but Cliff (Maduncle) brought his CB450 hubs over so I could remove the bearings. I had to make a special bearing retainer removal tool for the rear hub, which will be handy for me too, as it'll also work on CB750 rear hub bearing retainers. Cheers, Terry. ;D
maduncle
« Reply #8692 on: December 27, 2011, 03:26:17 AM »
I need to start a new thread "what did Terry do on my bike today"!
Apart from calling in the professional help for bearing removal - I spent some time on the 'net researching the original Honda CB450 Candy Blue colour to see if I can get my frame, swing arm and other parts powder coated in a blue that matches.
Offline axehole54
  • Who the heck decided to call me a
  • #169 North
« Reply #8693 on: December 27, 2011, 05:33:24 AM »
Not today... but yesterday I pushed the fzr1000 outta the way, messed around with my carbs a bit and took the k3 out for a Christmas Day ride. Was happy to see that at least 3 other riders were as crazy as me to ride on the slippery streets at just above 0 degrees celsius :D
73 750k, 78 750k, 69 c10, 87 r1500 (c10), 94 fzr1000
« Reply #8694 on: December 27, 2011, 05:39:22 AM »
i think the only snow in all of australia was in my freezer today,,i hope everyones beer was cold enough?
    • http://forums.sohc4.net/index.php?PHPSESSID=g85bm9tb44dr5rdvig0n8kdun4&/topic,60973.0.html
« Reply #8695 on: December 27, 2011, 05:43:14 AM »
i split the cb 77 engine
« Reply #8696 on: December 27, 2011, 05:13:14 PM »
Well we had a "White Christmas" here Dave, actually it was friggin' scary. About 4 pm on Christmas Day all hell broke loose and we had floods, hail storms and even a couple of small tornado's. I was with the wife's family at my mother in laws place and we copped some really big hailstones that smashed the windscreens in several cars parked in her street, and as soon as it backed off we drove back to my place to see if we were OK.
Well the poor little Hyundai was driving thru water up to it's doors, past cars that had been drowned, but it made it home ok, even though the usual 20 minute drive took over an hour due to the flooded roads. I got home and the house had narrowly missed being flooded, we're on a block that slopes down to the creek in the park behind our house, so when the drains in our street were overwhelmed, the water ran down across my front yard, around my house, down thru my driveway and patio, and into my garage, which had a bout 4 inches of water in it when I got home. I've now got a nice cover of topsoil from my front garden over my garage floor. Still, on the bright side, the hailstones I collected were handy in my Scotch and coke! Cheers, Terry. ;D
http://www.abc.net.au/news/2011-12-27/melbourne-storm-insurance/3748698?section=business
« Reply #8697 on: December 27, 2011, 05:23:41 PM »
yeah that was bad.
Offline cben750f0
« Reply #8698 on: December 27, 2011, 05:40:02 PM »
xmas day, pulled the bike out, and adjusted the valves, as well as pulling the cam chain tensioner out, and checking how much adjustment i had left, which was heaps.
noted that it was a little sticky, so pulled it apart, cleaned and lubed, replaced in engine and allowed to spring forward, with the motor in the apropriate position ( 15 degrees past tdc on number 1).
sounds heaps better, funny how we dont notice the noises over time...lol
other than that, just been riding around far north Queensland=)
Merry Xmass all BTW
peace
Offline mickey6
« Reply #8699 on: December 28, 2011, 03:00:38 AM »
got a cb400f today with title for $100. started the tear down, it's got some pretty nasty carbs... the only thing that moves on the is the choke. But it'll be a fun little project.
76 cb750F in 7 boxes
73 cb500 daily cafe
