Author Topic: What did you do to your bike today ?  (Read 3315924 times)
« Reply #12500 on: November 04, 2012, 05:15:57 PM »
That is one sweet looking 550 Stev-o...
Thanks, it's getting there. Bought a frt fender in excellant cond, just need to fit it and do a couple other cosmetic fixes. Fun bike to ride and now dont have to worry about the battery dying...
« Reply #12501 on: November 04, 2012, 07:00:11 PM »
Well after all my drama's I've had with replacing the front Comstar wheel on my bike because it's got a dent in the rim, I found out today that I can get the dent rolled out locally for 60 bucks.
I wish I'd known that before I spent 150 bucks getting the wrong wheel sent out from the US, poop! Oh well, as long as it gets me back on the road, no biggie, I should have it back by Friday.
I also bought some fork seals and some carb cleaner, but even though it's quite warm, it's dribbling rain outside, and as there's not enough room in the Turdis to swing a small cat at the mo, I'll do it tomorrow. Cheers, Terry. ;D
Offline gnarlycharlie4u
  • Far from being an
« Reply #12502 on: November 04, 2012, 07:06:50 PM »
I finally got my #3 carb to stop barfing gas and hold a proper float level, about goddam time too...
I've had this same problem on my friend's bike.
I've even swapped the float, pin, and needle with no luck. The towers are fine and not rounded out at all.
I'm without a clue.
« Reply #12503 on: November 04, 2012, 07:11:14 PM »
I'm without a clue.
I had the same problem on a CB750 recently mate, it turns out one float arm was slightly bent, and the float was getting snagged on the inside of the float chamber, holding the float valve open, and flooding gas out of the airbox. It was an easy fix, once I realised what the problem was. Cheers, Terry. ;D
maduncle
« Reply #12504 on: November 04, 2012, 07:20:24 PM »
Despite the rain, it was warm enough to go for a ride and buy some new coloured wire from a vintage wiring loom maker out east.
Now I can build myself a new CB450 wiring harness.
This vintage wiring loom place had the coolest old machines - they 'knit' cloth covering over single wire or over looms, in all sorts of colours and patterns.
Excellent - now to find one of those machines...
« Last Edit: November 05, 2012, 02:49:53 AM by maduncle »
Offline 750K
« Reply #12505 on: November 04, 2012, 08:45:53 PM »
I'm without a clue.
My root problem was the dimple worn into tab of the float by the needle itself, I swapped needles and floats plus hinge pins from non leaking carbs. I tried bending floats out or in thinking it was catching on the bowl or towers, what finally solved the problem was filing the dimples on the tabs off. That allowed the the needle to properly seat and not leak anymore.
77 Cb750, 78 Kz1000
« Reply #12506 on: November 04, 2012, 10:41:16 PM »
Yeah mate, I had that problem around the same time you posted your carb findings, but I didn't have that problem, Ken's K1 had only done 5000 miles from new, and the contact tab on the float arms were unmarked. Cheers, Terry. ;D
oldbob
« Reply #12507 on: November 05, 2012, 10:24:49 AM »
I discovered that the main fuse had melted the fuse box. Obviously, I should have cleaned up the connections before putting the 400 back into service. Looks like I'll be buying one of HondaMan's fuse boxes.
Bob
Offline DJ_AX
« Reply #12508 on: November 05, 2012, 09:49:25 PM »
Wiped the frost off the seat for the 30F degrees ride home from work tonight... I was layered up right ... a nice warm ride home. :)
Juiced up the chain
Online Don R
« Reply #12509 on: November 05, 2012, 10:05:53 PM »
Rode it to breakfast, dang it was cold. Found an oil leak went to my local bike guru, he found me some oil line crush washers to fix it. woo hoo one more bug getting worked out.
« Reply #12510 on: November 05, 2012, 10:24:41 PM »
You rode your bike to breakfast Don? Wow, you must have a big house mate, or are you just really lazy? ;D
maduncle
« Reply #12511 on: November 05, 2012, 11:11:23 PM »
Could we have a 'facepalm' emoticon available just for moments like these?
« Reply #12512 on: November 06, 2012, 12:19:15 AM »
my marlon brando wild one accessory kit arrived today,,im not wearing the hat that came with it though!
« Reply #12513 on: November 06, 2012, 12:55:13 AM »
Hey that'd be a nice urn for your ashes if you karked it Dave, I might have to get one for when I leave my mortal coil! ;D
« Reply #12514 on: November 06, 2012, 12:59:30 AM »
i want my ashes sprinkled through carbs during a carb sync!
« Reply #12515 on: November 06, 2012, 01:17:50 AM »
I want mine dropped in the oil tank of a sandcast collector just before a long ride............ ;D
maduncle
« Reply #12516 on: November 06, 2012, 02:28:24 AM »
I was planning on half burying you face down and using the bit sticking out as a bike stand - so you be useful when I work on bikes even after you are gone.
« Last Edit: November 06, 2012, 02:30:25 AM by maduncle »
« Reply #12517 on: November 06, 2012, 05:52:52 PM »
Fit a new ebay front fender on the red 550 [worth the $100]
And rode the Hills on a beautiful Election Day...
Offline Spike
« Reply #12518 on: November 06, 2012, 06:22:18 PM »
Got the rear wheel cleaned up a little and put together.
I'm thinking about putting my second CB 500 (parts bike) on the market
to make room for another project...sheesh ::)
« Last Edit: November 06, 2012, 06:27:57 PM by Spike »
Any road...anytime
IBA# 6154
'73 CB 500
Concours C14
BMW R100/7
Offline Jerry E.
« Reply #12519 on: November 06, 2012, 06:43:58 PM »
Helped my welder friend make an aluminum mounting bracket for my oil cooler, which he welded up for me.
"Why jump from perfectly good airplanes? Because the door opens."
« Reply #12520 on: November 06, 2012, 07:14:53 PM »
Are you going to rubber mount it..?  Aluminum brackets are notorious for breaking when used as direct frame mounted bracket for the oil cooler, i always make them out of mild steel and rubber mount them...
Offline Jerry E.
« Reply #12521 on: November 06, 2012, 09:43:17 PM »
Well, the cooler is rubber mounted to the aluminum bracket, but I was going to bolt the bracket to the horn mount. Think I need to rubber mount the bracket, too? Or would it still be prone to breaking? I was going to tie down the oil lines to/from the cooler, to help keep vibration/ movement to a minimum.
« Reply #12522 on: November 06, 2012, 09:50:39 PM »
The vibrations eventually fatigue the aluminum causing it to crack, there have been a couple of failures of aluminum brackets on the forum, the one i read of recently was on a race bike..  If it were me, i would be rubber mounting the bracket as well, just to lower the pitch of the vibration, if that makes any sense... ;)
Offline Tintop
« Reply #12523 on: November 07, 2012, 06:45:17 AM »
RR it was bwaller's the cooler that failed, not his mount, both alloy.  I like the rubber bushings that have a bolt vulcanizied into each end.  I've also just zip tied the cooler into a mount with rubber / foam between, no issues.  Jerry E, not a problem tieing down the lines, but don't do it too close to the cooler so as the make the mounting ridged.
1980 CB750F (project)
77 CB550 Cafe build
550/750 Filter Thread
Sidecar Rebuild Thread
« Reply #12524 on: November 07, 2012, 01:18:07 PM »
Thats the one Brian, thanks. I think the cooler being "softer" went first, i think over time that the allow mount would go as well unless rubber mounted. I don't think one manufacturer that fits coolers stock use an alloy bracket, none were on any of the bikes i have owned. Its like my mates boat trailer, he had some really nice alloy mud guards made for it with all alloy mounts, they just kept breaking, he now has steel brackets bolted to the guards and so far so good....
