Author Topic: What did you do to your bike today ?  (Read 3157230 times)
0 Members and 10 Guests are viewing this topic.
« Reply #17250 on: April 17, 2014, 02:10:49 pm »
OK OT7  :),
I've been looking at this other brand Motobatt and they have a 2 year warranty but the price is $81 shipped and that's a few more tanks of gas for me. You're happy w/ that Scorpion ? When you say "third season", is that with this particular YB12A-A? What's the Scorpion model# for it ? I want to do some more research. That YB12A-A size is one of the most common size batteries for Vintage cycles for many years now.
        Thanks, Bill
I just got this one for $66 total.  Came fully charged and ready to go.
http://www.batterystuff.com/powersports-batteries/sYTX14AHL-BS.html
« Reply #17251 on: April 17, 2014, 02:37:28 pm »
OK OT7  :),
        Thanks, Bill
+1 For Battery Stuff. I've bought two from them
« Reply #17252 on: April 17, 2014, 02:55:46 pm »
It sounds good.
Offline fire113
« Reply #17253 on: April 17, 2014, 03:07:00 pm »
fire,
That exhaust reminds me a little of the BMW stlye., is it Stainless Steel ?
...yes, stainless steel  :)
« Reply #17254 on: April 17, 2014, 05:32:49 pm »
...mounted the pipe, did some electric, put a ignition cover and rode it.
Looking good Georg, that tank is huge, I reckon you could fill it up and ride it to my place on one tank-full! Cheers, Terry. ;D
Offline nccb
  • 1974 CB750 Four
« Reply #17255 on: April 17, 2014, 06:46:48 pm »
The tank is to the bike as Pherrell's hat is to his head 8)
Offline edwardmorris
  • Youngish
« Reply #17256 on: April 17, 2014, 06:59:14 pm »
Picked up Blanchard Ground rotor, and oil pump body with the shaft seal removed, cleaned and derusted all pieces that attach to the frame. Now just waiting for spring weather to start painting.
« Reply #17257 on: April 17, 2014, 07:07:41 pm »
Ha ha, it sure is mate! ;D
Offline Cvillechopper
  • Is just pretending to be an
  • If not for my failures I'd never know my limits
« Reply #17258 on: April 18, 2014, 03:57:18 am »
I went out to the shed, gazed longingly at my bike, then wiped a tear off my cheek and came back inside.
Were you sad because it was too cold to ride ?   ???
If only.  It was because I haven't been able to ride in months and don't see it happening any time soon.  Wife and I commute most of the time to make dropping the kids off at daycare easier (3 1/2 boy, 19 mth twin girls).  That and any time I'm not working I am campaigning.  Showing up at an event disheveled doesn't work...
It is the mark of an educated mind to be able to entertain a thought without accepting it.  Aristotle
« Reply #17259 on: April 18, 2014, 04:18:44 am »
Here's hoping that all of this comes together for you soon...you know it's worth the wait  :)
« Reply #17260 on: April 18, 2014, 08:49:28 am »
The start of a good day in the garage....
Offline Sgt.Pinback
« Reply #17261 on: April 18, 2014, 10:04:29 am »
Took Z1-A carbs out and fitted correct 73'  Z1 carbs.
Doc, I love a motorcycle!
« Reply #17262 on: April 18, 2014, 10:56:20 am »
Show us some pics of that Z1 !
Offline fire113
« Reply #17263 on: April 18, 2014, 01:24:43 pm »
...put the pipes on for a test run, kicked 3 times but ...NOTHING  :-X
Took off the carb bowl an found old fuel and clogged slow jets, cleaned em and kicked it again and it starts right up as it should  ;)
    • http://forums.sohc4.net/index.php?PHPSESSID=du8qh2o8psbrek1usvtts63ae2&/topic,60973.0.html
« Reply #17264 on: April 18, 2014, 02:36:54 pm »
set the ign timing on my 500 twin
Offline Sdsbassist
  • Gus, Austin, MN.
« Reply #17265 on: April 18, 2014, 03:20:48 pm »
Started buttoning things up.
Put on front fender (always loved the look of these)
And a side mount plate I picked up. Im going to weld on a light holder sunday at dad's house.
Insurance next week then hopeful ride moat days. Finally nice enough up here!
Sent from my PC36100 using Tapatalk 2
Gus, Austin, MN.
Current Bike:  75 750F
Past bikes: 76 750K - "Iowa Blue",78 750K Craigslist find - "Black Beth;" 77 CB750K Basketcase, with a 75K engine; 1970 Cb750 K1, "Rosa Luxembourg"
74 cb750, 75 cb550, 77 kawa 650, 81 virago 750, 83 virago 920, 80 Honda Twinstar 200, 71 Honda CT70, 1971 Honda CB750 Rat Project "Black Dahlia Bitsa"
Offline MoMo
  • Ride like you're invisible
« Reply #17266 on: April 18, 2014, 04:41:57 pm »
sold my Xl125,  325 toward the Indian fund,  only 20k to go and seven bikes to sell...Larry
Offline Tews19
  • I am no
« Reply #17267 on: April 18, 2014, 04:44:41 pm »
Split the cases on my 550 build. Now I have to figure out a way to clean and strip the cases...
Sent from my SAMSUNG-SGH-I337 using Tapatalk
1970 Honda CB750 survivor.
Offline Raef
« Reply #17268 on: April 18, 2014, 05:07:36 pm »
Face lift for 2014 is compete, just got the stickers in the mail and put them on. I plan on getting some road time this weekend ;)
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« Reply #17269 on: April 18, 2014, 05:20:25 pm »
Lots accomplished today...
Painted the headers and extension... VHT Hi-Temp Header Paint, flat black.
my "paint booth"
Pre-paint
Primer
Final coat of black
In between coats I managed to get my Lucas tail light installed...
and also cut the flat spot into the upper clamp spacers. Measured, from the fork tube to the outer edge of the "doughnut hole", is 12/32" or 9.525mm. The washer I had sticks out a little bit, but no matter!
I also tidied up the front end wiring with some zip-ties, as I don't want to cut/recrimp a bunch of connections for shorter wires, especially where I already have a basket case and may get some model-correct switches at some point.
--Evan
1975 CB750K "Rhonda"
« Reply #17270 on: April 18, 2014, 06:14:26 pm »
Raef,
Is this a liter size bike ?
Offline Raef
« Reply #17271 on: April 18, 2014, 06:16:27 pm »
Raef,
1998 zx11, 1100 cc
« Reply #17272 on: April 18, 2014, 06:32:53 pm »
a ZX11 ! a guy I knew had one and the front end reminded me of it. Nice Bike  8)
« Reply #17273 on: April 18, 2014, 06:49:37 pm »
ZEP commercial purple decreased on the inside, and out.  Love that stuff.
Offline mcswny
« Reply #17274 on: April 18, 2014, 07:38:07 pm »
Got my bronze swing arm bushings installed. Boy are they snug! Throwing the swing arm back on tomorrow.
Also got progressive fork springs. Excited!
1972 CB750 K2
1997 XR600r (street legal)
1975 XL250
198 XR80
