Author Topic: What did you do to your bike today ?  (Read 3674762 times)
0 Members and 11 Guests are viewing this topic.
« Reply #17200 on: April 11, 2014, 10:31:51 PM »
Looks like Serious 'Eye Candy' to me Dimitri !  ;D
Offline MoMo
  • Ride like you're invisible
« Reply #17201 on: April 12, 2014, 04:49:35 AM »
Yup, same here.   I forget, what color will the tank be?...Larry
« Reply #17202 on: April 12, 2014, 07:09:59 AM »
Replaced the old leaking brake master cylinder with a new aftermarket from David Silver Plus the additional OEM looking cap. Everything on handle bar is new.
    • http://forums.sohc4.net/index.php?PHPSESSID=lclssd3buq5mn71qho9bjaahq1&/topic,60973.0.html
« Reply #17203 on: April 12, 2014, 12:54:42 PM »
got the rpm gear monteret...and test run...work like new...took the viring aut of main light..to route viring korerekt..had it to the vrong side of stering head..so never get it to vork right..
now oil thange and polish..and vait for dry veather
thanks to FUzzIE for the parts,and a fair preis..
first time in 4 years i see the rpm....
« Last Edit: April 12, 2014, 01:36:30 PM by strynboen »
Offline fire113
« Reply #17204 on: April 12, 2014, 03:50:10 PM »
...blasted the engine holders
« Reply #17205 on: April 12, 2014, 04:03:01 PM »
A little darker than powder blue, Gulf racing colors.... ;)
Offline 72 yellow
« Reply #17206 on: April 12, 2014, 07:35:55 PM »
Took advantage of a beautiful day and no one bothering me for anything to ride until my butt was numb.  :o  When I got back I changed the oil and filter.  ;D
Offline Nick0
« Reply #17207 on: April 12, 2014, 07:37:23 PM »
I started it up and it spat oil on me http://forums.sohc4.net/index.php?topic=136280
Offline KRONUS0100
  • MAD MATT THE MANIAC
« Reply #17208 on: April 13, 2014, 01:53:41 PM »
today i rode.  put 65 non stop miles on her around the block via the scenic route.  came home and changed oil, found small leak at oil cooler. removed oil cooler, think about fixing it later date.  tommorrow rear sprocket supposed to arrive.
MATT
Offline Schnell
« Reply #17209 on: April 13, 2014, 02:49:32 PM »
New swing arm bushings. Friday evening the back wheel and swing arm came off. Saturday the swing arm was cleaned, old bushings removed, new ones installed, and swing arm re-installed. Sunday afternoon, the back wheel was cleaned, re-installed,  and everything buttoned back up. Then a first seasonal and new bushing inaugural ride. Great weekend.
primary: 1974 Honda CB750
project: 1971 Honda CL350
project: 1974 Honda CB450
previous:
1975 Honda CB750
1973 BMW R90/6
1981 Suzuki GS650
1973 Honda CD175
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #17210 on: April 13, 2014, 02:51:33 PM »
Flogged the new rings for another 250 miles today to get home...
after flogging them for 250 miles to get to Valdosta on Friday.
Break-in complete!
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
« Reply #17211 on: April 13, 2014, 06:17:13 PM »
Break-in complete!
How were the races, Wilbur? Is there a write up??
Offline Tews19
  • I am no
« Reply #17212 on: April 13, 2014, 06:27:42 PM »
I'm looking to replace my bushings on my 750. Link to where you got yours Schnell?
« Last Edit: April 13, 2014, 06:38:07 PM by Tews19 »
1970 Honda CB750 survivor.
Offline Schnell
« Reply #17213 on: April 13, 2014, 06:36:29 PM »
I'm looking to replace my gushing on my 750. Link to where you got yours Schnell?
Here it is: http://www.ebay.ca/itm/Honda-CB500-CB550-CB550F-CB550K-CB750-4-cyl-Bronze-Swingarm-Swing-Arm-Bushings-/161245167478?
« Last Edit: April 13, 2014, 06:52:41 PM by Schnell »
previous:
1975 Honda CB750
1973 BMW R90/6
1981 Suzuki GS650
1973 Honda CD175
« Reply #17214 on: April 13, 2014, 07:50:47 PM »
Break-in complete!
What a blast! Picts and videos to come, some info has been posted:
http://forums.sohc4.net/index.php?topic=61876.msg1534496#msg1534496
TAMTF...
Wilbur
Projects:
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« Reply #17215 on: April 14, 2014, 04:41:09 AM »
Wired up my bucket and rear blinkers. Waiting on some reinforced rubber washers this afternoon as per Dream750's suggestion here... so I can adjust my headlight if I need to once it is all closed up.
Also found out that my battery might need replacing... Even after being on the tender for a day, it wiped the battery down just after testing the blinkers and headlight. I stuck the tender back on tonight and I think i'm going to leave it on until bike is ready to be ridden.
--Evan
1975 CB750K "Rhonda"
Offline Nick0
« Reply #17216 on: April 14, 2014, 07:25:54 AM »
maybe you've already thought of this but this could also be the symptoms of a short in your electrical system
Offline evanphi
  • Apparently I'm an
« Reply #17217 on: April 14, 2014, 10:29:32 AM »
Certainly crossed my mind. I will be doing full electrical tests before closing up that headlight.
--Evan
« Reply #17218 on: April 14, 2014, 12:56:42 PM »
Got the top end installed and dialed in.  Ready to button up.
Offline evanphi
  • Apparently I'm an
« Reply #17219 on: April 14, 2014, 05:50:57 PM »
Pulled the side cover off and I had popped the main fuse. I think I had a wire crossed somewhere, and I think it is the Brown/White connection that would normally also power the speedo/tach lights when the headlight is on. I have two female Brown/White connections in my bucket, and only one male, coming from the Throttle side switches. I had switched it last night hoping to remedy my issue, but I had already blown the fuse, and guess what... no spares. Will get tomorrow.
Anything else that can blow the main fuse?
--Evan
Offline edwardmorris
  • Youngish
« Reply #17220 on: April 14, 2014, 06:30:37 PM »
Tracked down and bought a set of NOS 750 oil hoses, can't decide if I should sell for project funding or use them on my bike  :-\ Also acquired two extra oil pump filters, if anyone needs them PM me. Pix on page 19 of my build thread below.
Offline brooze72
« Reply #17221 on: April 14, 2014, 06:47:55 PM »
Finally got the "fleet"out of storage on Sat, now time to get them ready for the road.
1972 CB500K1 - restored rider
1981 CB650C - new project
Offline OldSchool_IsCool
  • Really feeling like an
« Reply #17222 on: April 14, 2014, 07:47:41 PM »
evanphi,
Unless you are made of fuses, get/make urself a 12 volt light bulb with gater clip leads. Clip the bulb across the empty fuse holder.  The light will shine brightly when the short is active.  Now unplug connectors and wiggle wires until the light goes dim.  Once it does, you found your short.
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
Offline evanphi
  • Apparently I'm an
« Reply #17223 on: April 15, 2014, 02:19:51 AM »
evanphi,
Thanks for the tip. I was going to also use my multimeter.
--Evan
Offline fire113
« Reply #17224 on: April 15, 2014, 01:32:31 PM »
...put the K0 gas tank on and removed the last ugly chrome parts at the K0.
Did the electric @ the K2 and put a hand full of new screws at the K1.
