Author Topic: What did you do to your bike today ?  (Read 3726628 times)
0 Members and 11 Guests are viewing this topic.
« Reply #16050 on: December 03, 2013, 01:03:05 AM »
G'Day Steve, what a piece of shi, er, I mean, history! Ha ha, I can't see much in the way of real "Racer" parts on that bike, but who knows? The engine might be chock full of shiny Yoshimura parts?
The fairing does look reminiscent of an old Bevel Drive Ducati 900SS fairing, but many manufacturers made similar ones back in the day, I've got an Egli fairing in my garage that looks similar. Good luck with it mate, I hiope it goes better than it looks! ;D
« Reply #16051 on: December 03, 2013, 05:51:29 AM »
Ha....you don't have to sugarcoat it, Terry!  I doubt the race bike story myself, but I bought the bike, not the story.
It will be a challenge, no doubt, and a bike you don't see everyday.
Offline Jerilee
« Reply #16052 on: December 03, 2013, 12:21:47 PM »
I made an xmas list of bike parts  :D
I also popped on to Bikebandit last night to make use of the Cyber Monday deals, mostly because I noticed they had the turn signal buzzer in stock. (I know, I'm one of the weird ones who likes the thing!) Today they let me know it was forever out of stock. We'll see if they update the site too.
Ah well, I still got a set of tank mount rubbers out of the deal. Still bummed, I was super excited to have a buzzer that didn't sound like someone was trying to drown it.  :P
Jeri~
My F2 build http://forums.sohc4.net/index.php?topic=126314.0
77/78 cool 2 member
Offline edwardmorris
  • Youngish
« Reply #16053 on: December 03, 2013, 12:59:46 PM »
I hunted down the buzzer as well, you're not alone there....
Offline Jerilee
« Reply #16054 on: December 03, 2013, 03:21:17 PM »
Did you ever have any luck finding an acceptable new replacement or an NOS Honda part?
Jeri~
77/78 cool 2 member
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« Reply #16055 on: December 03, 2013, 05:35:43 PM »
Got my exhaust parts back from my dad/machinist. The 2.5" inlet on the Cone Engineering Quiet Core slips right over the mid-section that was cut from the old MAC canister slip-on. That mating will now provide the angle off the header's collector to get the reverse cone pointed straight back. Then a black paintjob for the midsection when I do the headers before spring. Test fitting and will fire her up this weekend!
« Last Edit: December 03, 2013, 05:41:15 PM by evanphi »
--Evan
1975 CB750K "Rhonda"
« Reply #16056 on: December 03, 2013, 07:16:24 PM »
That looks great
Offline Red Good
« Reply #16057 on: December 03, 2013, 08:08:56 PM »
Just rode it today, had to sort out a tach seal leak and test rode it for about 50 miles . Wow that big X pulls very hard . Red
« Reply #16058 on: December 04, 2013, 03:05:38 AM »
Rode to work, quite cold this morning; you can call me Chief Balls of Ice  ;D
Offline evanphi
  • Apparently I'm an
« Reply #16059 on: December 04, 2013, 04:51:05 AM »
That looks great
Thanks. I will be posting a video after this weekend.
--Evan
Offline Carver
« Reply #16060 on: December 04, 2013, 11:55:06 AM »
got the engine out of the 450, finally after a year of it being broken down.
Question, I need to pull the 750 engine as well, but i do not have a center stand for it, how much of a hindrance is that going to be?
Cb 750 k3
Cb 450 dohc k4
Offline Bankerdanny
  • Endeavor to persevere
« Reply #16061 on: December 04, 2013, 12:31:19 PM »
No center stand should be an issue since the easiest way to remove the 750 engine is to lay the bike on it's side and lift the frame off.
Offline Carver
« Reply #16062 on: December 04, 2013, 01:06:55 PM »
How much disassembly does that require? I'm trying to do as little as possible. Is it just all the bolts holding the engine in then place it down pop the last one out and lift it off? (obviously disconnect everything attached to the engine)
Cb 750 k3
Cb 450 dohc k4
« Reply #16063 on: December 04, 2013, 01:14:24 PM »
I just did this last weekend.   Most of the bike needs to be stripped.  Mine was just a roller.  I put down a few layers of heavy cardboard on the lawn, and rolled the bike onto its right side.  (I put on an old dented points cover so as to not bend the advancer shaft.)
I loosened most fasteners beforehand.
Once over, i removed the front forks and wheel, and then the rear wheel w the shocks and swingarm still attached.  I was able to rock the motor back and forth, and prop it as needed to shimmy the frame off.  would have been much easier with a neighbor, but they all ran inside when the saw what i was about to do  ::)
Offline 750K
« Reply #16064 on: December 04, 2013, 02:07:33 PM »
True test of how good of a neighbor you really have, lol
77 Cb750, 78 Kz1000
Offline Carver
« Reply #16065 on: December 04, 2013, 02:33:04 PM »
damn man I only need to do head work so I really wanted to avoid stripping down the whole bike. Gunna get my frame cut while the engine is out as well to avoid this in the future.
Cb 750 k3
Cb 450 dohc k4
« Reply #16066 on: December 04, 2013, 02:44:39 PM »
well, after the tank and seat, for convenience, you should remove the forks and rear wheel so its easier to maneuver the frame off, and with all that stuff still on it, you better have 2-3 buddies willing to hold it while you shift the engine...lighter is easier.
  • Youngish
« Reply #16067 on: December 04, 2013, 03:12:20 PM »
After several blockers, finally made time to work on the bike today. Mostly tore down stuff off the frame, steering, swingarm etc. so I can take the frame to a welder. Stuck on disassembling the swingarm as those pesky bushings refuse to move. The factory manual only says to inspect them while still in the swingarm. I know Hondaman's book talks about possible improvements here and I might have to sit down and read through that again.
Offline Carver
« Reply #16068 on: December 04, 2013, 04:21:34 PM »
The honda cb 450 everyone! Time to bust in to an engine for the first time ever. The second time will be a sohc 4 750
Cb 750 k3
Cb 450 dohc k4
« Reply #16069 on: December 04, 2013, 05:45:26 PM »
Very impressive!  Slap a 500 big bore kit in it!!
http://www.ebay.com/itm/GENUINE-HONDA-CB500K-PISTON-RING-KIT-1-00mm-O-SIZE-13105-323-000-13051-323-000-/261346557232?pt=UK_Motorcycle_Parts_13&hash=item3cd977fd30
Offline Carver
« Reply #16070 on: December 04, 2013, 05:53:57 PM »
The big bore is going in to the 750  ;D gunna get one of those 836 kits while they're cheap. I feel like the 750 lends itself to power modifications more so than the 450.
Cb 750 k3
Cb 450 dohc k4
« Reply #16071 on: December 04, 2013, 06:51:11 PM »
When I built the "592" I used a copper head gasket. On the street I don't think this is a good choice as they always weep a tad. Used a surface plate to clean up the head/cylinder and installed an MLS gasket. I had Swaintech coat the HA piston skirts originally and they still look great, good product.
Offline bjbuchanan
« Reply #16072 on: December 05, 2013, 01:48:17 PM »
I have been breaking in my recently built 836, I made a bunch of changes along the way. Major change is that I am running a tracy body kit on there which took some tweaking
I learned today it is just a bit over 3.5 gal capacity after I had to push the thing about 2 miles, partly uphill. No sidewalks either because I was right near a parkway. At the top of the big hill I was really wishing I had bought a 200twin or something instead of a 750
I will get pics up of the bike with the body kit. It isn't the groovy, swoopy one, sorta F model looking one.
Offline goldarrow
  • one day, i'll be an
« Reply #16073 on: December 05, 2013, 02:15:30 PM »
BJ, did you coat the tank of your Tracy body? Curious to see the picture
CB550 K0
Offline bjbuchanan
« Reply #16074 on: December 05, 2013, 02:31:58 PM »
Yeah, they guy I bought the body off had a Caswell kit for it he didn't get around to putting in. I wouldn't have taken the chance with ethanol in gas today, it will turn it to a gummy mess
That is an old mockup pic but it is more or less what it looks like mounted on there. Lucas tail light, mini round blinkers and did away with the side mount plate. I will get a good "today" pic up tomorrow in the daylight
