Author Topic: What did you do to your bike today ?  (Read 3206838 times)
Offline WhyNot2
  • I'm finally an
« Reply #9450 on: March 05, 2012, 03:10:26 PM »
........................drilled the clutch basket to improve oil circulation.
I really need to do this too.                      Lazy I guess............
Offline WhyNot2
  • I'm finally an
« Reply #9451 on: March 05, 2012, 03:11:08 PM »
I really need to do this too.                      Lazy I guess............or lack of confidence.
Offline piute
  • Piute
  • TRICK OR TREAT...B....es
« Reply #9452 on: March 05, 2012, 03:28:29 PM »
   put in dual aliments in rear signal lights so now have running and signal.
Ride to live Live for Jesus
1977 750 F2
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #9453 on: March 05, 2012, 03:42:10 PM »
Did you change the lenses? Most places require rear-facing running lights be red...  ???
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline Tintop
« Reply #9454 on: March 05, 2012, 05:06:40 PM »
Still waiting on the main jets I ordered for my 550, in the meantime I'm trying to get an 83 Yamaha XS650 road worthy again for a friend of mine. Typical kind of bike that's sat for the last 9 years. Thorough cleaning of the carbs got it running again then adjusted valve lash and cam chain and it actually doesn't sound too bad but now electrical gremlins are popping up. The headlight won't come on because the alternator isn't charging worth a squat and I'm finding out the alternator is one of Yamaha's weakest links at least on this bike it is. Just my luck.  >:(
The windings tend to come apart at higher RPM's.  That's why most sidecar racers that use the XS motor run a total loss system.
1980 CB750F (project)
77 CB550 Cafe build
550/750 Filter Thread
Sidecar Rebuild Thread
Offline Bailgang
  • Scott
  • Indiana
« Reply #9455 on: March 05, 2012, 06:14:22 PM »
Well my friend did provide another 83 XS650 as a parts bike to get the other together so hopefully I have enough usable parts between the two to get it's alternator figured out. I did notice while researching it that permanent magnet alternator conversions is a popular alternative for the XS engines. Electrical definitely isn't my expertise but I can figure electrical issues out provided I have good info so I'm busy reading up on all the charging system test procedures for this particular bike.
« Last Edit: March 05, 2012, 06:15:53 PM by Bailgang »
Scott
71 cb350 twin
77 cb750 F2
83 gl1100 Interstate
Offline Greggo
  • Somebody's
  • Helmets Save Lives. Period.
« Reply #9456 on: March 05, 2012, 06:59:05 PM »
Fitted the center stand to do some chaintenance after a 50 mile ride in the twisties  :)
Stopped in a park with some big ole redwood trees to take a leak..
Offline Really?
« Reply #9457 on: March 06, 2012, 07:24:32 AM »
Hey Greggo, do you attach the spring when you mount the centerstand back to do the maintenance?
The Wife's Bike - 750K5
The Kid's Bike - 750K3
Offline Dimitri13
  • 1974 CB550K
« Reply #9458 on: March 06, 2012, 09:19:08 AM »
Changed the throttle return spring... AFTER getting carpel tunnel in just one short week of riding, plus my job. Either of those separately would've been fine, but doing them together caused it real fast.
The spring is now MUCH light. I can actually open the throttle with two fingers. I'm not sure how long the spring will last, but I'll post in about a week about it.
Offline fire113
« Reply #9459 on: March 06, 2012, 01:28:23 PM »
...took alle tree bikes, claned them and rode them.
The K0 was in winter sleep for ~1/2 Year, 2 kicks later it was running very good.
Offline thrutheframe
« Reply #9460 on: March 06, 2012, 03:34:39 PM »
Rode her hard.
'74 cb 750 K4
'75 CB 360T
'90 RC31 Hawk GT
Offline Picasoo
« Reply #9461 on: March 07, 2012, 01:30:21 AM »
First singing of my ol' lady...
Honda cb750 f super sport 1975 first start
'75 cb750F super sport
Offline Bailgang
  • Scott
  • Indiana
« Reply #9462 on: March 07, 2012, 02:09:44 AM »
My oldest son finally saved the money needed to paint the tank and side covers for his 73 750 and the pieces are at the paint shop now. After that the bike just needs a few more things and on the road it will be.
Scott
71 cb350 twin
77 cb750 F2
    • http://forums.sohc4.net/index.php?PHPSESSID=tgdn9tksmkn9sfkvnfk78o9fc2&/topic,60973.0.html
« Reply #9463 on: March 07, 2012, 06:52:16 AM »
got the forks ready..and put back on...theked the front hveel..it run heavy/tight/??hvat call you it.??.have to put a chimms behind the bearing to take the pressure of...to loosen bearings up
« Last Edit: March 07, 2012, 06:54:44 AM by strynboen »
Offline Greggo
  • Somebody's
« Reply #9464 on: March 07, 2012, 08:56:55 AM »
Nope.  Too much effort to get that thing back on...even with the pennies stuck in there.
Offline ThomasD883
« Reply #9465 on: March 07, 2012, 02:12:13 PM »
Took off my air filter cover and got in a good ride, I feel all warm and tingily  ;D
Diesel deeds, done dirt cheap
Offline Tews19
  • I am no
« Reply #9466 on: March 07, 2012, 02:24:08 PM »
IM IN CAPS TODAY BECAUSE I CHARGED MY BATTERY ON THE 550K. I PLUGGED IN THE BATTERY. ATTACHED THE FUEL LINE FROM THE TANK TO THE PETCOCK. TURNED THE FUEL TO ON.....PUT THE CHOKE ON, AND VRRRRRRRRRRROOOOOOOOOOOOOOMMMMMMM........ I LET HER WARM UP FOR A FEW AND THEN TURNED THE CHOKE OFF AND WENT FOR A 5 MINUTE RIDE....................... ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D :o :o :o :o :o 8) 8) 8) 8) 8) ;D ;D ;D ;D ;D ;D ;D
1970 Honda CB750 survivor.
Offline ThomasD883
« Reply #9467 on: March 07, 2012, 02:44:14 PM »
Every spring is like that first ride all over, LOVE IT . Keeps me sane
Offline Greggo
  • Somebody's
« Reply #9468 on: March 07, 2012, 03:43:36 PM »
Rode the 500 in the hills :) and ordered some gaskets from Honda: 2 gas cap gaskets, and 1 petcock seal..a quick twenty one bucks...
maduncle
« Reply #9469 on: March 07, 2012, 05:27:18 PM »
Rode to work this morning on a smooth flat level stone free road and watched my right wing mirror spontaneously crack.
Like - nothing hit it, there were no bumps in the road - it just went 'pop' very loudly and cracked in half.
It is one of a pair of replacement mirrors I only just got from the UK and fitted to the bike a week ago.  >:(
Offline Really?
« Reply #9470 on: March 07, 2012, 08:17:09 PM »
Aaannnnnnd, your in caps because it died after 5 minutes?
Offline Tews19
  • I am no
« Reply #9471 on: March 08, 2012, 05:16:27 AM »
Oh no she didn't die. the kids came home from school. Bike ran like a top. Very pleased with her. Now I can't wait for a full riding season and having a bike that is ready to go. Last summer it seemed as if i had a bike in the shop all the time. This site has helped me learn how not to bring it to the shop and do the work myself.
Offline mick7504
« Reply #9472 on: March 08, 2012, 05:58:28 AM »
I bought this POS motor quite a while ago and it's been a long term project.
Finally it's beginning to take shape.
It's now an 836 with quite a few mods inside and out.
The engine covers have been bead blasted and painted with Harley textured engine paint (with a Harley price tag) and overlayed with VHT Satin Black engine enamel.
Here are a few pics of the before and after.
If I was you
I'd be worried about me.
Offline JustinLonghorn
« Reply #9473 on: March 08, 2012, 06:39:25 AM »
Very nice man. Motor looks great.
"So you had better do as you are told
You better listen to the radio"
My Super Sport Build
Offline Raef
« Reply #9474 on: March 08, 2012, 02:09:23 PM »
added another piece of hand made body work, one more side cover and a little wind screen and I'll be riding it.
