Author Topic: What did you do to your bike today ?  (Read 3668839 times)
0 Members and 24 Guests are viewing this topic.
« Reply #11700 on: August 23, 2012, 06:10:13 PM »
Happy ending?!
Offline Dimitri13
  • 1974 CB550K
« Reply #11701 on: August 23, 2012, 06:57:32 PM »
Not sure if I posted (text) about this earlier, but I tried my hand at welding for the first time. Needed to join a reducer to a mid-pipe because an extra coupler in there made the bend stick out too far (scraped the pipe several times on hard leans), and it leaked like a sieve. Didn't practice at all (although I DEFINITELY should have). Came out super ugly, and took about an hour's worth of welding and grinding to get it to seal up. It's definitely a good candidate for exhaust wrap. Should I paint it first, for an extra layer of heat retention?
Here's a couple pictures:
What the weld looks like (that's the pretty side).
Finished product (no wrap or paint yet).
Also, someone shared this on my motorcycle facebook group. I thought it was absolutely hilarious:
« Last Edit: August 23, 2012, 07:32:01 PM by Dimitri13 »
Offline cafevee
« Reply #11702 on: August 23, 2012, 07:51:04 PM »
I just rebuilt the forks on my 550 :)
Was supervised the whole time but I still did it. :)
Now to spend next 2 hours looking at the bike pics on the forum... with a Guinness in hand. Cheers all.
Offline Old75_ratafe
  • CB750 Cave Spelunking
  • 1975 CB750K
« Reply #11703 on: August 24, 2012, 12:03:28 AM »
Anybody out there have experience with missing rubber grommets on the round-top carbs where the slide rod goes through?  How important is this part and what clever fixes have you come up with for replacements?  This has to have been discussed somewhere in this vast resource of knowledge.... :)
Mines been missing for years never hurt me.  Just check it for road grim build up once and awhile and make sure they are moving freely when you change oil and it should be just fine.
1975 CB750K
Project Back in Black
« Reply #11704 on: August 24, 2012, 02:42:07 AM »
CB750 front brake master cylinders. What a PITA. I installed a kit in one awhile ago on Ken's K1, then for the last couple of weeks, I've bled up the brakes, got no lever pressure, so I've gone onto the next job. Now it's almost finished, I have to look closer at why it's not working.
Today I found another MC, installed another kit, bled it up, still no joy. Turned out both MC's had blocked breather holes, and they were blocked so bad I had to use a jet drill to unblock one. As soon as I did though, I had pressure, and it took me just five minutes to bleed them.
I suppose what really annoys me is that it took me so long to realise what was wrong, I've only been playing with these old buggers for 36 years!  :P
Offline Bailgang
  • Scott
  • Indiana
« Reply #11705 on: August 24, 2012, 04:49:31 AM »
It's going to be a busy week end for me. First off I got my first flat tire as I was coming home from work yesterday so that's getting fixed, fortunately I was only a few blocks from home. I've also got an annoying front brake squeal so I've got another rotor that I'm going to cross drill and see if that eliminates that once and for all. And then last but not least I have new fork gaiters to install.
Scott
71 cb350 twin
77 cb750 F2
83 gl1100 Interstate
« Reply #11706 on: August 24, 2012, 05:39:16 AM »
Misery loves company. Glad to hear it!  ;)  I had a royal pain time bleeding mine too. And as we both know there is no magic. Its either this or the other thing and they should bleed up quickly. Yet we pump and pump.
When they do bleed up, we kick ourselves for not getting it right sooner.
Glad you found your prob.
Offline kslrr
  • There is always a Blaster when there is a
  • Raising her up right!
« Reply #11707 on: August 24, 2012, 08:09:35 AM »
Terry, can you give more detail as to where the breather hole is?  Maybe a pic?  I have been restling with trying to properly bleed the front brakes on my CBs for years.
Now  1972 CB350FX (experimental v2.0)
        1981 CB650c Custom with '79 engine (wifes)
        1981 CB650 engine
        2004 HD XL883C Custom
        1977 Yamaha XS750D (in progress)
Then 1972 CL175
        1964 Yamaha YGS-1T
No ride is a Bad ride
Offline Blitzburgh207
« Reply #11708 on: August 24, 2012, 09:19:16 AM »
Pulled the motor.  No sign of the missing tappet nut up top  :-\ Hopefully I'll find it in the oil pan...  Otherwise I'm going to run it and see what happens.
1978 CB750 K8
Offline MoMo
  • Ride like you're invisible
« Reply #11709 on: August 24, 2012, 09:29:16 AM »
No, I am not Terry but I am sure he is referring to the hole inside the master cylinder.  There is one hole that rarely gets clogged and there is another in the middle of a small, cupped recess.  It always gets clogged, you'll need either a guitar string or a very small drill bit to clear it out...Larry
Offline CycleRanger
  • No comment about being an
« Reply #11710 on: August 24, 2012, 06:52:36 PM »
Received my new Thai rims for the CJ360T today.
Except for the large "Union Cycle DOT" stamped on the side they look pretty good. :)
« Last Edit: August 25, 2012, 10:41:21 AM by CycleRanger »
Offline Magpie
« Reply #11711 on: August 24, 2012, 06:59:49 PM »
Got the K1's ready for a show on the weekend upIsland. Cliff.
Offline Dimitri13
  • 1974 CB550K
« Reply #11712 on: August 24, 2012, 10:35:06 PM »
Replaced my broken lowbeam headlight after about 6 months of riding around with the highbeam angled lower.
Offline DJ_AX
« Reply #11713 on: August 24, 2012, 10:58:55 PM »
Took off the headlight, turn signals, wire harness, gauges, mirrors, horn, seat latch, oil tank, and a few other things.
For taking my time, it's going rather quickly.
« Reply #11714 on: August 25, 2012, 02:54:58 AM »
Thanks for the kind words Ron, and KSLRR, what Larry said is correct, but I can post a pic, if you like? What pissed me off today was letting someone else down. Ken was supposed to collect his beautiful K1 after it spent several months here as I worked thru Ken's wish list.
I had it all together, got all the electrics working great, installed and statically timed the Dyna 2000 ignition, everything was sweet until I poured some gas in the freshly painted tank, and turned the fuel tap on.
Fuel pissed out everywhere! Fuel was running out of one of the overflow tubes, out of the airbox, out of one of the breather hoses for Christs sake, there was gas pissing out in all directions. Great. I started pulling off float bowls and swapping out needles and seats, then one of the wire clips that retains the fuel bowl for #3 carb fell off. Fcuking Wonderful.
I challenge anyone to replace that wire clip while the carbs are in place, I gave up trying and rang Ken to tell him it wasn't gonna be ready. Ken was great, no problem, he said he'll pick it up in a couple of weeks which is great, but it still really pissed me off. Tomorrow the carbs are coming off, and I'll thoroughly clean them and install new kits while I'm at it. Cheers, Terry. ;D
Offline Dimitri13
  • 1974 CB550K
« Reply #11715 on: August 25, 2012, 03:58:35 AM »
Looks incredible Terry! Only thing that bothers me is the black front caliper sticks out way too much against the silver/chrome background.
_______________________
Took it for a quick test ride after making a quick adjustment to the carbs and came back an hour later with a long story.
It's quite long, and may contain some foul language.
Damn, bad night for a ride or what?
First I remove the screens from my stacks to see if that'll lean up my mixture enough. I get done with that, and turn on the bike. It has a bit of trouble starting up cold, which is a good thing (if it starts up easily it's too rich). I get on there, and as soon as I pull out of my driveway, I feel a little stumble (also normal for a cold take-off), then I feel some strong pull (also good).
I get out of my neighborhood and down to the next block, and the older gent in the car next to me points out my tail (running) light is out. Damnit. >:| I take note and ride my rear brake lever enough to trigger the brake light, but not engage the brakes. Not too bad. I get further up the road and plan on stopping in front of the fire station to check my wires, because their driveway is well-lit.
Sitting at the light one street before the fire station, I feel it starting to stumble. Classic sign of running out of fuel. I reach down to switch to reserve. Oh #$%*. I'm already on reserve. How did that happen? I try to take off and make it up there. No-go. As soon as I let out the clutch, it dies. Since it's a fairly long street and uphill, I sure as hell wasn't going to make it up to the fire station. Pulled a u-turn and stopped on the sidewalk to check out my wiring.
Nothing wrong that I could see. I disconnected all the wires and reconnected them. No luck. :( Time to push my #$%* to the gas station about 1/4mi. away. Since I don't have a tail light, I want to turn on my turn signal so people can see me. I decide the right one would be better, because it marks the left side of my bike, and I'm on the right side of the road. Well guess what? Left turn signals are out. Right turn signals work. I immediately realized what was wrong. My blinker solenoid needs the contacts cleaned and jiggled. Since I didn't have the tools for that, I couldn't do it there.
Finally made it to the gas station, all sweaty and out of breath. Some #$%* is sitting at the pump in his car playing #$%*ty music way too loud with too much bass. #$%*ing #$%*. The entire time I'm there, which is about 10 minutes, he's there. I finally get up and ask him to be a bit more polite, and he finally decides to leave. What a #$%*. Time to leave myself.
I get out on the road, and who did I pull out in front of? None other than Johnny Law. Damnit. I'm in front of him for a few blocks, and nothing happened. Thought I was in the clear, because he had his turn signal on. Nope. WOOP WOOP. :( I pull into the nearest parking lot, because I'm sure as hell not stopping on the side of the road. He's sitting in his car for a few minutes, doing cop things I assume. Meanwhile I've removed all my gear and am sitting politely on my bike with my hands visible. He strolls up, and lets me know my tail light is out. I tell him I know and that I was trying to keep my brake light active the entire time and that I was on my way back home. At this point I'm #$%*ting bricks because I left my bag at the house, and in there is all my paperwork. No regi, insurance, or safety inspection. That's not even counting the fact I don't have 5 reflectors, a safety inspection sticker, my turn signal doesn't work, it's too loud (especially at night), and it's spewing black smoke (oh I forgot to mention earlier that it's still too rich). At this point, he asks me to get off my bike. Uh oh. Seems he's not interested in me, but instead he's checking out my bike. For sure he's going to see I don't have a safety sticker, and my tire has hit my license plate at some point.
After a minute, he turns to me and asks, "what year is it?" "2012," I respond, thinking he's giving me a sobriety test. Spaghetti's leaking out of my pockets at this point, realizing he meant my bike. We chat for a good 10-15 minutes. He asks where I found it, how long I've had it, did I do the work myself, what have I done and plan to do, etc., the usual. He went on to say that his buddy in the force has a bike like this, a W650. "Anon?" I ask. Anon being the guy with the W650 that I rode with a few weeks ago. "Yeah, Anon. We used to ride then my wife made my sell my bike." We chatted for a few more minutes, then he reminded me to get my safety infractions sorted out or else he's going to have to cite me next time. He went on his merry way and I was there still #$%*ting my pants.
I rode off. About halfway home, I hear SCREEEEEEEEEEECH. Immediately I realized I hadn't been using my brake. I was so scared I burst into treats. I apologized profusely at the next light and explained that it's an old bike and some of the electrics are on their way out. He sympathized with me and volunteered to be my tail light to my neighborhood. I waved as I turned, and HOLY #$%* GRAVEL I FORGOT GOD DAMN I'M GOING TO DIE! I didn't die, but I sure as hell scared the last of the #$%* out of me. I shift up to 3rd gear going down my street as to not bother the neighbors. About 50 feet from my house, I pull the clutch and cut the power and shift down. I get into my driveway and SCHHRUOSFFEWFCHHHHHH my rear tire lucks up and it bucks me around real good because I was in 2nd, not neutral. I also managed to twist my right ankle because I put it down as a reflex. Now I'm putting the bike in the garage, and because I'm mostly on my left ankle, I managed to twist that one because I stepped on a screwdriver. :(
Moral of the story: always do a quick functions check before you leave the house.
« Last Edit: August 25, 2012, 04:01:13 AM by Dimitri13 »
« Reply #11716 on: August 25, 2012, 04:36:17 AM »
Well that was a good story mate, for sure! Hey if you're running pods/velocity stacks it should be running very lean, what size main jets are you running, and what's the needle position? Cheers, Terry. ;D
« Reply #11717 on: August 25, 2012, 04:36:31 AM »
Entertaining;)
Glad the cop was nice to you.
Offline Dimitri13
  • 1974 CB550K
« Reply #11718 on: August 25, 2012, 05:37:44 AM »
I was running 40 slows and 115 mains with the needle clip in the 4th (stock) position, with pitted points and it was very lean. I guess I overestimated the jetting. I replaced the points, went up to 42 slows and one notch richer, and it was extremely rich. Going to put the screens back on and go back down to 40 slows (and keep the needle position). That should put me a lot closer to where I need to be.
Offline scunny
  • don't call me expert
« Reply #11719 on: August 25, 2012, 05:49:47 AM »
spring has arrived. battery on the charger, checked the tyre pressures and oil.
see you in the "lets see your bike on the road thread" tomorrow  ;D
present-CB 650 retro
            VTR1000F3
           XL250S riverbed rocket
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
           pedal(pub bike) leaks oil
« Reply #11720 on: August 25, 2012, 06:06:29 AM »
Passed the test and got me M license!
Offline bjatwood
  • I never claimed to be an
  • 1973 CB750-K3
    • Minbikers Proboards
« Reply #11721 on: August 25, 2012, 07:00:33 AM »
Welcome to the club!
Brian
#24193
I believe that the Finest things are the most thoughtfully made, not the most expensive!
http://minibikers.proboards.com/
« Reply #11722 on: August 25, 2012, 07:19:22 AM »
Thank you. I had M overseas since 88, but it didnt transfer to US.  Got me a learner's permit year ago - and failed the cone wave in May :)
This was the last possible day I could try the test again, since the learners permit expires tomorrow.
Spent last week practising in parking lot and it paid off.
Offline Hasenkopf
  • Really, I'm not an
  • This space for hire.
« Reply #11723 on: August 25, 2012, 11:07:45 AM »
red-headed stepchild is now legal !
I like berries.
Offline Hasenkopf
« Reply #11724 on: August 25, 2012, 11:09:20 AM »
more....
I like berries.
