Author Topic: What did you do to your bike today ?  (Read 3158369 times)
« Reply #16675 on: February 09, 2014, 11:33:15 am »
thanks bjbuchanan,i couldnt find any stainless wool but ill pick some up ready for next time if this burns out quickly.
Offline bjbuchanan
« Reply #16676 on: February 09, 2014, 11:36:01 am »
No problem, bike sounds good
Offline fire113
« Reply #16677 on: February 09, 2014, 01:14:46 pm »
...put a fork and a wheel on that K0 frame to check the main center stand.
Offline nccb
  • 1974 CB750 Four
« Reply #16678 on: February 09, 2014, 02:26:17 pm »
took her for about 50 miles and then changed the oil.  I always end up making the biggest mess when draining the reservoir. . .
Offline fire113
« Reply #16679 on: February 09, 2014, 03:35:11 pm »
...drilled the holes for the emblems
Offline Dimitri13
  • 1974 CB550K
« Reply #16680 on: February 09, 2014, 03:39:57 pm »
Online Stev-o
Offline 750K
« Reply #16682 on: February 09, 2014, 04:10:06 pm »
Ordered a caswell tank sealer for my pin holed spare tank, hope it lives up to the reviews. I hate lining a tank but can't avoid it with this one...
77 Cb750, 78 Kz1000
Offline skidooextreme
« Reply #16683 on: February 09, 2014, 04:41:27 pm »
Continued working hard on the 350f project. Should have posted many times until now but this is where i am at today. Finished the cylinder head cover and installed it with the newly polished valve cover.  Bike was in a outdoor shed for 35 years before i got her 2.5 years ago.. Every nut and bolt has been cleaned or replaced.  8k on the meter!
Online Stev-o
« Reply #16684 on: February 09, 2014, 05:00:17 pm »
^^^   Looks great, Skidoo ^^^
Mounted this hoist on my garage ceiling.
Then proceeded to rip the K4 apart!
Ropes hold the bars/controls in place when the front end came out.
Offline MoMo
  • Ride like you're invisible
« Reply #16685 on: February 09, 2014, 06:26:16 pm »
Offline kippstakes
« Reply #16686 on: February 09, 2014, 07:57:28 pm »
finished up head gasket removal. lapped valves. painted pipes, dist. cover, frame, head, jugs. purchased honer. flushed case and crank shaft. cleaned out oil pan funk. hmm, there's more but it's making me tired typing about it.
hope you were all equally industrious!
D
Strength is just an accident arising from the weakness of others.
-J. Conrad
Offline bjbuchanan
« Reply #16687 on: February 09, 2014, 08:07:58 pm »
Caswell is good stuff. I lined my tracy body kit with it. It lays out thick which is great for pinholes
My recommendation is to put more in the tank than you are "supposed" to use according to measurements. My long, but only 3.5L tank took the majority of the kit for coverage. It moves slow so get good coverage
Offline 750K
« Reply #16688 on: February 09, 2014, 08:35:44 pm »
^^^Good to hear and I plan on dumping the whole kit in, between the pinholes and the 77-78k extra volume I figured it would need the whole kit.
77 Cb750, 78 Kz1000
Offline bjbuchanan
« Reply #16689 on: February 09, 2014, 08:36:45 pm »
Yeah you are thinking correctly. The kit specifically says that the volume to surface area coverage is not easy so put extra in
« Reply #16690 on: February 10, 2014, 12:36:28 am »
is that rocker cover powder coated dimitri?nice finish.
Offline Dimitri13
  • 1974 CB550K
« Reply #16691 on: February 10, 2014, 01:47:13 am »
Yep, powdercoated. Unfortunately I was playing with the colors in Lightroom and completely messed it up. It's not gold, it's supposed to be bronze. http://www.prismaticpowders.com/colors/UMB-493/
I'll try playing with it some more and get it accurate.
« Reply #16692 on: February 10, 2014, 02:16:20 am »
those cap screws along the front will foul on the tappet covers,youll have to use little button headed ones.
Offline jonda500
« Reply #16693 on: February 11, 2014, 12:09:17 am »
Cut off my muffler to replace the join pipe with a longer one. Is this (bottom pic) too long do you think??
A starter clutch thread:
Offline MoMo
« Reply #16694 on: February 11, 2014, 01:02:30 am »
It does make the bike appear longer but my aesthetic preference would be the shorter version. Nice bike! ...Larry
« Reply #16695 on: February 11, 2014, 01:36:44 am »
Yep, shorter one looks better and more balanced.... ;)
Offline jonda500
« Reply #16696 on: February 11, 2014, 05:19:18 am »
Thanks guys :)  I didn't want to go ahead and weld it on as I also had a feeling it wasn't gonna look right. I was trying to emulate the original supersport muffler and also delete the muffler clamp (by welding the new pipe section to my centre stand bumber instead), but you are right- this aftermarket muffler just doesn't look right that far back on the bike. Looks like I'll have to use the clamp as I cant weld a bracket to the aluminium muffler :(
« Reply #16697 on: February 11, 2014, 05:43:19 am »
Yesterday I put my F head together.  The black paint suffered a bit I will have to touch it up when it's warmer.
Time to make a timing wheel.
Offline edwardmorris
  • Youngish
« Reply #16698 on: February 11, 2014, 08:25:46 am »
Still cleaning up a lot of small hardware. Totally stuck on removing the bearings on the main shaft because I can't figure out how to get the clutch basket off it. Please advise in my build thread :)
    • http://forums.sohc4.net/index.php?PHPSESSID=fpbefspb82pir37inn26ht5gu2&/topic,60973.0.html
« Reply #16699 on: February 11, 2014, 08:41:49 am »
smash my yamaha dt 125 engine...now rebuilding :-\
