Author Topic: What did you do to your bike today ?  (Read 3340755 times)
Offline twallace
« Reply #9725 on: March 29, 2012, 10:46:42 PM »
Well technically I started yesterday because its now 1:30 in the am. Rebuilt my front brakes including the master cylinder. I was really worried about getting that clip out because of all the stories I've read about it being hard. Fortunately the entire guts fell out when I started taking it apart so it was clearly way overdue. Several beers later I now have nice smooth powerful front brakes and a new appreciation for the magic that happens inside that master cylinder. Pic is a before shot but I couldn't post without a pic.
Offline Spanner 1
« Reply #9726 on: March 29, 2012, 11:05:19 PM »
Took the  K8 carbs apart to fix a leak on #2 and 4.... sho'nuff some tank crap had done it's business in the float valves. Fixed 2 no prob., 4 wouldn't seal even when holding the float up with my hand so dived into some 'used' carb parts and found a rubber tipped valve. Replaced the offending one ( which looked fine btw ) and prob. solved....... then checked the acc. pump squirters... yes, 1 and 2 worked great, 3 and 4 nothing.
side note... all this stuff was working 3 months ago..... moral of the story = do not leave Ethanol gas in your carb, unused for more than a week  :o... Cleared #3 squirter with a very small sewing needle poked into the tiny opening in the squirt post.... #4 no such luck !....had to press the squirt post down and out of the carb ( not a lot of folks know you can do this  ;) ) when pressed down, the post will unseat the brass 'bung' beneath it, need to have a catch cloth below to hold the bung and post.... poked the post clear and re-installed... 4 good squirters now ... yeah  8)
Offline dhall57
« Reply #9727 on: March 30, 2012, 12:39:36 AM »
Got a new Dunlop D404 for the front of my 650.  100/90-19.  From eBay/Chapparal Motors.  $75.88+$7.99 shipping.  I ordered it Tuesday and it showed up today.
I run the same on my KO and K6. Good all around tire for the money.
1970 CB750KO
1971 CB500KO-project bike
1973 CB350G- project bike
1974 CB750K4-project bike
1974 CB750K4
1976 CB750K6
1977 GL1000
1997 Harley Wideglide
Offline Grey
« Reply #9728 on: March 30, 2012, 06:15:49 AM »
Sooooooo, howdya do it?  Strapped to the floor?
I drill the concrete floor with 1/4" carbide bit. Then pound in Hillman (straight shank Green color sometimes blue) plastic plug. I first used two on each side about 6" apart with the to inboard ones about 16" apart about 1 1/2" deep. Then I get four 3/16" wood screw hooks and screw them in at least an inch. Latley though I've only been using two hooks and one strap. Seems to hold the weight fine as you can see below.
Offline Tews19
  • I am no
« Reply #9729 on: March 30, 2012, 09:18:09 AM »
Saddest day with the 550K today. I sold her :'( :'(. She was running like new, no issues whatsoever, new tapered bearings, fork seals, fresh oil and a new set of chrome ears on her and now she has found a new home. The wife wanted some room and one less bike taking up space. The new owner seems genuine, maybe we will see him here..............Now on to getting the 750 up and running like a top...
« Last Edit: March 30, 2012, 09:24:46 AM by Tews19 »
1970 Honda CB750 survivor.
Offline cben750f0
« Reply #9730 on: March 30, 2012, 04:41:23 PM »
cleaned and lubed all the cables, pivot points etc, cant believe how bad they were untill they after they were lubed.....hahah
peace
« Reply #9731 on: March 30, 2012, 05:27:54 PM »
Kinda makes me wonder, is there anything that most married men won't do to please their wives? I buy and sell bikes all the time, but I've never sold one because my wife has asked me to, which is probably why we're still married 30 years on. Maybe I should re-phrase the question, is there anything that a wife won't tell her husband to do? It's a sad day indeed mate, you have my sympathy. Cheers, Terry.  :'(
Offline Tews19
  • I am no
« Reply #9732 on: March 30, 2012, 06:25:52 PM »
Ahh it wasn't in a manner where she said sell now! She is great!  She "allowed " me to order HondaMans book tonight! Plus I still have my 550f and my 71 750.
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #9733 on: March 30, 2012, 06:33:42 PM »
Made major progress getting the wife's CH250 Elite back together. Had removed ALL the plastic bodywork to replace the tires and carb, like to never figured out where all the screws belonged! Should finish up tomorrow morning so I can get started on my own project. Starting my project was contingent on getting hers done...  :o
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline CycleRanger
  • No comment about being an
« Reply #9734 on: March 30, 2012, 08:13:46 PM »
Wrestled the engine back out due to the oil leak from the valve cover, dammit! >:(
It didn't give me too much trouble coming out, although I remember now when I put it in the back wheel was on and the bike sat lower making it a little easier...
The real fun was getting it on the engine stand.
Now I gotta wait for new gasket and brake shoes to arrive...  :P
Offline Spanner 1
« Reply #9735 on: March 30, 2012, 08:23:28 PM »
K8...fixed it and rode it  ;D... persistent leak from #2 carb was a brain teaser... drip, drip, drip but not out the overflow... O.K. then, must be the carb bowl seal, took the carbs off again  >:( and double-checked the gasket... all o.k. Put back together, turn on the gas and dripping again  >:(.... ..sheesh ! looked closer with a flashlight.... gas was coming down from above the bowl/body. Traced it up to the little in-line filter, which was cracked and leaking..... ( had to use it 'cos no filter on the petcock )... Ya never know with these old bikes  :)
« Reply #9736 on: March 31, 2012, 02:57:13 AM »
I rode my Triumph over to help a fellow CB750 owner get his bike going after he got ripped off by a dodgy bike shop, and in the process, after some horse trading, scored this beauty! Check out the number plate, is that Karma or what? ;D
maduncle
« Reply #9737 on: March 31, 2012, 03:02:40 AM »
Just one word...
Commission.
« Reply #9738 on: March 31, 2012, 03:23:50 AM »
Ha ha, no worries Cliff, I'll get a cheque off to you as soon as I finish paying for the BMW! ;D
Offline dhall57
« Reply #9739 on: March 31, 2012, 03:31:18 AM »
Your first Beemer Terry? What had the shady bike shop done to your friends 750?
1970 CB750KO
1974 CB750K4
1976 CB750K6
1977 GL1000
« Reply #9740 on: March 31, 2012, 04:06:40 AM »
Made a second foot peg, took off the pasangers to measure and ordered more aluminum.
« Reply #9741 on: March 31, 2012, 04:37:20 AM »
G'Day Mate, no, this one will be my 5th BMW, and my second R100RS. Tom, who Cliff (maduncle) introduced me to bought a K2 cafe racer that needed some work so he took it to a bike shop, and it took them a year to give it back.
All they did was install a big bore kit and a pretty ordinary paint job, (which they also managed to chip quite badly) synched the carbs and did some minor electrical work, and charged him 3500 bucks.
That was bad enough, but he could have lived with that if the bike was running well, with no more problems. This wasn't the case though, they knew that the countershaft seal was leaking badly but didn't bother to fix it while the engine was out of the frame, so it's gotta come out again, it's only running on 2 cylinders (1 and 2) but I think that's an ignition issue so no biggie, and the starter clutch is clagged.
I'm going to do all the remediation work for him as part payment on the BMW, plus give him some cash, the BMW needs a bit of work too, but nothing serious, and it'll be a nice long distance bike. I sold my last R100RS 10 years ago, so it'll be nice to have another one again. Cheers, Terry. ;D
Offline Roach Carver
« Reply #9742 on: March 31, 2012, 04:45:19 AM »
That is a great looking bmw. Looks like it has a set of konis on it as well.
« Reply #9743 on: March 31, 2012, 05:00:18 AM »
Thanks mate, it's actually pretty clean under all that dust, the shocks are new Ikons that Tom bought for it, but the good thing is that he kept the original Boge shocks, so if I ever restore it, I've got original parts. Cheers, Terry. ;D
Offline MoMo
  • Ride like you're invisible
« Reply #9744 on: March 31, 2012, 05:08:18 AM »
Nice Beemer Terry-must have been predestined with that semi-personalized plate :P.  Now you have a back up for the next Triumph failure ::)  Have fun with it...Larry
« Reply #9745 on: March 31, 2012, 05:15:51 AM »
Ha ha, don't remind me about the bloody Triumph Larry, I think I'll park it in my lounge room and just look at it, while I ride my (much more reliable) old bikes! ;D
Offline dhall57
« Reply #9746 on: March 31, 2012, 06:27:08 AM »
That's ridiculous Terry. Keeping his bike for a year and charging $3500 and the bike is still not right >:( Seems like word would get around that this shop is a rip-off and people would stop taking there bikes to them. There doors need to be closed not open. What ever happened to pride in your work and giving the customer what he paid for.
I know since it's in your hands now it will be running top-notch real soon ;)
« Last Edit: March 31, 2012, 06:31:33 AM by dhall57 »
1970 CB750KO
1974 CB750K4
1976 CB750K6
1977 GL1000
Offline thrutheframe
« Reply #9747 on: March 31, 2012, 06:55:59 AM »
I'm assuming you put a bike on its center stand and ratchet strapped the rear end in place THEN took everything off?  It's a great idea, I can't wait to try it.
'74 cb 750 K4
'75 CB 360T
'90 RC31 Hawk GT
Offline the technological J
  • deliciouso!
« Reply #9748 on: March 31, 2012, 07:12:18 AM »
what kind of bike is that? and am i missing an easy way to get that engine outta there that doesnt require a full tear down or a hack saw?
94 ST1100..Gone
72 750 K2 Stay tuned!
Offline Grey
« Reply #9749 on: March 31, 2012, 07:54:35 AM »
Put bike on center stand and pull rear wheel first. Then strap it down. I've been doing this for years and it's very stable. Even when pulling the engine. The nice thing about it is when the rear wheel is off, you just ratchet down the rear to get the front off the floor and the front wheel just drops out easily.
It's a 83 Interceptor. The one in the backround of the pic of the 550 torn down. Topic 9730. One of the first in the USofA. Frame #820.
« Last Edit: March 31, 2012, 08:05:46 AM by Grey »
