Author Topic: What did you do to your bike today ?  (Read 3209273 times)
0 Members and 13 Guests are viewing this topic.
Offline Mikey S
« Reply #19150 on: January 30, 2015, 07:51:00 PM »
Finally removed the massive tail light "tower" structure. Rewired and mounted the rear blinkers in the holes where the frame meets the rear fender. Drilled holes in the rear fender and wired up a Lucas style tail light. Had to drill some holes in the Lucas license plate bracket to fit a Georgia plate. Plugged in a new Emgo ignition switch (the original was fried) and moved it from the bars to its proper place below the tank. Got my local cycle shop to put a new tube in my front tire because the old one went flat at about 40 mph. Called the cops on some dude who tried to fight my neighbor. Had a beer.
« Reply #19151 on: January 31, 2015, 12:55:48 AM »
sounds pretty typical ???
Offline maduncle
  • Don't confuse me with a
« Reply #19152 on: January 31, 2015, 01:34:19 AM »
Yep. Looking at your avatar, I can guess why you may have wished to tone down that 'tower of tail light power' behind a cafe seat.
Glad you had a beer.
Have another.
CB750K2 (only slightly modified)
« Reply #19153 on: January 31, 2015, 09:12:39 AM »
Put the front end back together on my K4 after installing All Balls steering bearings and fork seals and boots. Everything went well and the forks ears lined up great. Think I will do a good tuneup/maintenance routine on the engine etc and hopefully be good to go when the robins fly.
« Last Edit: January 31, 2015, 09:14:26 AM by ekpent »
Offline supersports400
« Reply #19154 on: January 31, 2015, 09:50:03 AM »
Finished a Honda C50 engine (for my brother's C50), to make room for the CB400F engine. It's the spare engine, he's doing 10.000 km per year. After 20.000 km, I just swap engines, gives me time to do things in between other projects. After 20.000 km it only needed a re-bore and a valve job, new points and a new condenser. As an experiment I mounted a carburettor from a more modern C50. Mileage is around 60 km per litre.
« Last Edit: January 31, 2015, 09:59:22 AM by jensen »
Offline Mikey S
« Reply #19155 on: January 31, 2015, 06:26:42 PM »
seanbarney41 - all in a day's work, my friend
maduncle - new avatar coming soon. Cheers
    • http://forums.sohc4.net/index.php?PHPSESSID=3gojtpjnmee4v46f8q400jnq57&/topic,60973.0.html
« Reply #19156 on: February 01, 2015, 08:38:32 AM »
got my new 400 home.. it have a defekt main light...faund the mainlight is a 750 or 550......so my ekstra lens from my other 400 dont fit the lighthousing...so get the vindjammer dovn from attic..and got the H4 lighting pulled aut..and filled in the bog housing..a bit polishing..and most parts start shinng..only the rear fender and thain gard/ fender..can not hold the crome..so go the painted vay..until the money are for new parts...
i have to go road test,,for keep the regi plate...so have 14 days to get it refistered in my name...
light ears are" thomaseli"..think i keep the big headlight and this setup...
cam chain rattel..but it must vait...
« Last Edit: February 01, 2015, 08:43:27 AM by strynboen »
« Reply #19157 on: February 01, 2015, 09:20:05 AM »
My K6 got its new Ikon shocks mounted. Look much better and match the chromed chain guard very well.
I'll restore the old Marzocchi AG Strada later on. Need another bike for them  :D
« Reply #19158 on: February 01, 2015, 10:24:30 AM »
Those look good and I will consider them for a stock looking replacement for my K4.
Please give us a review and you have had a chance to road test them.
« Reply #19159 on: February 01, 2015, 10:32:16 AM »
Been raining most of this weekend but did have a nice ride on the K4 last Sunday....
There is a new home comunity being built about 5 miles from my house. There is an excellent road to ride and at the end they built a beautiful community pool and park on a bluff overlooking the River. One lone boater out...
Offline eigenvector
« Reply #19160 on: February 01, 2015, 10:33:44 AM »
Put the front forks back together finally.  Seals didn't come in until Saturday afternoon, popped them in with a bar clamp and threaded section of PVC pipe.  Not too bad, had a tendency to wiggle in side to side but I got them seated.
Hardest part of the whole job was remembering how the damper unit was assembled everything else was a piece of cake.
Used a 6 oz can of cat food to measure the new oil (had to use what I had available ;D)
Rob
2018 HD Softail Heritage
1979 CB750K Limited Edition
1977 CB550K
1984 CB700SC Nighthawk
1983 VF750S Sabre
Offline socal1200r
« Reply #19161 on: February 01, 2015, 01:42:38 PM »
Bought a Mobius action cam, and took it out for a road test.  The setup cost about $130, which was for the camera itself, USB cord, handlebar mount, and 32GB memory card.  Have to experiment with other mounting locations, in order to decrease the vibration.  Also have to figure something out to decrease the wind noise.  But for $130, it does a fairly decent job, IMHO...
Offline maduncle
« Reply #19162 on: February 01, 2015, 01:44:34 PM »
"Fork oil - now with extra meaty goodness".
« Reply #19163 on: February 01, 2015, 02:22:12 PM »
I have to wait for road tests. 4WD is my choice nowadays. I'm waiting for parts anyway. My thread repair kit seems to be stucked in New York Airport, USPS.
« Reply #19164 on: February 01, 2015, 02:26:55 PM »
Yes, the only choice for me when I'll soon mount 4-4 on the bike. Good combination.
Nic in Australia might chime in with his experiences of his Ikons, but without caps, same shocks otherwise.
http://forums.sohc4.net/index.php?topic=142552.msg1618562#msg1618562
Offline eigenvector
« Reply #19165 on: February 01, 2015, 03:02:08 PM »
They actually work quite well.  A large can of cat food is 5.9 oz.  Just enough to fill the tube, but leaves enough room to top off once they're installed.
Rob
1977 CB550K
1983 VF750S Sabre
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« Reply #19166 on: February 01, 2015, 03:44:05 PM »
Don't the lucas lights look awesome on these bikes? I love mine.
--Evan
1975 CB750K "Rhonda"
Offline Gene
  • Chat enuf you too can be a
« Reply #19167 on: February 01, 2015, 07:13:36 PM »
Realized I went the wrong way on a float adjustment, 1st dip into carb territory, sighed deeply, did a tune-up on my back-up and made plans to alter my initial mistake this week.
*1973 CB750K3 (Bow)
« Reply #19168 on: February 01, 2015, 08:48:10 PM »
I'd like to get a camera.  Your video started out good, but then you just followed that car in front when you could have passed or stayed right when they went left.
Try putting something over the mic to lower the wind noise.
Offline 750cafe
« Reply #19169 on: February 02, 2015, 07:19:54 AM »
I have used a couple of layers of electrical tape myself to buffet some of the wind noise.
Eric
Is there anything more fun than riding? They are between your legs and are quiet when you turn them off.
Offline InAquaVeritas
« Reply #19170 on: February 02, 2015, 12:11:52 PM »
Taping the mic would def help with the wind, nice quality as well!
I was looking to get one of the Bullet HD cameras. Have seen them used on a few action sports and car tv shows (recently in Top Gear, Hammonds helmet when he is on the 9000,- pushbike). I like the shape more and hope I can mount it so it sits underneath the helmet itself. Sort of upside down attached to where the cheek cushions sit. The mount looks too tall though, maybe something custom?
Surf bum trying his hand at wrenching!
Past "bikes" ;)
1981 Honda MT 50cc - Torn apart, put back together and got run down on..
1994 Derby Senda R 50cc - Fell apart
2001 Derby Senda R 50cc - 13/45 changed to 15/70, hit 90 kph in under 150 meters! Undriveable fun!
1987 Suzuki GN250 - Sold
1977 Honda CB750 F1 - F2 engine, '05 ZX6R front end and wheels, '04 ZX6R shortened swing arm converted to twin shock. http://forums.sohc4.net/index.php?topic=133411.0
1987 Honda XR600 Supermoto conversion. CR250 forks and triple. SM wheels, discs front and back. Rebuilt engine. Loudest exhaust in the world: Leovinci X3
« Reply #19171 on: February 02, 2015, 12:24:21 PM »
Started the tear-down of the CB750 to hopefully find and repair my missing 5th gear...again  ::)
"This is my CB. There are many like it, but this one is mineā€¦"
« Reply #19172 on: February 02, 2015, 01:07:55 PM »
Repaired one failed helicoil for one of the cam holder studs. One of the inner.
Big-Sert is the 2:nd chance.
Nic
« Reply #19173 on: February 02, 2015, 02:51:33 PM »
5th still no good?
Nic
« Reply #19174 on: February 02, 2015, 02:54:15 PM »
The linked post pretty much says it all, nothing has changed. Once I got the Ikons all the handling issues on this bike virtually disappeared.
