Author Topic: What did you do to your bike today ?  (Read 3423372 times)
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« Reply #17325 on: April 24, 2014, 11:31:22 AM »
I don't know it is just me or anyone else... but I love soldering.
--Evan
1975 CB750K "Rhonda"
Offline Vinhead1957
« Reply #17326 on: April 24, 2014, 12:21:53 PM »
Should be crimping instead
« Reply #17327 on: April 24, 2014, 12:24:00 PM »
says who?  :P
Offline Tews19
  • I am no
« Reply #17328 on: April 24, 2014, 12:47:45 PM »
Replaced my swing arm bushings in my 71 750... do I reuse the end caps since I went to the flanged bushings?  Also if anyone needs the felt washers I have then in good shape.
Sent from my SAMSUNG-SGH-I337 using Tapatalk
1970 Honda CB750 survivor.
Offline goldarrow
  • one day, i'll be an
« Reply #17329 on: April 24, 2014, 12:49:08 PM »
Yes the end caps go back on
CB550 K0
Offline Vinhead1957
« Reply #17330 on: April 24, 2014, 03:29:33 PM »
They were originally crimped because a good crimp has a more durable connection. Especially in moving things. Started wiring your telephone systems in 1980 and we only soldered the mistakes!
« Reply #17331 on: April 24, 2014, 03:46:19 PM »
What about first crimping & then soldering over it ?
Offline mrbreeze
  • Not your average
« Reply #17332 on: April 24, 2014, 04:58:34 PM »
I think a good crimp makes a good connection but the elements can eventually have their way with it. The solder on top of a good crimp with shrink tubing covering it is probably the best you're gonna get. When I say good crimp............I mean done with a decent set of crimpers. They have cheapies that just smash the connector around the wire but a good set has a tit on one side that makes a way better crimp that the wire won't hop out of.
MEMBER # 257
Offline Greggo
  • Somebody's
  • Helmets Save Lives. Period.
« Reply #17333 on: April 24, 2014, 05:17:25 PM »
Drained my tank, swapped out a leaky petcock, hooked up the new fuel lines after testing it for leaks and took it for a damn ride in the first time in two weeks ;D
Now it's time to sell it!!
Offline edwardmorris
  • Youngish
« Reply #17334 on: April 24, 2014, 05:19:03 PM »
I posted on the steampunk thread ;D  that counts right?
Offline mcswny
« Reply #17335 on: April 24, 2014, 06:07:15 PM »
Nicholas when you go to re install it, don't forget to loosen the engine mount bolt that holds the foot pegs on. It will loosen the frame up a bit allowin the swing arm to easily get it
1972 CB750 K2
1997 XR600r (street legal)
1975 XL250
198 XR80
« Reply #17336 on: April 24, 2014, 06:12:32 PM »
Exactly what I did  ;)
Offline mcswny
« Reply #17337 on: April 24, 2014, 06:14:49 PM »
1972 CB750 K2
1975 XL250
198 XR80
Offline ChrisP.
  • Hold my drink and watch this...
« Reply #17338 on: April 24, 2014, 07:00:07 PM »
Went on my first ride on my first CB750!!
Chris P
1973 Honda CB750K3
« Reply #17339 on: April 24, 2014, 07:39:27 PM »
Looks sweet Chris!   How ya liken it?
Offline CycleRanger
  • No comment about being an
« Reply #17340 on: April 24, 2014, 07:39:38 PM »
Ordered a new Pamco ignition for the .....CJ360T.
At long last Pete has a system for the 360's!!
Offline Sparked
  • Cheaper then therapy
« Reply #17341 on: April 24, 2014, 07:42:27 PM »
Went for the first ride of the year. It's always a good year if I am riding in April. Might snow yet still this weekend though.
1972 CB350F
1982 CM450A
1961 Ford Falcon (time for four wheels)
Offline Sparked
« Reply #17342 on: April 24, 2014, 07:42:38 PM »
1972 CB350F
1982 CM450A
Offline ChrisP.
« Reply #17343 on: April 24, 2014, 07:56:03 PM »
Sweet ride! Quite a bit heavier than my last bike which was a totally different animal altogether; Suzuki DR350!
Chris P
1973 Honda CB750K3
« Reply #17344 on: April 24, 2014, 07:59:33 PM »
That's nice paint.
  • Youngish
« Reply #17345 on: April 24, 2014, 10:57:20 PM »
Started tearing down the franken carbs that came with my bike, good practice for when my good set arrives.
« Reply #17346 on: April 25, 2014, 01:14:16 AM »
Progress again...! Got the head back from my local tuner that fixed the head. 8 new valves, adjusted spring force. Inlet valves had dimples (Mike Rieck helped me with lash caps), new CycleX ex super flow valves replaced due to loose fit in guides.
New Honda F2 inlet valves + kibblewhite exhaust valves plus spring force adjusted on ex side with shims. Too small spring force. I do not know when I lost the shims under springs or if my local tuner missed something for 30 years ago. I might have lost them in later mechanical sessions.
LIFE IS GOOD!! Do the head job with engine in frame ;)
I'll re-torque head 28Nm later today  (20.65 ft lbs) I do not want to torque harder when max is 22 ft lbs according to kibblewhite HD stud instruction
Time cam this weekend... soon starting it again... maybe tomorrow? :)
« Last Edit: April 25, 2014, 04:20:56 AM by PeWe »
Offline maduncle
  • Don't confuse me with a
« Reply #17347 on: April 25, 2014, 02:42:40 AM »
What steampunk thread?
Where?
Post a link for us...
CB750K2 (only slightly modified)
« Reply #17348 on: April 25, 2014, 04:29:39 AM »
I'd rather use the one w/ the 'tit' Anyday...
Offline fire113
« Reply #17349 on: April 25, 2014, 06:38:10 AM »
...drove to the customs station and picked up the parts.
