Author Topic: What did you do to your bike today ?  (Read 3460060 times)
Offline CycleRanger
  • No comment about being an
« Reply #17350 on: April 25, 2014, 07:12:15 AM »
Progress again...! Got the head back from my local tuner that fixed the head. 8 new valves, adjusted spring force. Inlet valves had dimples (Mike Rieck helped me with lash caps), new CycleX ex super flow valves replaced due to loose fit in guides.
Good looking head! Make sure to remove the old copper exhaust gaskets.
Offline Sparked
  • Cheaper then therapy
« Reply #17351 on: April 25, 2014, 07:16:48 AM »
Went for the first ride of the year. It's always a good year if I am riding in April. Nice weather report for the weekend, more snow coming.
1972 CB350F
1982 CM450A
1961 Ford Falcon (time for four wheels)
« Reply #17352 on: April 25, 2014, 07:41:33 AM »
I hope ALL the rest of the snow blows out to sea  and the sun SHINES more  8)
Offline bambuhiphop
« Reply #17353 on: April 25, 2014, 08:21:42 AM »
Got it into a roller   ;D
« Reply #17354 on: April 25, 2014, 08:31:07 AM »
Hondaman clutch center extra oiler holes done and cleaned.
New CYCLE X cork clutch plates soaked and installed without cracking the lifter plate  ;D
Offline ChrisP.
  • Hold my drink and watch this...
« Reply #17355 on: April 25, 2014, 08:34:34 AM »
That's nice paint.
It is, thanks to Chewy!
Chris P
1973 Honda CB750K3
Offline edwardmorris
  • Youngish
« Reply #17356 on: April 25, 2014, 09:09:44 AM »
I posted on the steampunk thread ;D  that counts right?
What steampunk thread?
Where?
Post a link for us...
Here you go
http://forums.sohc4.net/index.php?topic=136511.0
its all the buzz these days.
Offline fire113
« Reply #17357 on: April 25, 2014, 11:37:34 AM »
...took the K1 for a ride ;)
EDIT--> and drove home late
« Last Edit: April 25, 2014, 02:01:15 PM by fire113 »
Offline ChrisP.
« Reply #17358 on: April 25, 2014, 02:58:56 PM »
Got the bike inspected, title, tagged and rode the snot out of her for a 45 mile trip in this warm 88 degree weather! Such a blast!!
Chris P
1973 Honda CB750K3
Offline mcswny
« Reply #17359 on: April 25, 2014, 03:01:26 PM »
Hey now no need to brag on the weather, it's never gettin warm up here in the north east!
1972 CB750 K2
1997 XR600r (street legal)
1975 XL250
198 XR80
Offline ChrisP.
« Reply #17360 on: April 25, 2014, 03:13:23 PM »
Was meant as a jab but more for Chewy's sake. Ha! Ha! It's getting almost too warm to ride!
Chris P
1973 Honda CB750K3
Offline Tews19
  • I am no
« Reply #17361 on: April 25, 2014, 03:56:58 PM »
Sometimes the simplest thing can be a #$%*.
Sent from my SAMSUNG-SGH-I337 using Tapatalk
1970 Honda CB750 survivor.
Offline speedwolf
  • Mull Fember
  • You are the company you keep.
« Reply #17362 on: April 25, 2014, 04:04:34 PM »
Cleaning my spare set of 500 carbs. They were pretty nasty. Top right is after a short dip in NAPA Carb Cleaner and some nylon brush scrubbing.
« Last Edit: April 25, 2014, 04:06:49 PM by speedwolf »
'72 Honda CB500 K1
Offline bambuhiphop
« Reply #17363 on: April 25, 2014, 04:14:09 PM »
Holy Crap!!! And I thought mine was bad.
« Reply #17364 on: April 25, 2014, 10:28:12 PM »
You need my special tool mate, I can take 'em out without damaging anything. Cheers, Terry. ;D
« Reply #17365 on: April 25, 2014, 11:11:16 PM »
The very soft bearing retainers are usually locked with punch marks too. These marks must be drilled with a 3-4mm drill, 3-5mm deep to unlock by removing the destroyed threads.
The other retainer is bad as well, maybe worse. I cut and drilled it into 2 pieces, bought new that I did not lock, my hub is already looking as a Swiss cheese since the replacements earlier. I cannot see how it can move when bolted in the swing. Maybe I'll get new experiences about that this summer :) I have to keep my eyes open.
Offline Sparked
« Reply #17366 on: April 25, 2014, 11:45:05 PM »
Went for a nice long late night ride around and through downtown. Only 4 degrees C when I got home, sure didn't feel that cold.
1972 CB350F
1982 CM450A
« Reply #17367 on: April 25, 2014, 11:54:59 PM »
I was thinking about to reuse the copper gaskets. I torqued the exhaust with that in mind last time, not maximum. They have been used max 2 hours in total.
I have new ones to use, maybe better to be safe, no need to remove the exhaust.
Next, time the cam when everything is bolted and torqued without thread disasters. I'm always worried about the cam tower/caps bolts when reaching 12Nm despite most of them have thread inserts.
Edit: Cyl studs are Kibblewhite mounted bottomed out in the case threads + 8 ft Lbs, nuts standard DIN6331 10.9 grade that was possible to fit. Used thinner washers under nuts to use most of the threads of the higher nuts. Maybe possible without washers, oiled surface under making sure that the head is not scratched, small alu chips.
New cam sprocket from Falicon easier to mount than the previous APE
« Last Edit: April 26, 2014, 12:11:01 AM by PeWe »
Offline Christo
« Reply #17368 on: April 26, 2014, 03:28:29 AM »
Bikes been running a bit rich for a while. Well since iv had it really. Dave500 showed me today how to check the needle clip height and bloody hell, it was sitting on the bottom slot. So we set it back to middle slot. Also put air screws at 1.5 out. Was at 2.5 previously probably trying to compensate for the low clip height. Bike has a 4 into 1 exhaust. (Mac).  PO probably thought that it required a change due to this.
Runs better now. Better low end acceleration and feels more responsive.
Dont get me wrong. It was running good but compared to Daves, it was lacking at the lower end. I am lucky because i can ride Daves bike which is tuned and runs to perfection and i noticed how mine wasnt quite the same. Its closer now. His runs just amazingly. Probably better than off the showroom floor. Anyway a good afternoon learning session. Heres a pic doing a vacuum check at the end.
« Last Edit: April 26, 2014, 04:48:30 AM by Christo »
74 CB550K
« Reply #17369 on: April 26, 2014, 05:16:02 AM »
it helps when stupid dave has enough fuel in the dodgy lawn mower tank to run the engine though!christo blanked out the guage readings aswell its a trade secret!
« Last Edit: April 26, 2014, 05:18:06 AM by dave500 »
« Reply #17370 on: April 26, 2014, 05:56:03 AM »
Went on my first ride on my first CB750!!
That is one sweet ride, Chris!
« Reply #17371 on: April 26, 2014, 05:58:02 AM »
Yes it can :)
« Reply #17372 on: April 26, 2014, 09:08:33 AM »
+1.  I can't wait to ride it!
« Reply #17373 on: April 26, 2014, 12:09:28 PM »
Cam timed, cam sprocket bolts glued with blue thread locker. Valve lashes done and cover on. No thread disaster today too!
Valve cover gasket from yamiya much better than my previous flimsy one from a kit back in the 80's. No extra sealer needed. I used a very thin layer of Permatex copper spray gasket on side facing head.
Cam timing was easy in frame. The frame mod kit neded to cut the triangular bracing, holes in them when mounting frame back was used fror cam timing equipment. No need of magneto foot.
Tomorrow new plugs going in. I have fouled 3-4 setups of plugs when I tuned my carbs with flowing floats.
I hope I'll put everything together and able to start it. Maybe i add an extra relay for my new double snail horn probably need some amps not good for the horn button.
Offline CBGhia
« Reply #17374 on: April 26, 2014, 12:56:35 PM »
Well, it is a hot one here in Texas.  I got the 650 cam in and the new jets are in the carbs.  Need to adjust the valves, put in new plugs and get the carbs back in place.  I'm hoping I can get everything ironed out by next weekend.  Gotta be able to ride the hill country with Godzilla.
