Author Topic: What did you do to your bike today ?  (Read 3460389 times)
Offline rickman750
« Reply #17800 on: June 14, 2014, 12:24:17 AM »
Swapped forks left to right to correct the PO's wrongness. I'm guessing he wanted the callipers behind the fork leg. I want them in their correct position, ahead of the fork.
PO had cut and welded the front guard to make it fit. Now I have to find some crappy and cheap guard.
    • http://forums.sohc4.net/index.php?PHPSESSID=epbrsaf1c02vt32sif0cd97r84&/topic,60973.0.html
« Reply #17801 on: June 14, 2014, 03:33:36 AM »
kleaned kaburators on nic..500.. battery acid,, takes all oxyd and dirt..but it needs a vask and kleaning after to neutral all acid..before wd 40 spray..
Offline Jerilee
« Reply #17802 on: June 14, 2014, 01:07:23 PM »
Not much today or yesterday, work interrupted the important work of bike resto :P
I did let the Electrolysis bath have at the exhaust manifold, did OK, the amps have been low in the bath for a few days. I'll poke at the bath and battery charger before I put the tanks in. Yesterday I cleaned up all of those SAAB cams and the bolts for the carriers. More precious bike work lost! :P
Jeri~
My F2 build http://forums.sohc4.net/index.php?topic=126314.0
77/78 cool 2 member
Offline mcswny
« Reply #17803 on: June 14, 2014, 05:24:12 PM »
After buying the wrong center stand off flea bay, I finally got my correct center stand stand (THANKS BILL BENTON!!) and installed and was able to lube my chain WITHOUT my lift. And yes, it was niceeeeeee!
Sent from my iPad using Tapatalk
Well it's a really good thing I got my center stand on because...
Last night my bike got pushed over/backed into and knocked over. Kick stand was crumbled, clutch lever broken in half and most unfortunately my unicorn horn top tree broke. So today I had to put on a 74 top tree (was saving for a different project) and had to leave off my tach and speedo in the meantime unfortunately so I can still ride my bike. I'm not sure what my plan is now. My bikes kind of a basket case (although the engine runs strong and tough). So I'm having a hard time justifying buying a expensive unicorn triple tree.
While everything was off I also upped my fork oil from 10w to 15w.
1972 CB750 K2
1997 XR600r (street legal)
1975 XL250
198 XR80
Offline edwardmorris
  • Youngish
« Reply #17804 on: June 14, 2014, 09:26:28 PM »
Sanded aluminum with finer grits, installed all new double sealed SKF bearings on hubs and sprocket carrier, installed nice new master cylinder sticker on my powder coated MC, left hand drilled out stuck speedo cable screw at the drive (anyone have a spare? Please PM me).
Offline thirsty 1
« Reply #17805 on: June 14, 2014, 10:33:22 PM »
I took the 400 to costco and picked up a half gal of cheap vodka. 25bucks - good deals in Costco. I didn't really do anything to old girl except have fun on her.
Offline thirsty 1
« Reply #17806 on: June 14, 2014, 10:34:55 PM »
LAME O
« Reply #17807 on: June 15, 2014, 12:39:33 AM »
Well the weather here is sh1t at the moment, winter has settled over southern Oz like a big wet poop and motivation has reached an all time low, but I'm slowly turning a pile of rusty parts back into a bike. ;D
Offline rickman750
« Reply #17808 on: June 15, 2014, 01:41:48 AM »
C'mon, Terry. Melbs is a bit cool, but you should try the National Capital!
Fiddled with my callipers. Looks like I'll need some professional help to make a sealing surface where the banjos will seal. Also looks like I'll have to drill an 8.5mm port deeper and use a 10x1mm bottoming tap to make the Venhill parts work.
Phill in  Canberra.
Offline bikerbart
« Reply #17809 on: June 15, 2014, 11:38:52 AM »
Love it Terry, that reminds me of a carnival ride in the 70's. Sweet! I put my last valve on today , getting ready to put her back together.
Offline mcswny
« Reply #17810 on: June 15, 2014, 11:58:00 AM »
LAME O
You're telling me! Turned a day that was supposed to be spent at the beach into a day of wrenching. Not the worst, but was definitely hot enough for some good ole swimming
1972 CB750 K2
1975 XL250
198 XR80
Offline KirkBurner
« Reply #17811 on: June 15, 2014, 01:10:32 PM »
Well..  today I bought a new CB750
« Reply #17812 on: June 15, 2014, 01:38:12 PM »
"Basket case"!   Another failed project, hope you can bring new life to it.
« Reply #17813 on: June 15, 2014, 01:54:09 PM »
Poor Terry, no wonder there's no motivation being trapped in that big wet poop!  ;D
Offline KirkBurner
« Reply #17814 on: June 15, 2014, 01:58:10 PM »
he didnt have time to finish it off.. so, I got a sweet deal on it loads of spare parts and new parts...
ohh there will be life.. not this week.. but there will be life...
Offline Jo3f1sh
  • Still don't have a jacket, even though I'm a
« Reply #17815 on: June 15, 2014, 03:11:11 PM »
Installed a Lucas style tail light, Dyna 5ohm coils and Pamco ignition. After brain farting and forgetting to tap INTO the kill switch line and not just bypass it, it finally cranked right up after actually wiring it up correctly. For being my first bike, it was incredibly easy to do. Still need to get it timed.
After that, I tried to install my 18T sprocket, but the PO had stripped the screw heads on the cover...and then I proceeded to break off two drill bits in it trying to get it out. Oy vey.
1974 Honda CB350 Four
Build thread: http://forums.sohc4.net/index.php?topic=138848.0
Offline Tews19
  • I am no
« Reply #17816 on: June 15, 2014, 04:49:00 PM »
Terry sweet looking bike. Where did you get the seat and are you looking to sell it?
1970 Honda CB750 survivor.
Offline Schnell
« Reply #17817 on: June 15, 2014, 05:12:48 PM »
This, from a pliĆ© of rusty parts?!?  Nice. :)
primary: 1974 Honda CB750
project: 1971 Honda CL350
project: 1974 Honda CB450
previous:
1975 Honda CB750
1973 BMW R90/6
1981 Suzuki GS650
1973 Honda CD175
Offline 1974CB750rider
  • 1974 CB750K4 46000 miles
« Reply #17818 on: June 15, 2014, 05:17:44 PM »
After riding my DOHC for a good while now. I fired up the 74 model. I took it for a nice ride and damb it felt good.
People with closed minds cannot learn new things.
  • Youngish
« Reply #17819 on: June 15, 2014, 09:10:02 PM »
Finished clear/blue chromate conversion for most of the hardware.
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« Reply #17820 on: June 16, 2014, 04:56:54 AM »
Put on the new Oury grips and the throttle stopper from Yamiya. Brake pipe from Slingshot should arrive today! Then I can ride again!
--Evan
1975 CB750K "Rhonda"
« Reply #17821 on: June 16, 2014, 05:24:55 AM »
Wow!
Offline Jo3f1sh
« Reply #17823 on: June 16, 2014, 07:29:58 AM »
Offline Hon3ybadger
  • Someday it will run...
« Reply #17824 on: June 16, 2014, 08:48:10 AM »
Today I will hopefully be vinyl wrapping my tank. Saturday I was able to finally get her running and tuned. I love my new dyna coils!
