Author Topic: What did you do to your bike today ?  (Read 3264596 times)
« Reply #8725 on: December 30, 2011, 10:03:19 AM »
Started one of my new 72 750's for the first time last night. Always one of those finger crossed moments to hear it run for the first time.This one had sat dormant for at least several years.Cleaned the carbs,set the valves,timeing,tuned up the cam tensioner by removing the screw divots on the ramp and made gasket,new oil, all the usual pre start stuff.  Started right up and all sounds very good. Did get the famous debri blowout at one muffler,a bunch of what looked like pumpkin seeds  :D   Well on to the next-------------
« Last Edit: December 30, 2011, 10:06:24 AM by ekpent »
Offline dhall57
« Reply #8726 on: December 30, 2011, 12:04:27 PM »
I see 6 bikes in the background are these all in riding condition? Quite a collection Ekp ;D and I know you've got more that's not pictured. How do you do it?
1970 CB750KO
1971 CB500KO-project bike
1973 CB350G- project bike
1974 CB750K4-project bike
1974 CB750K4
1976 CB750K6
1977 GL1000
1997 Harley Wideglide
Offline Tintop
« Reply #8727 on: December 30, 2011, 12:12:49 PM »
pumpkin seeds ::), some rodent is going to be pissed. ;D ;D ;D
1980 CB750F (project)
77 CB550 Cafe build
550/750 Filter Thread
Sidecar Rebuild Thread
« Reply #8728 on: December 30, 2011, 12:38:36 PM »
I see 7!      CB Hoarder!!
Offline Trav-i
  • Has finally become an
« Reply #8729 on: December 30, 2011, 12:38:48 PM »
Didn't really do anything to my bikes, but I finally got around to assembling a set of carbs that I've had laying around in boxes for the last 2 years.  Although this weekend I'll probably wind up working on my cl350 so I can get ready to sell it. :'(
Forum member #9962
1992 GL1500 Interstate
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #8730 on: December 30, 2011, 12:45:44 PM »
Hauled my $300.00 CB750 K8 CL find from Ohio (found while visiting family) to FL.
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline OldSchool_IsCool
  • Really feeling like an
« Reply #8731 on: December 30, 2011, 02:45:16 PM »
Yea, those of us competing with you to find SOHC/4's wana know!!  ;D
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
Offline mjstone
  • I'm definitly not a
« Reply #8732 on: December 30, 2011, 03:47:06 PM »
WOW!  I've been away for awhile. Six pages  to read just to catch up! :o  Not that I've been out of town or even been away from the Honda, just away from the computer.
To catch up, I did get the oil changed several weeks ago, but didn't get the clutch cable replaced then.  Had the cable, lubed the hell out of it too, just didn't have the time.  Suffered with real bad shifting and having to shut down the engine to shift into neutral.  Even rode into Flint on Christmas Day to my brother in laws for the family get together with the jury rigged clutch cable.  On the 26th I said enough was enough and tore into it.  WOW what a difference! :o  Runs like a new bike! ;D
What I did today was to ride it down to Goodrich and make a payment on the '73.  More than half mine now. 8)
MJ
1972 CB500Four (Honda)
1973 CB500Four (Oliver)
maduncle
« Reply #8733 on: December 30, 2011, 10:13:59 PM »
Too hot here to work in the shed, so I wheeled my steel bench outside, set up the bench grinder and spent four hours polishing parts for the CB450.
That's four parts polished for the CB450 engine, and about another 12 to go! The oil filter cover is not too bad, a bit knocked about but polished up okay. The stator cover is a wreck, it has a big hole through it so I either need to get another one (at around $200) or make up a replacement part - possibly out of clear acrylic?
And yes - I decided to polish the POSA log manifold for the 750 whilst I was at it. If I am going to use it, then I might as well make sure it gets noticed.
Offline K5owner
« Reply #8734 on: December 31, 2011, 01:39:07 AM »
Nice job on the polishing. By the looks of the intake - I'll assume you're running a blower or turbo  ;D   or ?
-Ray
Remembering the past...   Livn' the dream
1975 Honda CB750 K5, Restored Aug/2011
1971 Honda CB175 K5, next project
1977 Honda CT70, swap meet scooter
2004 Honda NRX1800 (Rune), Cruiser
1977 Honda GL1000, daily driver
« Reply #8735 on: December 31, 2011, 01:48:14 AM »
Nice work Cliff, and you've got more energy than me, I sat inside with the cooler on drinking Johnny Walker all day and fell asleep in my chair........... ;D
maduncle
« Reply #8736 on: December 31, 2011, 01:55:18 AM »
Single Lectron 36mm carb with a billet bowl and super jet...
... well, that's the current plan!
« Reply #8737 on: December 31, 2011, 06:38:14 AM »
My clutch cable was A OK.  Didnt feel the need to replace it  and than it cracked and i had to get a new one.  Now I just cannot believe how easy the clutch works.
« Reply #8738 on: December 31, 2011, 08:49:48 AM »
A good opportunity to expand on your experience and pass this along. Often, cables that are otherwise low mileage and "well cared for" are actually in bad shape. They corrode internally from condensation cycles. This greatly increases their friction under load. Take them off and move them and they feel fine. Its the "under load" condition that proves it.
All the lube in the world will not fix this condition, only a new cable will.  This is a function of age, not so much use. When it was 1990, our CBs were at most 20 years old. Low mileage was still meaningful as gross age was still within limits.
But at a gross age of 40+, low mileage is nearly meaningless, age, gravity and condensation rule.
Offline Tintop
« Reply #8739 on: December 31, 2011, 08:58:16 AM »
Are you referring to the bikes or the riders MCR. ;D ;D ;D ;D ;D ;D ;D
77 CB550 Cafe build
« Reply #8740 on: December 31, 2011, 09:03:32 AM »
Gravity is especially hard on the rider!   :D
Offline dhall57
« Reply #8741 on: December 31, 2011, 03:11:31 PM »
Rode my KO to work today. Around 45 at 7:30 this morning so it was a nice ride in. Instead of parking it outside being Saturday I brought it inside where it's nice and warm. ;D
1970 CB750KO
1974 CB750K4
1976 CB750K6
1977 GL1000
Offline dr.seiss
« Reply #8742 on: December 31, 2011, 03:17:24 PM »
Finished putting all the pieces back together to get it temporarily road "worthy" for tonight's ride to Big Sur. Should be fun!
« Reply #8743 on: December 31, 2011, 03:45:24 PM »
That's a thing of beauty mate, you're a lucky man! Cheers, Terry. ;D
Offline :c:
  • payin the cost to be the boss
    • I will teach you to SCUBA dive in the comfort of your own home.
« Reply #8744 on: December 31, 2011, 04:22:13 PM »
Synced carbs and checked timing.
“Travel is fatal to prejudice, bigotry, and narrow-mindedness, and many of our people need it sorely on these accounts. Broad, wholesome, charitable views of men and things cannot be acquired by vegetating in one little corner of the earth all one's lifetime.” -Twain      www.deepbluevoyager.com
Offline MoMo
  • Ride like you're invisible
« Reply #8745 on: December 31, 2011, 04:26:36 PM »
Went for a 100 mile ride.  It was in the mid 50's in beautiful, expensive Chester County.  While in Lancaster County I ran across an Amish tack shop.  Well, the zipper on my leather pants has been broken for a year or so (cannot ride when it is too cold as it gets sort of chilly down there :P). The young Amish man was in his front yard, working as they always do, and I asked him if he could fix it.  He said sure and that it would cost about $3.  Needless to say I left my pants there ::)...Larry
« Reply #8746 on: December 31, 2011, 05:26:18 PM »
Geez it must have been cold riding home with no pants on Larry? ;D
Offline MoMo
« Reply #8747 on: December 31, 2011, 05:58:10 PM »
Well I did get a lot of strange looks......................... :P :P   It was so warm jeans were adequate for warmth...Larry
« Reply #8748 on: December 31, 2011, 06:17:56 PM »
Ha ha, well i'd just about swap with you mate, it's almost 100 degrees here as I type this, and it'll be like this for the next couple of days. Thank God for my "Swamp Cooler"! 'D
Offline mjstone
« Reply #8749 on: December 31, 2011, 09:48:28 PM »
Well, since its now 42 minutes into the new year here in Michigan, yesterday I was sent out to the grocery store 4 times getting stuff for the festivities.  Of course I had to go on the Honda.  One time I didn't get my helmet off when she sent me back out for something she forgot to tell me to get before!  However I didn't get the bike covered up until after midnight so at least I did that to the bike today.
MJ
