Author Topic: What did you do to your bike today ?  (Read 3918907 times)
0 Members and 23 Guests are viewing this topic.
« Reply #17425 on: May 01, 2014, 01:57:03 AM »
G'Day Krusty, nice vehicles mate. I use Supercheap's "Truckwash", I just mix a little bit with water in a spray bottle, spray it on and leave it for 10 minutes to soften up the bug splat, then hose it off.
The only thing wrong with it is that  if you've used any Armor All on it, you'll have to do it again afterwards, it leaves old plastics etc looking a bit dull. Cheers, Terry. ;D
Offline Steverinomeister
« Reply #17426 on: May 01, 2014, 08:26:19 AM »
I noticed the bell crank wasn't lined up with the throttle cable very well and in trying to loosen a bolt on the carb plate I managed to break off the head of said bolt. Now I am looking at buying I good used mounting plate. Considering this is an all original 7,000 mile K5 that's never been apart I should of taken the approach that some things are better left alone.
Steve
Offline fire113
« Reply #17427 on: May 01, 2014, 08:58:53 AM »
...changed the back light at the K0, found out that the other K0 has rust at he choke lever  :o
Moved K1 & K2 and pulled the K2 project out of the corner where it was waiting for me the last 6 month  ::)
Offline Sgt.Pinback
« Reply #17428 on: May 01, 2014, 10:12:48 AM »
...changed the back light at the K0, ....
Why, cracked?
Are there any differences from K0 - K6 within the German back lights?
Doc, I love a motorcycle!
Offline fire113
« Reply #17429 on: May 01, 2014, 10:26:24 AM »
Why, cracked?
...US and EU version is different!
Offline Sgt.Pinback
« Reply #17430 on: May 01, 2014, 11:29:46 AM »
    • http://forums.sohc4.net/index.php?PHPSESSID=nacu7tpnp39pem62ttskk7hnp6&/topic,60973.0.html
« Reply #17431 on: May 01, 2014, 11:47:47 AM »
he mean over the years..are there thange in germen type/fabrikant rearlight..or are all the same..ko-k6   is it hella? bosch or ulo who made them
edit.... looked at the photo ,, japanese made...
« Last Edit: May 01, 2014, 11:52:54 AM by strynboen »
Offline Sgt.Pinback
« Reply #17432 on: May 01, 2014, 11:56:06 AM »
Sind die deutschen Rücklichter von K0 - F1 alle gleich oder gab´s da Änderungen?
"STANLEY 6 2218 MADE IN JAPAN"
« Last Edit: May 01, 2014, 12:01:50 PM by Sgt.Pinback »
Offline fire113
« Reply #17433 on: May 01, 2014, 01:44:16 PM »
...take a look at the German part list K0-K2
Offline mrbreeze
  • Not your average
« Reply #17434 on: May 01, 2014, 02:38:41 PM »
I've never seen a tail light like that.
MEMBER # 257
Offline Jonathan403
« Reply #17435 on: May 01, 2014, 03:59:57 PM »
Got the cb650 registered and insured. Ready to start riding now....
Edit: then our forecast shows snow for the next 7 days..... :(
« Last Edit: May 02, 2014, 06:34:45 AM by Jonathan403 »
« Reply #17436 on: May 01, 2014, 08:57:16 PM »
Started stocking up on a few summer goodies. Honda'a like a fresh battery. Only problem with more than one bike is you have to buy in bulk. Not quarts of oil but gallons and not a few plugs but boxes. Its fun though.
  Started up the old everyday rider today also, She acted a little snotty after sitting for this nice pleasant winter  ::)  with that good fuel left in her carbs but after a little coaxing belched to life with her usual roar, 4 pipes burning hot and ready to go.
  What the Hell is that Harley doing in the shop   ::)
« Reply #17437 on: May 02, 2014, 02:17:06 AM »
Hey nice Harley Eric, you're right, it does look out of place in your bike hole, can you send it to me please mate? ;D
Offline Wollongongwolf
« Reply #17438 on: May 02, 2014, 02:45:52 AM »
Fitted the new Motad exhaust, lot of polishing , degreasing, washing and hoping to get it registered and on the road soon.
Suzuki DRZ400
1976 Suzuki TS400
1984 XL350R
1976 CB550F Super Sport
Offline Sgt.Pinback
« Reply #17439 on: May 02, 2014, 03:03:59 AM »
OK, three different numbers.
Can you tell me the differences?
« Reply #17440 on: May 02, 2014, 03:14:02 AM »
Eric, you forgot to say what oil are you using  ;D
Always love to see pictures of your collection, thanks.
Offline fire113
« Reply #17441 on: May 02, 2014, 06:55:51 AM »
..Lens is always the same but the assy is different, thats all ;)
« Reply #17442 on: May 02, 2014, 10:52:39 AM »
stop licht are gelb.<??.oder ..ve cant use it in denmark..they vant red breakelight..
but ve often use the small side blinksignals kombined vith old type  small rearlights from 400 four...
Offline Jerilee
« Reply #17443 on: May 02, 2014, 12:49:30 PM »
got curious while I was working on the Saab so i popped open the tappet covers and noticed a little rust on the intake valves. Confirms what I thought about water getting in the PO's pod filters. I put some oil in over the tappets, down the intakes, in the exhaust tappets and down the plug holes and then rotated the thing a few degrees. still moves freely, hopefully the inside will be in good-enough shape when I get the the engine part of the build.
Jeri~
My F2 build http://forums.sohc4.net/index.php?topic=126314.0
77/78 cool 2 member
Offline jhalldorson
« Reply #17444 on: May 02, 2014, 04:25:38 PM »
Got my carbs mounted and some wiring sorted. Drag bars going on this weekend, time permitting:)
Sent from my EVO using Tapatalk 2
Online grcamna2
« Reply #17445 on: May 02, 2014, 05:22:11 PM »
That's some Beautiful shining machine jhalldorson !  8)
Offline jhalldorson
« Reply #17446 on: May 02, 2014, 06:07:06 PM »
Thank you grcamna! I'm hoping to get to hear it run sometime soon.
« Reply #17447 on: May 02, 2014, 06:11:27 PM »
Hi J...does that silver overspray on the oil pressure sender look familiar to me for some reason?
Offline Hrvatski Medvjed
« Reply #17448 on: May 02, 2014, 06:48:48 PM »
Long list today: picked up newly polished & ported head from machine shop - I had some bent valves replaced so I figured "why not?" Buttoned the 500k engine back together with all new gaskets, 650 cam, 750 carbs, and dyna ignition...after a long winter and some rebuilding mistakes, Iwas finally able to fire up my ol' girl. Tomorrow I finish some wiring and synch the carbs. SO HAPPY TONIGHT!
"Two Possibilities Exist...Both are Equally Terrifying" - Arthur C. Clarke
Offline rb550four
« Reply #17449 on: May 02, 2014, 07:08:06 PM »
HM, thinking of using 73 750 carbs on one of the 550's. Did I read somewhere that you can use  stock 650 rubber connectors to attach those carbs to the 500/550 manifolds? Also , I was once warned that the carbs may not work because the slides in open position will interfere with the bottom of the tank, have you encountered this problem? I haven't tried it out yet because of the connector issue so I don't know for sure, but I'd like to know that it actually works before investing in connectors,so, does it work?
