Author Topic: What did you do to your bike today ?  (Read 3389757 times)
Offline Dimitri13
  • 1974 CB550K
« Reply #16700 on: February 11, 2014, 10:31:06 AM »
So much black.
With the base and clear, how thick is the powder? Is it noticeable thicker?
Offline dlhoulton
« Reply #16701 on: February 11, 2014, 12:37:11 PM »
Yea, it's a lot of black but this is a 1977 CB750F. It had lots of black on it.
As for thickness, it all depends on how much powder you apply. You can just lightly dust them, then bake or keep applying the powder for a thick coating then bake. The black is a high gloss and does not need clear. It comes in many finishes, from high gloss all the way to flat to wrinkle. The "Reflective Chrome" requires the clear coat. Eastwood states that it is a two stage coating and is required. I wasn't very happy with the way it turned out. It was very "reflective" when applied and baked but when the clear was applied it "dulled" it down. Probably my fault. But reviews on there forum state that many have had the same problem.
« Last Edit: February 11, 2014, 12:41:45 PM by dlhoulton »
Offline Jerilee
« Reply #16702 on: February 11, 2014, 04:42:17 PM »
I was curious about pcing my parts myself too, a 77F as well  ;D What did you bake them all in?
Jeri~
My F2 build http://forums.sohc4.net/index.php?topic=126314.0
77/78 cool 2 member
Offline krusty
« Reply #16703 on: February 11, 2014, 04:49:18 PM »
Applied decals to tank. Give it a day or two to set then the clear goes on.
Honda
1976 CB750F1
1978 CB750F2
1972 CB350F
1961 C100 Cub
1962 C100 Cub
1959 C76
1963 C92
1964 C95
Suzuki
1963 M15D 50cc
1961 250TA Colleda
Yamaha
1977 DT175E x 2
1978 DT125E
1979 DT125F
1976 DT250E
1978 DT250G
1984 FJ1100
1990 FJ1200
Offline dlhoulton
« Reply #16704 on: February 11, 2014, 05:00:55 PM »
Jerilee, went to Walmart and got a $65 oven. Looked for largest counter top I could find. This one is a "West Bend". Here is a couple pic's of it.
    • http://forums.sohc4.net/index.php?PHPSESSID=chm01ap7bmb9r6amuj32sng5i0&/topic,60973.0.html
« Reply #16705 on: February 12, 2014, 04:27:43 AM »
splitting my yamaha total....now vating for parts from england...
« Reply #16706 on: February 12, 2014, 04:29:49 AM »
Nice winter project  :)
« Reply #16707 on: February 12, 2014, 08:25:39 AM »
no it are not nice ;D..it sekund time i do the job...so have not done it perfekt..first time....hate to pull a engine after 2 auers... :P
Offline fire113
« Reply #16708 on: February 12, 2014, 02:04:42 PM »
...did the fork ears and the fork rubber stuff, put a inner and outer rear fender and a head light.
Took K2 Fork ears because the K1 set ins't painted right now.
Offline Jerilee
« Reply #16709 on: February 12, 2014, 02:58:49 PM »
That's not bad at all. Clearly it can fit the fork lowers. :)
How did you suspend the parts inside, coat hanger?
Jeri~
77/78 cool 2 member
« Reply #16710 on: February 12, 2014, 03:27:29 PM »
Pulled the fork apart on the K4 and ordered Progressive springs...
Offline dlhoulton
« Reply #16711 on: February 12, 2014, 04:23:00 PM »
Jerilee, yes it just fits the fork lowers one at a time at an angle with about an inch to spare. To suspend parts I got a roll of wire and made assorted hooks. The oven came with two wire racks. I use one at the very top to hang stuff, the other was used on stuff that could just rest on a rack. Look at second picture of oven in previous post and you can see resting on top the wire coil, PC tape and the box that contain plugs. Got the assorted plugs from Caswell plating. They save a lot of time buy just putting a plug into a screw hole so the powder won't get in. They just pull out when done and are reusable. Here's a pic of lower in oven. I remounted it to show that it does fit.
Also for anyone who gets the HF powder coating gun. It only comes with two cups. HF does not sell the cups. I found that Caswell Plating sells a gun like the HF and the cups are just like the HF. I got three from them so I wouldn't have to keep pouring powder back into bulk container and cleaning the cup for the next color. The cups are only $2.99 each. Here's a link: http://www.caswellplating.com/powder-coating/powder-coating-systems/powder-coating-gun-cup.html
« Last Edit: February 12, 2014, 04:55:45 PM by dlhoulton »
Offline goldarrow
  • one day, i'll be an
« Reply #16712 on: February 12, 2014, 07:08:55 PM »
What are you gonna do with those pitted chrome plating stevo?
CB550 K0
« Reply #16713 on: February 13, 2014, 06:36:26 AM »
Send em to you?  I have polished lowers on the shelf...
Offline goldarrow
« Reply #16714 on: February 13, 2014, 08:00:25 AM »
send them to me and i'll do some experiments for you.  i know you don't like to polish, me neither, but read that you can let them sit in Cola and chrome should clean off.  worth a try.
CB550 K0
Offline krusty
« Reply #16715 on: February 13, 2014, 01:29:52 PM »
Applied decals 2 days ago then today did the clear coat.
Honda
1976 CB750F1
1978 CB750F2
1972 CB350F
1961 C100 Cub
1962 C100 Cub
1959 C76
1963 C92
1964 C95
Suzuki
1963 M15D 50cc
1961 250TA Colleda
Yamaha
1977 DT175E x 2
1978 DT125E
1979 DT125F
1976 DT250E
1978 DT250G
1984 FJ1100
1990 FJ1200
Offline FrankenFrankenstuff
    • FrankenBike Stuff Store
« Reply #16716 on: February 13, 2014, 01:47:39 PM »
Looks flawless. What is it with all of the Australians doing such frigging great painting? You and  forum member "cakey" should get together for a few frosty brews. Great job Krustyman.
Offline krusty
« Reply #16717 on: February 13, 2014, 02:29:00 PM »
Thanks FF. That paint job was straight out of rattle cans, anti rust epoxy enamels usually made for painting ironwork. It's not perfect by any means but it's good enough for me, not looking for concours. Just need to buff it when its cured fully then fit the emblems.
Not sure if I've already posted this but this is how it looked when I got it.
Honda
1976 CB750F1
1978 CB750F2
1972 CB350F
1961 C100 Cub
1962 C100 Cub
1959 C76
1963 C92
1964 C95
Suzuki
1963 M15D 50cc
1961 250TA Colleda
Yamaha
1977 DT175E x 2
1978 DT125E
1979 DT125F
1976 DT250E
1978 DT250G
1984 FJ1100
1990 FJ1200
« Reply #16718 on: February 13, 2014, 02:45:03 PM »
Yikes. Good on you for saving it.
Offline Jerilee
« Reply #16719 on: February 13, 2014, 05:43:56 PM »
Great info! and thank you for going back to take the photo! I've sprayed paint a few times but PC is still a whole new world for me, for now. it sounds pretty do-able. :)
Jeri~
77/78 cool 2 member
« Reply #16720 on: February 13, 2014, 05:59:40 PM »
Another box of goodies turned up and another on the way.... 8)
« Reply #16721 on: February 13, 2014, 06:06:00 PM »
C'mon Mick, we need more info.  Pics or it's just BS!
Offline jonda500
« Reply #16722 on: February 13, 2014, 06:14:22 PM »
Finally made up my mind how long I wanted the exhaust and welded on the extension pipe and the muffler :)
A starter clutch thread:
« Reply #16723 on: February 13, 2014, 06:27:12 PM »
No pics yet Steve , Yoshimura rearsets, a really nice oil cooler {these first 2 go away for the 3rd bike, the 1000cc injected one}, foot pegs and mounts, a very clean early airbox, rear wheel spacers, a nice clean hand control, dash and wiring, coil mounts, inner guard, long oil filter bolt for oil cooler conversion and some more wiring bits.... All these parts are for the 900cc K2, which isn't far off being built, just a few more little things to get sorted and its full steam ahead......slowly.... ;D ;)
Offline 750K
« Reply #16724 on: February 13, 2014, 09:51:27 PM »
Nothing in regards to my cb, I did talk to the bank about a line of credit. Got my eye on a gently used cbr600rr locally though. Once I sit down with my financial advisor I'm going sport bike shopping!
77 Cb750, 78 Kz1000
