Author Topic: What did you do to your bike today ?  (Read 3264996 times)
Offline lucky
« Reply #10200 on: May 07, 2012, 07:26:26 AM »
Back in the garage to play!
Fit new plug wires. Finished the install of the stainless braided oil lines now that I had both o-rings and new hardware. Installed the battery and turned the key - we have light, horn and turn signals. Rebuilt the rear caliper. Installed a NOS rear master. Installed the rear wheel. Hooked up the brake system.
Let's take a peek at what it's going to look like
Thanks for posting the photos.
That is a very nice job you are doing!!1 WOW!!!
Offline lucky
« Reply #10201 on: May 07, 2012, 07:30:03 AM »
Uh oh.. I was flogging it down a hill and somehow missed between 2nd and 3rd, revved up from redline to over 12k.. Now one cylinder isn't firing. I hope I didn't bend any valves or blow up a spark plug. This just happened about 15 minutes ago so it's still too hot to look into.
Any guesses?
Been there, done that on 1st to 2nd. Floated valve, broke valve, BIG hole in piston, locked up big time, destroyed engine. Hope your's is minor. That is what got me into "fixing" these things  ;D The one of the right just went into it.
Thankfully it's not that severe. Engine still turns and runs. At first I thought it was just a main jet that got clogged up or something, so I took my carbs off and gave it a good cleaning. Went for a test ride and it ran decent (although it was shooting out flames and popping a bit at idle because I went from 45 slows to 38 slows). At some point during the ride, this happened. I don't know when, because I looked down at a stop light and discovered my engine soaked in oil.
I stopped at the local drug store and assessed the situation. Since I was able to get there from that stop light, I assumed I could get home (about three minutes ride), and I did. Thankfully no oil made it on to my rear tire and I didn't eat it.
Looks like I'm down for a few weeks while I get the minimum amount of parts (tappet cover, adjusting screw, and nut), then tear the head apart and go from there...
I thought #40's were the stock slow jet size for your bike?
BTW....Did you notice the tappet cover has broken off threads in the hole?
Thats why oil may be all over the place.
Maybe the engine leaked oil from that cracked tappet cover until it was too low on oil?
« Last Edit: May 07, 2012, 07:34:02 AM by lucky »
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #10202 on: May 07, 2012, 09:18:33 AM »
I think the tappet cover was actually busted out when the tappet adjuster came loose. He didn't have to remove the tappet cover, it was already gone...  :o
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline jessezm
  • '77 cb400f cafe build
  • Always wrenching...
« Reply #10203 on: May 07, 2012, 10:39:27 AM »
HAH!  I was wondering if anyone would notice!  They were sharing a carb-dip bath together...   I also disassembled the front master cylinder and cleaned it, and took apart the front caliper.  Since the MC was shot (ever seen a reservoir full of dried crumbly looking stuff?) I had to pump the caliper piston out with a grease gun.  Worked like a charm, and miraculously, the piston itself is near perfect!  I also de-varnished and de-rusted my gas tank, I just didn't have pictures of the rest of it...  I'm trying to put a $300 barn find back on the road on the cheap
Went from this:
To this:
Looks great...but how did you fit the brake caliper B and piston in your carbs?  ;D
« Last Edit: May 07, 2012, 10:49:08 AM by jessezm »
Offline Dimitri13
  • 1974 CB550K
« Reply #10204 on: May 07, 2012, 12:19:17 PM »
Any guesses?
I thought they were too, which is why I bought a set of 42s from Jets R Us -.- Hopefully I can exchange them for 40s when they get here.
The tappet cover busted off at some point during that ride, and it was spitting oil all over the place.
Offline jessezm
« Reply #10205 on: May 07, 2012, 12:31:57 PM »
I had one experience shortly after rebuilding my 400f where I got higher than I intended to in the revs and found all of my tappets had backed themselves out a significant amount.  It sounds like that's what happened to you--at least one of your tappets got loose and backed out so far it pounded into your access cover.  In that picture had you removed the tappet yourself or did it come all the way off and fly around inside the cam cover?  Either way, it does sound like you're in for some close inspection and rebuilding...  Dang!
Any guesses?
Offline lucky
« Reply #10206 on: May 07, 2012, 01:18:10 PM »
Any guesses?
You may need those #42's.
Can you give me the run down on your bike?
Year and size?
Air intake system?
Exhaust system?-muffler?
Idle jet?
Mainjet?
needle clip position?
Mixture screw position?
Offline Greggo
  • Somebody's
  • Helmets Save Lives. Period.
« Reply #10207 on: May 07, 2012, 03:07:20 PM »
Bought a sweet flat tracker seat/light from a local CL guy.  Got an O.G. Clymer manual, and a master cylinder to rebuild...
Offline fire113
« Reply #10208 on: May 07, 2012, 03:34:30 PM »
...K0 speedo came today  :( sometimes I hate ebay  >:( It's not working.
Offline Statenheimer
« Reply #10209 on: May 07, 2012, 04:18:07 PM »
That flat tracker seat is AWESOME!  Nice find.  8)
'75 550F - Resto/mod - Riding - But never really finished...
'76 550K - Cafe build - On hold
'78 550K - Parts - Good engine for another day
'73 500 - Parts - Engine seized
'90 CB-1 - No longer seized! but still title-less
Offline Greggo
  • Somebody's
« Reply #10210 on: May 07, 2012, 04:34:42 PM »
Thanks!  Mocked it up on the 500/4 it will end up on...  8) 8) 8)
Can't wait to lose the fender on this bike.
Offline Roach Carver
« Reply #10211 on: May 07, 2012, 04:45:15 PM »
Dimitri. I may have missed something but I did that once. It backed an adjuster out. I limped home and set valves. No problem since. Looks like your adjuster backed out and broke the tappet cover.
Offline Greggo
  • Somebody's
« Reply #10212 on: May 07, 2012, 05:56:22 PM »
I need to stop finding ridiculous deals on parts...$60 shipped for used S&W shocks  :o
Offline Tews19
  • I am no
« Reply #10213 on: May 07, 2012, 06:01:24 PM »
Drove my 550F 49.9 miles, had to plug in the rear brake light as it unplugged when I installed the seat..... PLayed with the idle screw a bunch of times and still need to sort out the idle.... Hopefully will change out the main jets this weekend to 100's....
Got a few goodies in the mail for the 550- new jets from Jets R US
rear turn signals for my 71 750...
1970 Honda CB750 survivor.
Offline Hasenkopf
  • Really, I'm not an
  • This space for hire.
« Reply #10214 on: May 07, 2012, 08:33:21 PM »
I wanted to post a pic of my subaru oil temp gage installation, but keep getting a message "connection to server was reset"...... ::)
I like berries.
Offline the technological J
  • deliciouso!
« Reply #10215 on: May 07, 2012, 08:54:28 PM »
Damn Jerry  :o That sh1t looks HOT!  I like those rear spoked F wheels.  I see BOTM in your future ;)
got my vote!
94 ST1100..Gone
72 750 K2 Stay tuned!
Offline turbo_nine
« Reply #10216 on: May 08, 2012, 07:37:18 AM »
Replaced the megaphone-style exhaust on my 400F with a David Silver piece last night.
The DS piece looks great though fitment wasn't perfect and I've got to figure out a kickstand stop since mine was probably discarded by the PO.
Outgoing muffler wasn't bad.  Not real high-quality, but sounded decent for its additional noise.  Might polish it up and offer it for sale if there is interest.
'75 CB400F
« Reply #10217 on: May 08, 2012, 08:15:58 AM »
Installed my new front SS brake line from Slingshot Cycles.
Ordered last Wednesday. Got it yesterday.
Great work Shaun!
    • http://forums.sohc4.net/index.php?PHPSESSID=pgbcl5t847j9qc8u1sd8t3hsd5&/topic,60973.0.html
« Reply #10218 on: May 08, 2012, 09:31:59 AM »
 glued the old coils, hvere the new kabels vas fit,hope it works ...we have some rainy days from now...so get it testet at first trip
Offline CBNJ74
  • Sweep the leg!
« Reply #10219 on: May 08, 2012, 10:04:58 AM »
Tank and sidecovers came back from paint this week. Started putting the old girl back together.
The paint looks great!
Mark Byrd did it.  mark8149@yahoo.com
The pictures do not do it justice.
1973 Honda CB750K
1983 Honda VF750 Interceptor
2005 Triumph Thruxton
2012 Ducati Monster 1100evo
Offline Dimitri13
  • 1974 CB550K
« Reply #10220 on: May 08, 2012, 11:15:49 AM »
Year and size?
Air intake system?
Idle jet?
Mainjet?
74 550
Stacks
MAC 4-1 headers, shorty straight pipe
Idle was 45 (way too much), went down to 38 until I get a different one
Main is 120. I got 110 and 115 coming.
Stock position (4 from the top)
Stock position (1-1/2 - 1-3/4)
Offline gnarlycharlie4u
  • Far from being an
« Reply #10221 on: May 08, 2012, 12:43:05 PM »
that looks spectacular.
What did I do to my bike today?
got drunk and took my life into my own hands:
http://gnarlywrench.blogspot.com/2012/05/shock-disassembly.html
Offline CrankyOldGuy
  • Wish I was a
« Reply #10222 on: May 08, 2012, 03:40:41 PM »
I bought a motorcycle jack (lift).  At least the 750K1 now has a set of wheels  ::)
Harry O.
750 K1 Original Owner
« Reply #10223 on: May 08, 2012, 04:31:15 PM »
I used tipsy wrench with various luck over the time.  This is pretty smart, reminds me of your center stand spring and pennies.
Offline HonderCB
« Reply #10224 on: May 08, 2012, 05:05:14 PM »
went on a joy ride after work and did the ton... that never gets old.
then when i got home i decided it was lookin too good to not snap a pic with my phone:
77' CB750F
81' CB650C - SOLD
