Author Topic: What did you do to your bike today ?  (Read 3279775 times)
Markcb750
« Reply #18775 on: November 02, 2014, 04:48:03 AM »
Hi Dhall
It was only 11 bucks with the fancy flip up cap, figured I would try it for awhile.  The 900F has the switch above the handlebar clamp, it is convenient for the garage door fob.  Butthoonose
I got to do about 20miles on a 76 GL last weekend.  Motor is not running properly but the bike rides nice. Sounds like a rod knock, (PO had just rebuilt the motor) must have missed something important!  :o :)
« Reply #18776 on: November 02, 2014, 05:26:21 AM »
Installed a OEM ignition switch bracket I found on eBay.
What is OEM? Doesn't look like it to me.
Markcb750
« Reply #18777 on: November 02, 2014, 06:07:28 AM »
Came in a Honda bag with the markings of a NOS part, but your guess may be right....
« Last Edit: November 02, 2014, 05:35:00 PM by Markcb750 »
Offline 750cafe
« Reply #18778 on: November 02, 2014, 06:26:26 AM »
I REBUILT THE ENGINE 8)
Powder coated or appliance paint on the frame?
VHT cast aluminum caliper paint on the engine?
Do you have a thread in the build section? Link?
Eric
Is there anything more fun than riding? They are between your legs and are quiet when you turn them off.
Offline JW Miles
« Reply #18779 on: November 02, 2014, 08:14:14 AM »
Hi Eric,
I am new to this and can hardly find my way back :P
I am trying to refinish the paint and finishes as they came from Honda.
Enamel on the frame, Engine enamel on the engine, VHT clear coat on the aluminum also engine enamel.
I have tolearn how to publish our work.
All the hardware has been replated and or replaced with nos.  Including the kick shaft, shift spindle and rear brake actuator shaft.
« Last Edit: November 02, 2014, 08:19:23 AM by JW Miles »
Offline 750cafe
« Reply #18780 on: November 02, 2014, 08:43:30 AM »
I can never find my way back in this forum.
There seems to be no provision for following subscribed threads besides waiting for someone else to post in one that you have previously posted in. Weird!
For paint, you did a fantastic job on that frame.  :D  I use appliance epoxy paint myself and it is difficult to tell the difference from powder coating.
Eric
« Reply #18781 on: November 02, 2014, 11:47:28 AM »
Eric
ITs a bandaid I know, but I save it (the thread in question) as a favorite place. Then I can return to it easily with no search.
« Reply #18782 on: November 02, 2014, 11:54:30 AM »
Eric
There should be a button to escape threads too... ;D
Nic
« Reply #18783 on: November 02, 2014, 01:03:17 PM »
Eric
unnotify at the bottom of the page.
Offline dave the welder
  • dave the welder
« Reply #18784 on: November 02, 2014, 02:00:51 PM »
went back out today.the cleaning faries did not show up to do their job but my boys(26&24 years old)promised me they would clean it this week.will let everyone know if i pass out from holding my breath on this one
don't buy it build it
« Reply #18785 on: November 02, 2014, 02:03:19 PM »
Eric
Gday Nic, I don't have that function... :o
Nic
« Reply #18786 on: November 02, 2014, 02:59:23 PM »
Eric
G/day Mick, that's strange.
« Reply #18787 on: November 02, 2014, 03:12:08 PM »
Eric
Any chance you could post a screen shot of a page with unnotify tab...?
Nic
« Reply #18788 on: November 02, 2014, 04:04:58 PM »
Eric
Here you go mate.
« Reply #18789 on: November 02, 2014, 04:55:26 PM »
I have the same tabs but mine says "notify".... :o
Nic
« Reply #18790 on: November 02, 2014, 05:10:11 PM »
It changes to unnotify once you post on the thread, if you haven't posted on the thread it should say notify but unnotify if you have posted.
You may need to go to your profile, edit profile, "turn notifications on"
« Last Edit: November 02, 2014, 05:17:54 PM by Nic »
Offline edwardmorris
  • Youngish
« Reply #18791 on: November 02, 2014, 06:51:23 PM »
Final piece done, Project Ice Cream is now ready for assembly
« Reply #18792 on: November 02, 2014, 07:00:35 PM »
Looking forward to your finished project, you have applied much 'elbow grease'   ;)
Nic
« Reply #18793 on: November 02, 2014, 07:11:38 PM »
Awesome as usual 8)
  • Youngish
« Reply #18794 on: November 02, 2014, 07:13:56 PM »
Thanks fellers, can't wait to get it on the road. Will be putting together whatever small parts I can this winter, mostly the bolt on stuff so I have it ready. Spring is when I plan on the final assembly to begin.
Offline DWS
  • Treat others as you would like to be treated .
« Reply #18795 on: November 03, 2014, 10:59:17 AM »
Broke a bit trying to drill and tap my petcock, now i have to buy one. eerrrrr
Always looking for friends.
78CB750F3
PD 42A with original breadbox
4 into 1
valves adjusted to .003 (intake and exhaust) ( as was suggested for cooling )
slow jets#35 Main #110
 turned out to 1.5 some paper work says 1.75
4800 feet altitude
78 Honda CB 750 F3 Restoring now(Almost done)
BSA MX 50 Next
BSA b50T Parts
Offline bambuhiphop
« Reply #18796 on: November 03, 2014, 11:10:57 AM »
Masked the case in preparation for mineral blasting  :)
Offline rickman750
« Reply #18797 on: November 04, 2014, 02:10:54 AM »
New tyres fitted. Wheels installed. Brakes and chain adjusted. "PhillSpec" air filter under construction.
Edging closer and closer to rideable!
Offline 72 yellow
« Reply #18798 on: November 04, 2014, 03:01:36 PM »
Tried to figure out why it decided suddenly it didn't want to start.  >:(  Did find one plug cap that was dead.  Ran out of time to go farther.
« Reply #18799 on: November 05, 2014, 04:45:03 AM »
Broke down and parted out what was left of a build date 6/75 750F frame and engine as part of operation shop clean. No camera but we have all seen dirty parts. Boxes of parts to still go through and organize from another summer buying season.
