Author Topic: What did you do to your bike today ?  (Read 3205881 times)
« Reply #17050 on: April 02, 2014, 09:18:28 PM »
I have front blinkers if you need
I do.  Don't you owe me?! Ha!
You need them? Really? That's new! Have seen your bikes blinkers less. Ha!
They're yours.  I just have to find the time to dig them out
I'm turning over a new leaf! The back ones are good and work, and what's left of the fronts are damaged, so have to do something.
Need a L fork ear while you are digging.   Thanks Gold Dude.
PS. Where's your Relay ride report??
Offline FillionJ
« Reply #17051 on: April 03, 2014, 01:31:02 AM »
I woke up early n went and looked at a 77 cb125s. Ended up buying it for 300 after I took it for a spin down the back lane in -15..   Great day
Offline wardenerd
  • '77 550F '81 650C
« Reply #17052 on: April 03, 2014, 04:41:13 AM »
Rode my 1977 550F to work on this lovely 50 degree day.  It is amazing after 37 years that it runs like a top.  Original silencer at Brown's getting new chrome.
Offline WhyNot2
  • I'm finally an
« Reply #17053 on: April 03, 2014, 05:37:33 AM »
Rode to work on this lovely 63 degree morning.
Rode my 1975 CB750 to work this am too. Was a great ride. Kinda took my time, and enjoyed the cool wind in me face. Must have bumped something in the electrics....cause rear LED tail light stayed bright at idle. Normally it goes dim when idling.
Life is good today..........
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« Reply #17054 on: April 03, 2014, 05:53:44 AM »
Got some washers and M8 35mm socket heads in stainless. Need them for my MAC header, and going to grind some of the washers down for the top triple spacers. Lots of leftovers, might be giving them away once bike is back on the road.
--Evan
1975 CB750K "Rhonda"
« Reply #17055 on: April 03, 2014, 06:11:10 AM »
A word of caution: if your washers are even slightly thinner than the original spacer (most standard hardware is) the clamp will still break.
Search for my thread in Tips and Tricks for the proper thickness.
Offline wardenerd
  • '77 550F '81 650C
« Reply #17056 on: April 03, 2014, 08:25:45 AM »
budlite 282 where in Georgia?
Offline fire113
« Reply #17057 on: April 03, 2014, 08:26:36 AM »
...think it was 2mm
    • http://forums.sohc4.net/index.php?PHPSESSID=isnh7od399l35tasa6nadvpto3&/topic,60973.0.html
« Reply #17058 on: April 03, 2014, 10:38:14 AM »
made a rep of my gear shift splines end. on the cb 500 t   .po have veldet the pedal on...
took a china honda engine..and cut the parts i needed..took it in the latne??to make it perfekt senter up..cut the veld on shift arm..to get it in the machine..veld the arm on at last
« Reply #17059 on: April 03, 2014, 11:12:18 AM »
...think it was 2mm
It was .09", which is 2.286mm.
http://forums.sohc4.net/index.php?topic=72765.0;nowap
If you need some cyl head washers let me know.
Offline WhyNot2
  • I'm finally an
« Reply #17060 on: April 03, 2014, 04:49:44 PM »
Augusta
Offline evanphi
  • Apparently I'm an
« Reply #17061 on: April 04, 2014, 08:42:24 AM »
...think it was 2mm
Cool thanks for the tip. I will measure these ones this weekend.
--Evan
Offline dlhoulton
« Reply #17062 on: April 04, 2014, 12:01:57 PM »
Polished some carb parts. Love the smell of fresh polished parts.
« Reply #17063 on: April 04, 2014, 12:04:10 PM »
sunglasses needed 8)
nice work!
Offline Dimitri13
  • 1974 CB550K
« Reply #17064 on: April 04, 2014, 12:16:45 PM »
Started to assemble my forks. Hit this snag. Got no feedback in my thread about it :(
« Reply #17065 on: April 04, 2014, 01:04:01 PM »
Hi Dimitri13,
What was the snag you had,a circlip problem ?
Offline Dimitri13
  • 1974 CB550K
« Reply #17066 on: April 04, 2014, 01:40:40 PM »
Hi Dimitri13,
The fork spring sticks out over an inch. Not sure that's supposed to be like that.
« Reply #17067 on: April 04, 2014, 01:43:46 PM »
Dimitri13....compress the springs with the caps and screw them on.
You're good  ;)  It's just a small amount of pre-load.
There might be a washer between the spring and fork cap.
Offline Dimitri13
  • 1974 CB550K
« Reply #17068 on: April 04, 2014, 01:46:20 PM »
Dang, that's gonna be a bit tough. Don't want to put them in the triple tree, and I can't lay em down.
« Reply #17069 on: April 04, 2014, 02:12:13 PM »
yep, takes a bit of leverage.  hunk of wood on the floor might work.
Offline goldarrow
  • one day, i'll be an
« Reply #17070 on: April 04, 2014, 02:18:03 PM »
I use tall/deep socket on the cap so I can hold better when trying to screw the cap on, also position the cap thread to where it's about to go on the thread in fork, push and turn, shouldn't take too much
CB550 K0
Offline mcswny
« Reply #17071 on: April 04, 2014, 02:28:12 PM »
Going to my garage tonight to prep my bike for a small camping trip upstate ny this weekend.
Also, bought myself some new, stock length fork tubes. I was sick of my 4" extended tubes and crappy handling. That combined with my tapered race bearings, my handling is going to be spot on (swing arm bushings next)!
1972 CB750 K2
1997 XR600r (street legal)
1975 XL250
198 XR80
« Reply #17072 on: April 04, 2014, 02:33:17 PM »
I use tall/deep socket on the cap so I can hold better when trying to screw the cap on...
+1........23mm.
« Reply #17073 on: April 04, 2014, 02:36:09 PM »
+1........23mm.
hey Dimitri...since its out of the trees, grab a buddy or your signif other, and while you press the cap down onto the tube, have them grab the tube and turn it until its in all the way.  then torque it.
boom.
done.
« Last Edit: April 04, 2014, 02:48:39 PM by flybox1 »
Offline Dimitri13
  • 1974 CB550K
« Reply #17074 on: April 04, 2014, 02:40:23 PM »
Dang. Now I just need to figure out what fork oil I was t.
